Ghost webhook-triggered build stuck in Starting Up state
Hello.
I have a small blog which has been working fine for years: https://f70f2d06-bbf5-4bce-bfdb-6b93306c6e7a.netlify.app/
It is a headless Ghost as CMS and then webhooks trigger a build and deploy on Netlify. Recently all deploys triggered via Ghost hook (“Deploy triggered by hook: Ghost update”) show up with “Starting Up” state, but it doesn’t seem like they even initialize/start - there is absolutely nothing in the logs, and they just get stuck in such state until time out and failure.
When I manually trigger the build everything works fine.
This is on free tier, with 1 concurrent build and the issue happens still within free limits.
Hey @Anarion :wave:,
Thanks for reaching out!
We’ve gone ahead and created a support ticket for you, so our team can follow up with you directly via email from the help desk. Our Support crew will be in touch with you by email soon.
Great news: these days anyone can reach out to Netlify Support. First, you can try getting an answer using Ask Netlify, our helpful AI search tool. If your question isn’t answered there, you can submit a ticket using the support form, and we’ll take it from there.
We’re keeping the community around for swapping ideas, sharing tips and tricks, and talking shop with other folks building on the platform — but for support issues, tickets are the way to go.
Thanks for being here, and keep an eye out for that email from us!
