Gatsby build is failing Command failed with exit code 1: yarn build (https://ntl.fyi/exit-code-1)
Hi Team,
my website gatsby build is failing
here is the screenshot
anyone who can help me out to resolve this build issue
Hi @bangash11
That stacktrace is not enough to understand the issue. Do you mind sharing more in a clode block?
The previous 200 lines or so might be sufficient.
Thanks!
11:48:16 PM:             "https://tests.wikijob.co.uk/nyc-gifted-talented",
11:48:16 PM:             "\\bNYC Gifted and Talented Test\\b|\\bG&T test\\b"
11:48:17 PM:         ],
11:48:17 PM:         [
11:48:17 PM:             "https://tests.wikijob.co.uk/at-t-assessment",
11:48:17 PM:             "\\bAT&T\\b"
11:48:17 PM:         ],
11:48:17 PM:         [
11:48:17 PM:             "https://tests.wikijob.co.uk/map-5-grade",
11:48:17 PM:             "\\bNWEA 5th Grade\\b|\\bmap grade 5\\b"
11:48:17 PM:         ],
11:48:17 PM:         [
11:48:17 PM:             "https://l.wikijob.co.uk/etoro-trading-course",
11:48:17 PM:             "\\beToro Trading School\\b"
11:48:17 PM:         ],
11:48:17 PM:         [
11:48:17 PM:             "https://l.wikijob.co.uk/etoro",
11:48:17 PM:             "\\betoro\\b"
11:48:17 PM:         ],
11:48:17 PM:         [
11:48:17 PM:             "https://tests.wikijob.co.uk/coinbase",
11:48:17 PM:             "\\bcoinbase\\b"
11:48:17 PM:         ],
11:48:17 PM:         [
11:48:17 PM:             "https://l.wikijob.co.uk/thomas-kralow",
11:48:17 PM:             "\\bThomas Kralow\\b"
11:48:17 PM:         ]
11:48:18 PM:     ],
11:48:18 PM:     "layout": {
11:48:18 PM:         "scrollableLayout": true
11:48:18 PM:     }
11:48:18 PM: }
11:48:18 PM: error Command failed with exit code 1. (https://ntl.fyi/exit-code-1)
11:48:18 PM: info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
11:48:18 PM: ​
11:48:18 PM: ────────────────────────────────────────────────────────────────
11:48:18 PM:   "build.command" failed
11:48:18 PM: ​
11:48:18 PM:   Error message
11:48:18 PM:   Command failed with exit code 1: yarn build (https://ntl.fyi/exit-code-1)
11:48:18 PM: ​
11:48:18 PM:   Error location
11:48:18 PM:   In Build command from Netlify app:
11:48:18 PM:   yarn build
11:48:18 PM: ​
11:48:18 PM:   Resolved config
11:48:18 PM:   build:
11:48:18 PM:     base: /opt/build/repo/packages/wikijob
11:48:18 PM:     command: yarn build
11:48:18 PM:     commandOrigin: ui
11:48:18 PM:     environment:
11:48:19 PM:       - CLOUDFLARE_API_KEY
11:48:19 PM:       - CLOUDFLARE_EMAIL
11:48:19 PM:       - CLOUDFLARE_ZONE_ID
11:48:19 PM:       - DP_GATSBY_STRIPE_SK
11:48:19 PM:       - DP_GATSBY_STRIPE_TAX_RATE
11:48:19 PM:       - GATSBY_BUY_COURSE_PATH
11:48:19 PM:       - GATSBY_STRIPE_PK
11:48:19 PM:       - GATSBY_STRIPE_SK
11:48:19 PM:       - GATSBY_STRIPE_TAX_RATE
11:48:19 PM:       - NETLIFY_GRAPH_TOKEN
11:48:19 PM:       - NETLIFY_USE_YARN
11:48:19 PM:       - NODE_VERSION
11:48:19 PM:       - ONEGRAPH_AUTHLIFY_TOKEN
11:48:19 PM:       - REVIEW_ID
11:48:19 PM:       - YARN_VERSION
11:48:19 PM:     publish: /opt/build/repo/packages/wikijob/public
11:48:19 PM:     publishOrigin: ui
11:48:19 PM:   plugins:
11:48:19 PM:     - inputs: {}
11:48:19 PM:       origin: ui
11:48:19 PM:       package: netlify-purge-cloudflare-on-deploy
11:48:19 PM:       package: '@netlify/plugin-lighthouse'
11:48:20 PM: Caching artifacts
11:48:20 PM: Started saving workspace packages/common node modules
11:48:20 PM: Finished saving workspace packages/common node modules
11:48:20 PM: Started saving workspace packages/psychometric node modules
11:48:20 PM: Finished saving workspace packages/psychometric node modules
11:48:20 PM: Started saving workspace packages/wikijob node modules
11:48:20 PM: Finished saving workspace packages/wikijob node modules
11:48:20 PM: Started saving workspace packages/wjdotcom node modules
11:48:20 PM: Finished saving workspace packages/wjdotcom node modules
11:48:20 PM: Started saving workspace root node modules
11:48:20 PM: Finished saving workspace root node modules
11:48:20 PM: Started saving build plugins
11:48:20 PM: Finished saving build plugins
11:48:20 PM: Started saving yarn cache
11:48:20 PM: Finished saving yarn cache
11:48:20 PM: Started saving pip cache
11:48:20 PM: Finished saving pip cache
11:48:20 PM: Started saving emacs cask dependencies
11:48:20 PM: Finished saving emacs cask dependencies
11:48:20 PM: Started saving maven dependencies
11:48:20 PM: Finished saving maven dependencies
11:48:20 PM: Started saving boot dependencies
11:48:20 PM: Finished saving boot dependencies
11:48:20 PM: Started saving rust rustup cache
11:48:20 PM: Finished saving rust rustup cache
11:48:21 PM: Started saving go dependencies
11:48:21 PM: Finished saving go dependencies
11:48:52 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
11:48:52 PM: Creating deploy upload records
11:48:52 PM: Failing build: Failed to build site
11:48:52 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2)
11:48:52 PM: Finished processing build request in 7m26.722273081s
here is the complete log @gaulter please
generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:07 PM: er",
            "\\bReckitt Benckiser Assessment\\b|\\bReckitt Benckiser test\\b|\\bReckitt Benckiser\\b"
11:48:07 PM:         ],
11:48:07 PM:         [
11:48:07 PM:             "https://tests.wikijob.co.uk/amazon/warehouse-prep",
11:48:07 PM:             "\\bAmazon Warehouse and Fulfillment online assessment\\b|\\bAmazon Warehouse and Fulfillment assessment\\b"
11:48:07 PM:         ],
11:48:07 PM:         [
11:48:07 PM:             "https://l.wikijob.co.uk/lendsecured",
11:48:08 PM:             "\\bLendsecured.eu\\b"
11:48:08 PM:         ],
11:48:08 PM:         [
11:48:08 PM:             "https://tests.wikijob.co.uk/deductive-link",
11:48:08 PM:             "\\bdeductive reasoning\\b"
11:48:08 PM:         ],
11:48:08 PM:         [
11:48:08 PM:             "https://tests.wikijob.co.uk/verbal-reasoning-tests",
11:48:08 PM:             "\\bverbal reasoning tests\\b|\\bverbal reasoning test\\b|\\bverbal test\\b|\\bverbal\\b"
11:48:08 PM:         ],
11:48:08 PM:         [
11:48:08 PM:             "https://tests.wikijob.co.uk/opq32",
11:48:08 PM:             "\\boccupational personality questionnaire\\b|\\bSHL OPQ test\\b|\\bOPQ32 test\\b|\\bOPQ test\\b|\\bSHL OPQ\\b|\\bOPQ32\\b|\\bOPQ\\b"
11:48:08 PM:         ],
11:48:08 PM:         [
11:48:08 PM:             "https://tests.wikijob.co.uk/critical-reasoning-test",
11:48:08 PM:             "\\bCritical Reasoning\\b"
11:48:08 PM:         ],
11:48:08 PM:         [
11:48:08 PM:             "https://tests.wikijob.co.uk/non-verbal-reasoning",
11:48:08 PM:             "\\bnon-verbal reasoning\\b|\\bnon-verbal\\b|\\bnon verbal\\b"
11:48:08 PM:         ],
11:48:08 PM:         [
11:48:08 PM:             "https://tests.wikijob.co.uk/logical-link",
11:48:08 PM:             "\\blogical reasoning\\b"
11:48:08 PM:         ],
11:48:09 PM:         [
11:48:09 PM:             "https://tests.wikijob.co.uk/logical-test",
11:48:09 PM:             "\\blogical reasoning\\b"
11:48:09 PM:         ],
11:48:09 PM:         [
11:48:09 PM:             "https://tests.wikijob.co.uk/spatial-reasoning",
11:48:09 PM:             "\\bspatial awareness\\b|\\bspatial reasoning\\b"
11:48:09 PM:         ],
11:48:09 PM:         [
11:48:09 PM:             "https://tests.wikijob.co.uk/critical-reasoning",
11:48:09 PM:             "\\bcritical reasoning\\b"
11:48:09 PM:         ],
11:48:09 PM:         [
11:48:09 PM:             "https://tests.wikijob.co.uk/diagrammatic-check-out",
11:48:09 PM:             "\\bdiagrammatic reasoning\\b|\\bdiagram tests\\b|\\bdiagrammatic\\b"
11:48:09 PM:         ],
11:48:09 PM:         [
11:48:09 PM:             "https://tests.wikijob.co.uk/isee-lower-level",
11:48:09 PM:             "\\blower level ISEE test\\b"
11:48:10 PM:         ],
11:48:10 PM:         [
11:48:10 PM:             "https://tests.wikijob.co.uk/nhs-aptitude-tests",
11:48:10 PM:             "\\bNHS\\b"
11:48:10 PM:         ],
11:48:10 PM:         [
11:48:10 PM:             "https://tests.wikijob.co.uk/free-verbal-test",
11:48:10 PM:             "\\bFree Verbal Reasoning Test\\b|\\bFree Verbal Tests\\b|\\bFree Verbal Test\\b"
11:48:10 PM:         ],
11:48:10 PM:         [
11:48:10 PM:             "https://tests.wikijob.co.uk/thinking-skills-assessment",
11:48:10 PM:             "\\bthinking skills assessment\\b"
11:48:10 PM:         ],
11:48:10 PM:         [
11:48:10 PM:             "https://tests.wikijob.co.uk/korn-ferry-talent-q",
11:48:10 PM:             "\\btalent q\\b"
11:48:10 PM:         ],
11:48:10 PM:         [
11:48:10 PM:             "https://l.wikijob.co.uk/flexjobs-interview",
11:48:10 PM:             "\\binterview\\b"
11:48:10 PM:         ],
11:48:11 PM:         [
11:48:11 PM:             "https://tests.wikijob.co.uk/isee-middle-level",
11:48:11 PM:             "\\bmiddle-level ISEE test\\b"
11:48:11 PM:         ],
11:48:11 PM:         [
11:48:11 PM:             "https://tests.wikijob.co.uk/hsbc-assessment",
11:48:11 PM:             "\\bHSBC\\b"
11:48:11 PM:         ],
11:48:11 PM:         [
11:48:11 PM:             "https://tests.wikijob.co.uk/kpmg",
11:48:11 PM:             "\\bKPMG\\b"
11:48:11 PM:         ],
11:48:11 PM:         [
11:48:11 PM:             "https://l.wikijob.co.uk/postal-exam-477",
11:48:11 PM:             "\\bUSPS 477 exam\\b|\\bUSPS 477 test\\b"
11:48:11 PM:         ],
11:48:11 PM:         [
11:48:11 PM:             "https://tests.wikijob.co.uk/ucat",
11:48:11 PM:             "\\bUniversity Clinical Aptitude Test\\b|\\bUCAT\\b"
11:48:11 PM:         ],
11:48:11 PM:         [
11:48:11 PM:             "https://tests.wikijob.co.uk/inductive-link",
11:48:11 PM:             "\\binductive reasoning\\b|\\binductive\\b"
11:48:12 PM:         ],
11:48:12 PM:         [
11:48:12 PM:             "https://tests.wikijob.co.uk/ccat-check-out",
11:48:12 PM:             "\\bCriteria Cognitive Aptitude Test\\b|\\bCCAT Test\\b|\\bCCAT\\b"
11:48:12 PM:         ],
11:48:12 PM:         [
11:48:12 PM:             "https://tests.wikijob.co.uk/korn-ferry-leadership-assessment",
11:48:12 PM:             "\\bKF Leadership assessment\\b|\\bKorn Ferry leadership\\b"
11:48:12 PM:         ],
11:48:12 PM:         [
11:48:12 PM:             "https://tests.wikijob.co.uk/korn-ferry",
11:48:12 PM:             "\\bKorn Ferry\\b"
11:48:12 PM:         ],
11:48:12 PM:         [
11:48:12 PM:             "https://tests.wikijob.co.uk/swift-executive",
11:48:12 PM:             "\\bSwift Executive Test\\b|\\bSwift Executive\\b"
11:48:12 PM:         ],
11:48:12 PM:         [
11:48:12 PM:             "https://tests.wikijob.co.uk/numerical-link",
11:48:12 PM:             "\\bnumerical reasoning\\b|\\bnumerical\\b"
11:48:12 PM:         ],
11:48:12 PM:         [
11:48:12 PM:             "https://tests.wikijob.co.uk/numerical-test",
11:48:12 PM:             "\\bNumerical\\b"
11:48:12 PM:         ],
11:48:12 PM:         [
11:48:13 PM:             "https://tests.wikijob.co.uk/shl-general-ability",
11:48:13 PM:             "\\bSHL General Ability Test\\b"
11:48:13 PM:         ],
11:48:13 PM:         [
11:48:13 PM:             "https://tests.wikijob.co.uk/map-test",
11:48:13 PM:             "\\bMeasures of Academic Progress Test\\b|\\bMAP test\\b|\\bMAP Test\\b"
11:48:13 PM:         ],
11:48:13 PM:         [
11:48:13 PM:             "https://l.wikijob.co.uk/ofx",
11:48:13 PM:             "\\bOFX\\b"
11:48:13 PM:         ],
11:48:13 PM:         [
11:48:13 PM:             "https://tests.wikijob.co.uk/error-checking-tests",
11:48:13 PM:             "\\berror checking tests\\b|\\berror checking test\\b"
11:48:13 PM:         ],
11:48:13 PM:         [
11:48:13 PM:             "https://tests.wikijob.co.uk/freshfield",
11:48:13 PM:             "\\bFreshfields\\b"
11:48:13 PM:         ],
11:48:13 PM:         [
11:48:13 PM:             "https://tests.wikijob.co.uk/hbri",
11:48:13 PM:             "\\bHBRI\\b"
11:48:13 PM:         ],
11:48:13 PM:         [
11:48:13 PM:             "https://tests.wikijob.co.uk/hbri-test",
11:48:14 PM:             "\\bHBRI\\b"
11:48:14 PM:         ],
11:48:14 PM:         [
11:48:14 PM:             "https://tests.wikijob.co.uk/shl",
11:48:14 PM:             "\\bSHL test\\b|\\bSHL\\b"
11:48:14 PM:         ],
11:48:14 PM:         [
11:48:14 PM:             "https://tests.wikijob.co.uk/numerical-ability",
11:48:14 PM:             "\\bnumerical ability test\\b|\\bnumerical ability\\b"
11:48:14 PM:         ],
11:48:14 PM:         [
11:48:14 PM:             "https://tests.wikijob.co.uk/verbal-ability",
11:48:14 PM:             "\\bverbal ability tests\\b|\\bverbal ability test\\b|\\bVerbal Ability\\b"
11:48:14 PM:         ],
11:48:14 PM:         [
11:48:14 PM:             "https://tests.wikijob.co.uk/aon-test",
11:48:14 PM:             "\\bAon G.A.T.E Assessment Test\\b|\\bAon G.A.T.E\\b|\\bAonTest\\b"
11:48:14 PM:         ],
11:48:14 PM:         [
11:48:14 PM:             "https://linkly.wikijob.co.uk/xtb-fx-broker",
11:48:14 PM:             "\\bXTB\\b"
11:48:14 PM:         ],
11:48:14 PM:         [
11:48:14 PM:             "https://tests.wikijob.co.uk/thomas-ppa",
11:48:14 PM:             "\\bThomas PPA\\b|\\bPPA test\\b|\\bPPA\\b"
11:48:15 PM:         ],
11:48:15 PM:         [
11:48:15 PM:             "https://tests.wikijob.co.uk/gia-test",
11:48:15 PM:             "\\bThomas International\\b|\\bGIA\\b"
11:48:15 PM:         ],
11:48:15 PM:         [
11:48:15 PM:             "https://tests.wikijob.co.uk/staar",
11:48:15 PM:             "\\bState of Texas Assessments of Academic Readiness\\b|\\bSTAAR \\b"
11:48:15 PM:         ],
11:48:15 PM:         [
11:48:15 PM:             "https://tests.wikijob.co.uk/cogat",
11:48:15 PM:             "\\bCogAT\\b"
11:48:15 PM:         ],
11:48:15 PM:         [
11:48:15 PM:             "https://tests.wikijob.co.uk/olsat",
11:48:15 PM:             "\\bOtis-Lennon School Ability Test\\b|\\bOLSAT\\b"
11:48:15 PM:         ],
11:48:15 PM:         [
11:48:15 PM:             "https://tests.wikijob.co.uk/ati-teas",
11:48:15 PM:             "\\bAssessment Technologies Institute\\b|\\bTest of Essential Academic Skills\\b|\\bATI TEAS\\b"
11:48:15 PM:         ],
11:48:15 PM:         [
11:48:15 PM:             "https://tests.wikijob.co.uk/isee",
11:48:16 PM:             "\\bIndependent School Entrance Examination\\b|\\bISEE\\b"
11:48:16 PM:         ],
11:48:16 PM:         [
11:48:16 PM:             "https://tests.wikijob.co.uk/nln-pax",
11:48:16 PM:             "\\bNLN PAX\\b"
11:48:16 PM:         ],
11:48:16 PM:         [
11:48:16 PM:             "https://tests.wikijob.co.uk/ssat",
11:48:16 PM:             "\\bSecondary School Admissions Test\\b|\\bSSAT\\b"
11:48:16 PM:         ],
11:48:16 PM:         [
11:48:16 PM:             "https://tests.wikijob.co.uk/scat",
11:48:16 PM:             "\\bSchool and College Ability Test\\b|\\bSCAT\\b"
11:48:16 PM:         ],
11:48:16 PM:         [
11:48:16 PM:             "https://tests.wikijob.co.uk/nnat",
11:48:16 PM:             "\\bNaglieri Nonverbal Ability Test\\b|\\bNNAT\\b"
11:48:16 PM:         ],
11:48:16 PM:         [
11:48:16 PM:             "https://tests.wikijob.co.uk/ccat-grade-3",
11:48:16 PM:             "\\bCCAT Grade 3 sections\\b|\\bCCAT grade 3 test\\b"
11:48:16 PM:         ],
11:48:16 PM:         [
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1556030944-technical-interview.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1558039609-associate-law-firm.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1575551214-book-shelves-book-stack-bookcase-books-207662.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1565003149-adult-2398561640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1603239380-talent-q-numerical-test-explanation1.png?auto=&dpr=0.05&fm=png&q=30&w=477 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1603239368-question-2-talent-q-numerical-test.png?auto=&dpr=0.04&fm=png&q=30&w=630 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1603239045-question-1-talent-q-numerical-test.png?auto=&dpr=0.04&fm=png&q=30&w=652 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1603239700-talent-q-numerical-test-explanation3.png?auto=&dpr=0.03&fm=png&q=30&w=534 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1603239880-question-4-talent-q-numerical-test.png?auto=&dpr=0.04&fm=png&q=30&w=572 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1564697918-brain-2062057640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1603240157-question-5-talent-q-numerical-test.png?auto=&dpr=0.03&fm=png&q=30&w=685 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1565003772-evaluation-1516644640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1603239617-question-3-talent-q-numerical-test.png?auto=&dpr=0.04&fm=png&q=30&w=630 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1603239375-question-2-5-talent-q-numerical-test.png?auto=&dpr=0.04&fm=png&q=30&w=501 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1544633111-cog-wheels-2125169640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1558092385-lady-justice-2388500640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1556030944-technical-interview.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1558039609-associate-law-firm.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1575917660-gray-magnifying-glass-and-eyeglasses-on-top-of-open-book-3109168.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1571865638-bank-banking-change-36104.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1550491116-situational-interview-1.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1575917657-bookcase-books-bookshop-bookstore-220326.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1550491136-situational-interview-2.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1572465688-adult-beautiful-business-attire-2422280.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1571865686-city-of-london-4481399640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1580904479-virgin-759376640resize.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1580991963-learning-1782430640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1582044823-fish-759384640resize.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1582044996-woman-wearing-white-collared-shirt-standing-near-brown-easel-374767.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:05 PM: Error downloading https://www.datocms-assets.com/7756/1582032117-man-in-suit-jacket-standing-beside-projector-screen-2173508.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1582032117-man-in-suit-jacket-standing-beside-projector-screen-2173508.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1571865686-city-of-london-4481399640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1572465688-adult-beautiful-business-attire-2422280.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1582491339-twins-759375640resize.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1571697053-anger-angry-anxiety-897817.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1567718695-adult-agent-approval-684385.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1582491583-drinks-1283608640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1571697044-adult-blur-books-261909.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1564498350-shell-logo.gif?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1554731774-agreement-3974293640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1563444508-abandoned-brand-classic-284288.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1554733992-lemon-3303842640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1564501997-oil-rig-2191711640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1620214905-how-to-solve-percentage-problems-08.png?auto=&dpr=0.01&fm=png&q=30&w=6667 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1620214930-how-to-solve-percentage-problems-09.png?auto=&dpr=0.01&fm=png&q=30&w=6668 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1547043356-stopwatch-2624277640-1.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:06 PM: Error downloading https://www.datocms-assets.com/7756/1546553466-pexels-photo-268460.jpeg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:07 PM: Error downloading https://www.datocms-assets.com/7756/1582491583-drinks-1283608640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:07 PM: Error downloading https://www.datocms-assets.com/7756/1566309901-dollar-499481640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:07 PM: Error downloading https://www.datocms-assets.com/7756/1580675468-astrology-993127640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:07 PM: Error downloading https://www.datocms-assets.com/7756/1566216833-money-2696219640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:07 PM: Error downloading https://www.datocms-assets.com/7756/1564498350-shell-logo.gif?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:07 PM: Error downloading https://www.datocms-assets.com/7756/1603245599-shl-practice-test-question-explanation-5.png?auto=&dpr=0.09&fm=png&q=30&w=245 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:07 PM: Error downloading https://www.datocms-assets.com/7756/1563444508-abandoned-brand-classic-284288.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:07 PM: Error downloading https://www.datocms-assets.com/7756/1564501997-oil-rig-2191711640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:07 PM: Error downloading https://www.datocms-assets.com/7756/1573051442-brain-2062048640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:07 PM: Error downloading https://www.datocms-assets.com/7756/1585318979-red-and-yellow-stop-sticker-1749900resize.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:07 PM: Error downloading https://www.datocms-assets.com/7756/1630356579-concentration2answer.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:07 PM: Error downloading https://www.datocms-assets.com/7756/1630355409-consentrationanswer.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:07 PM: Error downloading https://www.datocms-assets.com/7756/1630359339-concentrationtest3answer.jpg?auto=format&lqip=blurhash to
11:47:43 PM:         [
11:47:43 PM:             "https://tests.wikijob.co.uk/mmpi-link",
11:47:43 PM:             "\\bMMPI\\b"
11:47:43 PM:         ],
11:47:43 PM:         [
11:47:43 PM:             "https://tests.wikijob.co.uk/caliper-link",
11:47:43 PM:             "\\bCaliper\\b"
11:47:43 PM:         ],
11:47:43 PM:         [
11:47:43 PM:             "https://tests.wikijob.co.uk/barb-test",
11:47:43 PM:             "\\bBritish Army Cognitive Test\\b|\\bArmy Cognitive Test\\b|\\bBARB\\b"
11:47:43 PM:         ],
11:47:43 PM:         [
11:47:43 PM:             "https://tests.wikijob.co.uk/birkman",
11:47:43 PM:             "\\bBirkman tests\\b|\\bBirkman test\\b"
11:47:43 PM:         ],
11:47:43 PM:         [
11:47:43 PM:             "https://tests.wikijob.co.uk/cognitive-link",
11:47:43 PM:             "\\bcognitive ability\\b|\\bcognitive test\\b|\\bCAT\\b"
11:47:44 PM:         ],
11:47:44 PM:         [
11:47:44 PM:             "https://tests.wikijob.co.uk/bksb-test",
11:47:44 PM:             "\\bBKSB initial assessment\\b|\\bBKSB Test\\b|\\bBKSB\\b"
11:47:44 PM:         ],
11:47:44 PM:         [
11:47:44 PM:             "https://tests.wikijob.co.uk/in-tray-test",
11:47:44 PM:             "\\bin-tray\\b|\\bintray\\b"
11:47:44 PM:         ],
11:47:44 PM:         [
11:47:44 PM:             "https://tests.wikijob.co.uk/revelian-link",
11:47:44 PM:             "\\brevelian\\b|\\bRCAT\\b"
11:47:44 PM:         ],
11:47:44 PM:         [
11:47:44 PM:             "https://tests.wikijob.co.uk/criticall-link",
11:47:44 PM:             "\\bCriticall Tests\\b|\\bCriticall Test\\b"
11:47:44 PM:         ],
11:47:44 PM:         [
11:47:44 PM:             "https://tests.wikijob.co.uk/cast-test",
11:47:44 PM:             "\\bCAST\\b"
11:47:44 PM:         ],
11:47:44 PM:         [
11:47:44 PM:             "https://tests.wikijob.co.uk/workkeys",
11:47:44 PM:             "\\bWorkKeys\\b"
11:47:44 PM:         ],
11:47:44 PM:         [
11:47:45 PM:             "https://tests.wikijob.co.uk/eei-tests",
11:47:45 PM:             "\\bEEI\\b"
11:47:45 PM:         ],
11:47:45 PM:         [
11:47:45 PM:             "https://tests.wikijob.co.uk/capp-link",
11:47:45 PM:             "\\bCAPP tests\\b|\\bCAPP test\\b"
11:47:45 PM:         ],
11:47:45 PM:         [
11:47:45 PM:             "https://tests.wikijob.co.uk/qts-test",
11:47:45 PM:             "\\bQTS Numeracy\\b"
11:47:45 PM:         ],
11:47:45 PM:         [
11:47:45 PM:             "https://tests.wikijob.co.uk/disc",
11:47:45 PM:             "\\bDISC\\b"
11:47:45 PM:         ],
11:47:45 PM:         [
11:47:45 PM:             "https://tests.wikijob.co.uk/matrigma-prep",
11:47:45 PM:             "\\bMatrigma\\b"
11:47:45 PM:         ],
11:47:45 PM:         [
11:47:45 PM:             "https://tests.wikijob.co.uk/saville-assessment",
11:47:45 PM:             "\\bsaville assessment\\b"
11:47:45 PM:         ],
11:47:45 PM:         [
11:47:45 PM:             "https://tests.wikijob.co.uk/diagrammatic-practice-test",
11:47:46 PM:             "\\bFree Diagrammatic Practice Test\\b|\\bDiagrammatic Practice Test\\b"
11:47:46 PM:         ],
11:47:46 PM:         [
11:47:46 PM:             "https://tests.wikijob.co.uk/merrill-lynch-prep",
11:47:46 PM:             "\\bBank of America\\b|\\bMerrill Lynch\\b"
11:47:46 PM:         ],
11:47:46 PM:         [
11:47:46 PM:             "https://tests.wikijob.co.uk/act-asset-test",
11:47:46 PM:             "\\bACT ASSET test\\b|\\bACT ASSET Exam\\b|\\bASSET test\\b|\\bASSET Exam\\b|\\bACT exam\\b|\\bACT test\\b"
11:47:46 PM:         ],
11:47:46 PM:         [
11:47:46 PM:             "https://tests.wikijob.co.uk/asda-assessment",
11:47:46 PM:             "\\bASDA\\b"
11:47:46 PM:         ],
11:47:46 PM:         [
11:47:46 PM:             "https://tests.wikijob.co.uk/airbus-assessment-center",
11:47:46 PM:             "\\bAirbus\\b"
11:47:46 PM:         ],
11:47:46 PM:         [
11:47:46 PM:             "https://tests.wikijob.co.uk/factset-interviw",
11:47:46 PM:             "\\bFactset Interview\\b|\\bFactset\\b"
11:47:46 PM:         ],
11:47:46 PM:         [
11:47:46 PM:             "https://tests.wikijob.co.uk/asvab",
11:47:47 PM:             "\\bArmed Services Vocational Aptitude Battery\\b|\\bASVAB\\b"
11:47:47 PM:         ],
11:47:47 PM:         [
11:47:47 PM:             "https://tests.wikijob.co.uk/qts",
11:47:47 PM:             "\\bQualified Teacher Status\\b|\\bQTS Professional Skills\\b|\\bQTS Literacy\\b|\\bQTS Test\\b|\\bQTS\\b"
11:47:47 PM:         ],
11:47:47 PM:         [
11:47:47 PM:             "https://tests.wikijob.co.uk/amazon-assessment",
11:47:47 PM:             "\\bamazon assessment test\\b|\\bamazon assessment\\b"
11:47:47 PM:         ],
11:47:47 PM:         [
11:47:47 PM:             "https://tests.wikijob.co.uk/rolls-royce-assessment",
11:47:47 PM:             "\\bRolls-Royce\\b"
11:47:47 PM:         ],
11:47:47 PM:         [
11:47:47 PM:             "https://tests.wikijob.co.uk/usps-exams",
11:47:47 PM:             "\\bUSPS job\\b"
11:47:47 PM:         ],
11:47:47 PM:         [
11:47:47 PM:             "https://tests.wikijob.co.uk/blabkrock-assessment-center",
11:47:47 PM:             "\\bBlackRock\\b"
11:47:47 PM:         ],
11:47:47 PM:         [
11:47:47 PM:             "https://tests.wikijob.co.uk/raf-practice-link",
11:47:48 PM:             "\\bRAF Aptitude Test\\b|\\bRAF\\b"
11:47:48 PM:         ],
11:47:48 PM:         [
11:47:48 PM:             "https://tests.wikijob.co.uk/air-control",
11:47:48 PM:             "\\bNATS\\b|\\bATC\\b"
11:47:48 PM:         ],
11:47:48 PM:         [
11:47:48 PM:             "https://tests.wikijob.co.uk/standard-chartered-assessment",
11:47:48 PM:             "\\bStandard Chartered\\b"
11:47:48 PM:         ],
11:47:48 PM:         [
11:47:48 PM:             "https://tests.wikijob.co.uk/dhl",
11:47:48 PM:             "\\bDHL\\b"
11:47:48 PM:         ],
11:47:48 PM:         [
11:47:48 PM:             "https://tests.wikijob.co.uk/pg-link",
11:47:48 PM:             "\\bP&G online assessment\\b|\\bProcter & Gamble\\b"
11:47:48 PM:         ],
11:47:48 PM:         [
11:47:48 PM:             "https://tests.wikijob.co.uk/national-grid-assessment",
11:47:48 PM:             "\\bNational Grid\\b"
11:47:48 PM:         ],
11:47:48 PM:         [
11:47:49 PM:             "https://tests.wikijob.co.uk/free-watson-glaser",
11:47:49 PM:             "\\bfree watson glaser tests\\b|\\bfree watson glaser test\\b"
11:47:49 PM:         ],
11:47:49 PM:         [
11:47:49 PM:             "https://tests.wikijob.co.uk/written-exercises",
11:47:49 PM:             "\\bWritten exercises\\b"
11:47:49 PM:         ],
11:47:49 PM:         [
11:47:49 PM:             "https://tests.wikijob.co.uk/jtp-link",
11:47:49 PM:             "\\baptitude tests\\b|\\baptitude test\\b|\\bjob test prep\\b|\\bJobTestPrep\\b|\\bJobTestPrep\\b|\\bjobtestprep\\b|\\bjtp\\b"
11:47:49 PM:         ],
11:47:49 PM:         [
11:47:49 PM:             "https://tests.wikijob.co.uk/ey-interview",
11:47:49 PM:             "\\bEY interview\\b|\\bEY\\b"
11:47:49 PM:         ],
11:47:49 PM:         [
11:47:49 PM:             "https://tests.wikijob.co.uk/thames-water-assessment",
11:47:49 PM:             "\\bThames Water\\b"
11:47:49 PM:         ],
11:47:49 PM:         [
11:47:49 PM:             "https://tests.wikijob.co.uk/hmrc",
11:47:49 PM:             "\\bSantander\\b"
11:47:49 PM:         ],
11:47:49 PM:         [
11:47:50 PM:             "https://tests.wikijob.co.uk/santander-assessment",
11:47:50 PM:             "\\bSantander\\b"
11:47:50 PM:         ],
11:47:50 PM:         [
11:47:50 PM:             "https://tests.wikijob.co.uk/network-rail-assessment",
11:47:50 PM:             "\\bNetwork Rail\\b"
11:47:50 PM:         ],
11:47:50 PM:         [
11:47:50 PM:             "https://tests.wikijob.co.uk/accenture-application",
11:47:50 PM:             "\\bAccenture\\b"
11:47:50 PM:         ],
11:47:50 PM:         [
11:47:50 PM:             "https://tests.wikijob.co.uk/rsm",
11:47:50 PM:             "\\bRSM\\b"
11:47:50 PM:         ],
11:47:50 PM:         [
11:47:50 PM:             "https://tests.wikijob.co.uk/exxonmobil-assessment",
11:47:50 PM:             "\\bExxonMobil\\b"
11:47:50 PM:         ],
11:47:50 PM:         [
11:47:50 PM:             "https://l.wikijob.co.uk/maxcrowdfund",
11:47:50 PM:             "\\bmaxcrowdfund.com\\b"
11:47:50 PM:         ],
11:47:51 PM:         [
11:47:51 PM:             "https://tests.wikijob.co.uk/mckinsey-Test",
11:47:51 PM:             "\\bMcKinsey\\b"
11:47:51 PM:         ],
11:47:51 PM:         [
11:47:51 PM:             "https://tests.wikijob.co.uk/deutsche-bank-interview",
11:47:51 PM:             "\\bDeutsche Bank\\b"
11:47:51 PM:         ],
11:47:51 PM:         [
11:47:51 PM:             "https://tests.wikijob.co.uk/astra-zeneca-assessment",
11:47:51 PM:             "\\b Astra Zeneca application\\b|\\bastra zeneca\\b"
11:47:51 PM:         ],
11:47:51 PM:         [
11:47:51 PM:             "https://tests.wikijob.co.uk/hsbc-assessment-center",
11:47:51 PM:             "\\bHSBC\\b"
11:47:51 PM:         ],
11:47:51 PM:         [
11:47:51 PM:             "https://tests.wikijob.co.uk/clifford-chance",
11:47:51 PM:             "\\bClifford\\b"
11:47:51 PM:         ],
11:47:51 PM:         [
11:47:51 PM:             "https://tests.wikijob.co.uk/jtp-main-page",
11:47:51 PM:             "\\baptitude tests\\b|\\baptitude test\\b"
11:47:52 PM:         ],
11:47:52 PM:         [
11:47:52 PM:             "https://tests.wikijob.co.uk/predictive-index-tests",
11:47:52 PM:             "\\bPI Behavioral Assessment\\b|\\bPredictive Index\\b"
11:47:52 PM:         ],
11:47:52 PM:         [
11:47:52 PM:             "https://tests.wikijob.co.uk/pymetrics",
11:47:52 PM:             "\\bpymetrics test\\b|\\bPymetrics\\b"
11:47:52 PM:         ],
11:47:52 PM:         [
11:47:52 PM:             "https://tests.wikijob.co.uk/schroders-prep",
11:47:52 PM:             "\\bSchroders\\b"
11:47:52 PM:         ],
11:47:52 PM:         [
11:47:52 PM:             "https://tests.wikijob.co.uk/john-lewis-assessment",
11:47:52 PM:             "\\bJohn Lewis\\b"
11:47:52 PM:         ],
11:47:52 PM:         [
11:47:52 PM:             "https://tests.wikijob.co.uk/personality-link",
11:47:52 PM:             "\\bpersonality tests\\b|\\bpersonality test\\b"
11:47:52 PM:         ],
11:47:52 PM:         [
11:47:52 PM:             "https://tests.wikijob.co.uk/morgan-stanley-assessment-center",
11:47:53 PM:             "\\bMorgan Stanley\\b"
11:47:53 PM:         ],
11:47:53 PM:         [
11:47:53 PM:             "https://tests.wikijob.co.uk/herbert-assessment",
11:47:53 PM:             "\\bHerbert Smith Freehills \\b|\\bHSF\\b"
11:47:53 PM:         ],
11:47:53 PM:         [
11:47:53 PM:             "https://tests.wikijob.co.uk/uniliver-assessment",
11:47:53 PM:             "\\bUnilever\\b"
11:47:53 PM:         ],
11:47:53 PM:         [
11:47:53 PM:             "https://tests.wikijob.co.uk/ubs",
11:47:53 PM:             "\\bUBS\\b"
11:47:53 PM:         ],
11:47:53 PM:         [
11:47:53 PM:             "https://tests.wikijob.co.uk/aptitude-link",
11:47:53 PM:             "\\bpractice aptitude tests\\b|\\bpractice aptitude test\\b|\\baptitude tests\\b|\\baptitude test\\b"
11:47:53 PM:         ],
11:47:53 PM:         [
11:47:53 PM:             "https://tests.wikijob.co.uk/lloyds-assessment",
11:47:53 PM:             "\\bLloyds Bank\\b"
11:47:53 PM:         ],
11:47:53 PM:         [
11:47:53 PM:             "https://tests.wikijob.co.uk/sky-assessment",
11:47:53 PM:             "\\bSky\\b"
11:47:54 PM:         ],
11:47:54 PM:         [
11:47:54 PM:             "https://l.wikijob.co.uk/crowdwithus",
11:47:54 PM:             "\\bcrowdwithus.london\\b"
11:47:54 PM:         ],
11:47:54 PM:         [
11:47:54 PM:             "https://tests.wikijob.co.uk/kf-elements",
11:47:54 PM:             "\\bKF Elements Talent Q\\b|\\bKorn Ferry Elements\\b"
11:47:54 PM:         ],
11:47:54 PM:         [
11:47:54 PM:             "https://tests.wikijob.co.uk/civil-service",
11:47:54 PM:             "\\bcivil service\\b"
11:47:54 PM:         ],
11:47:54 PM:         [
11:47:54 PM:             "https://l.wikijob.co.uk/planethomeinvest",
11:47:54 PM:             "\\bhttps://planethome-invest.com/\\b"
11:47:54 PM:         ],
11:47:54 PM:         [
11:47:54 PM:             "https://tests.wikijob.co.uk/sova-assessment",
11:47:54 PM:             "\\bSova Assessment\\b|\\bSova\\b"
11:47:54 PM:         ],
11:47:54 PM:         [
11:47:54 PM:             "https://tests.wikijob.co.uk/lnat",
11:47:54 PM:             "\\bLNAT\\b"
11:47:55 PM:         ],
11:47:55 PM:         [
11:47:55 PM:             "https://tests.wikijob.co.uk/cut-e",
11:47:55 PM:             "\\bCut-e\\b"
11:47:55 PM:         ],
11:47:55 PM:         [
11:47:55 PM:             "https://tests.wikijob.co.uk/mcquaig-mental-agility",
11:47:55 PM:             "\\bMcQuaig Mental Agility\\b"
11:47:55 PM:         ],
11:47:55 PM:         [
11:47:55 PM:             "https://tests.wikijob.co.uk/iegat",
11:47:55 PM:             "\\bieGAT Test\\b|\\bieGAT\\b"
11:47:55 PM:         ],
11:47:55 PM:         [
11:47:55 PM:             "https://tests.wikijob.co.uk/pwc-interview",
11:47:55 PM:             "\\bPwC graduate application process\\b"
11:47:55 PM:         ],
11:47:55 PM:         [
11:47:55 PM:             "https://tests.wikijob.co.uk/mcquaig-word-survey",
11:47:55 PM:             "\\bMcQuaig Word Survey\\b"
11:47:55 PM:         ],
11:47:55 PM:         [
11:47:55 PM:             "https://tests.wikijob.co.uk/neo-personality",
11:47:55 PM:             "\\bNeo Personality Inventory Test\\b"
11:47:56 PM:         ],
11:47:56 PM:         [
11:47:56 PM:             "https://tests.wikijob.co.uk/deloitte-interview",
11:47:56 PM:             "\\bDeloitte Interview\\b"
11:47:56 PM:         ],
11:47:56 PM:         [
11:47:56 PM:             "https://tests.wikijob.co.uk/spatial-aptitude",
11:47:56 PM:             "\\bspatial aptitude\\b|\\bspatial\\b"
11:47:56 PM:         ],
11:47:56 PM:         [
11:47:56 PM:             "https://l.wikijob.co.uk/binance",
11:47:56 PM:             "\\bBinance\\b"
11:47:56 PM:         ],
11:47:56 PM:         [
11:47:56 PM:             "https://tests.wikijob.co.uk/online-tests",
11:47:56 PM:             "\\bOnline Tests\\b"
11:47:56 PM:         ],
11:47:56 PM:         [
11:47:56 PM:             "https://tests.wikijob.co.uk/bennett-test",
11:47:56 PM:             "\\bBennett Mechanical Comprehension Test\\b|\\bmechanical comprehension\\b|\\bBennett Test\\b|\\bBMCT Test\\b|\\bBennett\\b|\\bBMCT\\b"
11:47:56 PM:         ],
11:47:56 PM:         [
11:47:56 PM:             "https://tests.wikijob.co.uk/wonderlic-link",
11:47:56 PM:             "\\bWonderlic\\b"
11:47:56 PM:         ],
11:47:57 PM:         [
11:47:57 PM:             "https://tests.wikijob.co.uk/psychometric-tests",
11:47:57 PM:             "\\bpsychometric tests\\b|\\bpsychometric test\\b"
11:47:57 PM:         ],
11:47:57 PM:         [
11:47:57 PM:             "https://tests.wikijob.co.uk/online-tests-link",
11:47:57 PM:             "\\bonline tests\\b"
11:47:57 PM:         ],
11:47:57 PM:         [
11:47:57 PM:             "https://tests.wikijob.co.uk/capital-one-assessment",
11:47:57 PM:             "\\bCapital One Assessment Test\\b|\\bCapital One Assessment\\b|\\bCapital One\\b"
11:47:57 PM:         ],
11:47:57 PM:         [
11:47:57 PM:             "https://tests.wikijob.co.uk/assessment-centre",
11:47:57 PM:             "\\bassessment centres\\b|\\bassessment centre\\b"
11:47:57 PM:         ],
11:47:57 PM:         [
11:47:57 PM:             "https://tests.wikijob.co.uk/saville-wave-test",
11:47:57 PM:             "\\bSaville Wave Tests\\b|\\bSaville Wave Test\\b"
11:47:57 PM:         ],
11:47:57 PM:         [
11:47:57 PM:             "https://tests.wikijob.co.uk/cubiks",
11:47:57 PM:             "\\bCubiks tests\\b|\\bCubiks test\\b"
11:47:57 PM:         ],
11:47:57 PM:         [
11:47:58 PM:             "https://tests.wikijob.co.uk/mercer-assessment-centre",
11:47:58 PM:             "\\bMercer\\b"
11:47:58 PM:         ],
11:47:58 PM:         [
11:47:58 PM:             "https://tests.wikijob.co.uk/mechanical-nav",
11:47:58 PM:             "\\bmechanical reasoning test\\b|\\bmechanical reasoning\\b|\\bmechanical\\b"
11:47:58 PM:         ],
11:47:58 PM:         [
11:47:58 PM:             "https://tests.wikijob.co.uk/practice-tests",
11:47:58 PM:             "\\bpractice tests\\b|\\bpractice test\\b"
11:47:58 PM:         ],
11:47:58 PM:         [
11:47:58 PM:             "https://tests.wikijob.co.uk/kenexa-tests",
11:47:58 PM:             "\\bkenexa\\b"
11:47:58 PM:         ],
11:47:58 PM:         [
11:47:58 PM:             "https://tests.wikijob.co.uk/postal-exam-955",
11:47:58 PM:             "\\bPostal Exam 955\\b|\\bUSPS 955 exam\\b|\\bUSPS 955\\b|\\bExam 955\\b"
11:47:58 PM:         ],
11:47:58 PM:         [
11:47:58 PM:             "https://tests.wikijob.co.uk/lek-assessment",
11:47:58 PM:             "\\bLEK\\b"
11:47:58 PM:         ],
11:47:58 PM:         [
11:47:59 PM:             "https://tests.wikijob.co.uk/skype-interview-prep",
11:47:59 PM:             "\\bSkype\\b"
11:47:59 PM:         ],
11:47:59 PM:         [
11:47:59 PM:             "https://tests.wikijob.co.uk/analytical",
11:47:59 PM:             "\\bAnalytical Reasoning\\b"
11:47:59 PM:         ],
11:47:59 PM:         [
11:47:59 PM:             "https://tests.wikijob.co.uk/eiat",
11:47:59 PM:             "\\bThe Elevator Industry Aptitude Test (EIAT)\\b|\\bThe Elevator Industry Aptitude Test\\b|\\bEIAT\\b"
11:47:59 PM:         ],
11:47:59 PM:         [
11:47:59 PM:             "https://tests.wikijob.co.uk/rbc",
11:47:59 PM:             "\\bRBC\\b"
11:47:59 PM:         ],
11:47:59 PM:         [
11:47:59 PM:             "https://tests.wikijob.co.uk/postal-exam-474",
11:47:59 PM:             "\\bUSPS 474 assessment\\b|\\bpostal exam 474\\b|\\b Exam MC 474\\b|\\bUSPS 474\\b|\\bexam 474\\b|\\b MC 474\\b"
11:47:59 PM:         ],
11:47:59 PM:         [
11:47:59 PM:             "https://tests.wikijob.co.uk/fbi-link",
11:47:59 PM:             "\\bFBI Phase 1 Test\\b"
11:47:59 PM:         ],
11:47:59 PM:         [
11:48:00 PM:             "https://tests.wikijob.co.uk/microsoft-office",
11:48:00 PM:             "\\bMicrosoft Office Test\\b|\\bMicrosoft Office\\b|\\bMicrosoft Word\\b"
11:48:00 PM:         ],
11:48:00 PM:         [
11:48:00 PM:             "https://l.wikijob.co.uk/1password",
11:48:00 PM:             "\\b1Password\\b"
11:48:00 PM:         ],
11:48:00 PM:         [
11:48:00 PM:             "https://l.wikijob.co.uk/premier-tefl",
11:48:00 PM:             "\\bPremier TEFL\\b"
11:48:00 PM:         ],
11:48:00 PM:         [
11:48:00 PM:             "https://tests.wikijob.co.uk/bus-driver-assessment",
11:48:00 PM:             "\\bbus driver assessment\\b|\\bbus driver test\\b"
11:48:00 PM:         ],
11:48:00 PM:         [
11:48:00 PM:             "https://tests.wikijob.co.uk/berke-assessment",
11:48:00 PM:             "\\bBerke Assessment Test\\b|\\bBerke Assessment\\b"
11:48:00 PM:         ],
11:48:00 PM:         [
11:48:00 PM:             "https://tests.wikijob.co.uk/nyc-safety-agent",
11:48:00 PM:             "\\bNYC School Safety Agent Exam\\b|\\bNYC School Safety Agent\\b"
11:48:00 PM:         ],
11:48:00 PM:         [
11:48:00 PM:             "https://tests.wikijob.co.uk/utopia",
11:48:00 PM:             "\\butopia\\b"
11:48:01 PM:         ],
11:48:01 PM:         [
11:48:01 PM:             "https://tests.wikijob.co.uk/ibew-test",
11:48:01 PM:             "\\bIBEW Test\\b"
11:48:01 PM:         ],
11:48:01 PM:         [
11:48:01 PM:             "https://tests.wikijob.co.uk/cat-4",
11:48:01 PM:             "\\bCAT4\\b"
11:48:01 PM:         ],
11:48:01 PM:         [
11:48:01 PM:             "https://tests.wikijob.co.uk/pwc-test",
11:48:01 PM:             "\\bPrice waterhouse Coopers recruitment test\\b|\\bpwc recruitment test\\b|\\bpwc assessment test\\b|\\bpwc assessment\\b|\\bpwc test\\b"
11:48:01 PM:         ],
11:48:01 PM:         [
11:48:01 PM:             "https://tests.wikijob.co.uk/situational-check-out",
11:48:01 PM:             "\\bsituational judgement\\b|\\bSJT\\b"
11:48:01 PM:         ],
11:48:01 PM:         [
11:48:01 PM:             "https://tests.wikijob.co.uk/intray-link",
11:48:01 PM:             "\\bin tray\\b|\\bin-tray\\b|\\be-tray \\b|\\bintray\\b|\\be tray\\b|\\betray\\b"
11:48:01 PM:         ],
11:48:01 PM:         [
11:48:01 PM:             "https://tests.wikijob.co.uk/free-abstract-test",
11:48:01 PM:             "\\bfree abstract tests\\b|\\bfree abstract test\\b"
11:48:01 PM:         ],
11:48:01 PM:         [
11:48:02 PM:             "https://tests.wikijob.co.uk/abstract-check-out",
11:48:02 PM:             "\\babstract reasoning test\\b|\\babstract reasoning\\b|\\babstract\\b"
11:48:02 PM:         ],
11:48:02 PM:         [
11:48:02 PM:             "https://tests.wikijob.co.uk/bank-england-test",
11:48:02 PM:             "\\bbank of England test\\b"
11:48:02 PM:         ],
11:48:02 PM:         [
11:48:02 PM:             "https://tests.wikijob.co.uk/hudson-assessment",
11:48:02 PM:             "\\bHudson\\b"
11:48:02 PM:         ],
11:48:02 PM:         [
11:48:02 PM:             "https://tests.wikijob.co.uk/cabin-crew",
11:48:02 PM:             "\\bcabin crew test\\b"
11:48:02 PM:         ],
11:48:02 PM:         [
11:48:02 PM:             "https://l.wikijob.co.uk/blockchain",
11:48:02 PM:             "\\bBlockchain.com\\b"
11:48:02 PM:         ],
11:48:02 PM:         [
11:48:02 PM:             "https://l.wikijob.co.uk/tradex",
11:48:02 PM:             "\\bTradex\\b"
11:48:02 PM:         ],
11:48:02 PM:         [
11:48:02 PM:             "https://l.wikijob.co.uk/swyftfilings",
11:48:03 PM:             "\\bSwyft Filings\\b"
11:48:03 PM:         ],
11:48:03 PM:         [
11:48:03 PM:             "https://l.wikijob.co.uk/incfile",
11:48:03 PM:             "\\bIncfile\\b"
11:48:03 PM:         ],
11:48:03 PM:         [
11:48:03 PM:             "https://tests.wikijob.co.uk/edf",
11:48:03 PM:             "\\bEDF\\b"
11:48:03 PM:         ],
11:48:03 PM:         [
11:48:03 PM:             "https://tests.wikijob.co.uk/reckitt-benckisError downloading https://www.datocms-assets.com/7756/1573051442-brain-2062048640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
Error downloading https://www.datocms-assets.com/7756/1574086212-brain-3829057640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:03 PM: Error downloading https://www.datocms-assets.com/7756/1586509695-watermelon-icosahedron-r62s-squarespace-com.png?auto=&dpr=0.03&fm=png&q=30&w=876 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:03 PM: Error downloading https://www.datocms-assets.com/7756/1586509818-tracking-link-1.png?auto=&dpr=0.02&fm=png&q=30&w=1000 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:03 PM: Error downloading https://www.datocms-assets.com/7756/1602783772-nums002.png?auto=&dpr=0.09&fm=png&q=30&w=227 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:03 PM: Error downloading https://www.datocms-assets.com/7756/1602783537-nums034.png?auto=&dpr=0.09&fm=png&q=30&w=235 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:03 PM: Error downloading https://www.datocms-assets.com/7756/1602784470-nums074.png?auto=&dpr=0.05&fm=png&q=30&w=415 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:03 PM: Error downloading https://www.datocms-assets.com/7756/1603239880-question-4-talent-q-numerical-test.png?auto=&dpr=0.04&fm=png&q=30&w=572 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:03 PM: Error downloading https://www.datocms-assets.com/7756/1603239380-talent-q-numerical-test-explanation1.png?auto=&dpr=0.05&fm=png&q=30&w=477 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:03 PM: Error downloading https://www.datocms-assets.com/7756/1603239045-question-1-talent-q-numerical-test.png?auto=&dpr=0.04&fm=png&q=30&w=652 to generate blurred placeholder!: The "path" argument must be of type string. Received undefined
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1544633111-cog-wheels-2125169640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:48:04 PM: Error downloading https://www.datocms-assets.com/7756/1558092385-lady-justice-2388500640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:47:16 PM:             "https://tests.wikijob.co.uk/ati-teas",
11:47:16 PM:             "\\bAssessment Technologies Institute\\b|\\bTest of Essential Academic Skills\\b|\\bATI TEAS\\b"
11:47:16 PM:         ],
11:47:16 PM:         [
11:47:16 PM:             "https://tests.wikijob.co.uk/isee",
11:47:16 PM:             "\\bIndependent School Entrance Examination\\b|\\bISEE\\b"
11:47:16 PM:         ],
11:47:16 PM:         [
11:47:16 PM:             "https://tests.wikijob.co.uk/nln-pax",
11:47:16 PM:             "\\bNLN PAX\\b"
11:47:16 PM:         ],
11:47:16 PM:         [
11:47:16 PM:             "https://tests.wikijob.co.uk/ssat",
11:47:16 PM:             "\\bSecondary School Admissions Test\\b|\\bSSAT\\b"
11:47:16 PM:         ],
11:47:16 PM:         [
11:47:16 PM:             "https://tests.wikijob.co.uk/scat",
11:47:16 PM:             "\\bSchool and College Ability Test\\b|\\bSCAT\\b"
11:47:16 PM:         ],
11:47:16 PM:         [
11:47:16 PM:             "https://tests.wikijob.co.uk/nnat",
11:47:16 PM:             "\\bNaglieri Nonverbal Ability Test\\b|\\bNNAT\\b"
11:47:16 PM:         ],
11:47:16 PM:         [
11:47:17 PM:             "https://tests.wikijob.co.uk/ccat-grade-3",
11:47:17 PM:             "\\bCCAT Grade 3 sections\\b|\\bCCAT grade 3 test\\b"
11:47:17 PM:         ],
11:47:17 PM:         [
11:47:17 PM:             "https://tests.wikijob.co.uk/nyc-gifted-talented",
11:47:17 PM:             "\\bNYC Gifted and Talented Test\\b|\\bG&T test\\b"
11:47:17 PM:         ],
11:47:17 PM:         [
11:47:17 PM:             "https://tests.wikijob.co.uk/at-t-assessment",
11:47:17 PM:             "\\bAT&T\\b"
11:47:17 PM:         ],
11:47:17 PM:         [
11:47:17 PM:             "https://tests.wikijob.co.uk/map-5-grade",
11:47:17 PM:             "\\bNWEA 5th Grade\\b|\\bmap grade 5\\b"
11:47:17 PM:         ],
11:47:17 PM:         [
11:47:17 PM:             "https://l.wikijob.co.uk/etoro-trading-course",
11:47:17 PM:             "\\beToro Trading School\\b"
11:47:17 PM:         ],
11:47:17 PM:         [
11:47:17 PM:             "https://l.wikijob.co.uk/etoro",
11:47:17 PM:             "\\betoro\\b"
11:47:17 PM:         ],
11:47:18 PM:         [
11:47:18 PM:             "https://tests.wikijob.co.uk/coinbase",
11:47:18 PM:             "\\bcoinbase\\b"
11:47:18 PM:         ],
11:47:18 PM:         [
11:47:18 PM:             "https://l.wikijob.co.uk/thomas-kralow",
11:47:18 PM:             "\\bThomas Kralow\\b"
11:47:18 PM:         ]
11:47:18 PM:     ],
11:47:18 PM:     "layout": {
11:47:18 PM:         "scrollableLayout": true
11:47:18 PM:     }
11:47:18 PM: }
11:47:18 PM: Error downloading https://www.datocms-assets.com/7756/1574206723-smiley-2979107640.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:47:18 PM: Error downloading https://www.datocms-assets.com/7756/1574207134-man-wearing-military-uniform-and-walking-through-woods-1927974.jpg?auto=format&lqip=blurhash to generate Blurhash placeholder!: The "path" argument must be of type string. Received undefined
11:47:18 PM: warning This query took more than 15s to run — which is unusually long and might indicate you're querying too much or have some unoptimized code:
File path: /opt/build/repo/packages/wikijob/src/templates/aptitude-test.js
11:47:18 PM: URL path: /aptitude-tests/test-providers/practice-shl-tests/shl-numerical-practice
11:47:18 PM: Context: {
11:47:18 PM:     "id": "DatoCmsTest-30030-en",
11:47:18 PM:     "words": [
11:47:18 PM:         [
11:47:18 PM:             "https://tests.wikijob.co.uk/math-assessment-test",
11:47:18 PM:             "\\bMath Assessment Tests\\b"
11:47:18 PM:         ],
11:47:18 PM:         [
11:47:19 PM:             "https://tests.wikijob.co.uk/olsat-nnat-bundle",
11:47:19 PM:             "\\bOLSAT and NNAT bundle\\b|\\bOLSAT NNAT bundle\\b|\\bOLSAT and NNAT\\b|\\bOLSAT & NNAT\\b"
11:47:19 PM:         ],
11:47:19 PM:         [
11:47:19 PM:             "https://l.wikijob.co.uk/thinkmarkets",
11:47:19 PM:             "\\bthinkmarkets\\b"
11:47:19 PM:         ],
11:47:19 PM:         [
11:47:19 PM:             "https://l.wikijob.co.uk/trezor",
11:47:19 PM:             "\\btrezor\\b"
11:47:19 PM:         ],
11:47:19 PM:         [
11:47:19 PM:             "https://l.wikijob.co.uk/coinmama",
11:47:19 PM:             "\\bCoinmama\\b"
11:47:19 PM:         ],
11:47:20 PM:         [
11:47:20 PM:             "https://l.wikijob.co.uk/cex",
11:47:20 PM:             "\\bCEX\\b"
11:47:20 PM:         ],
11:47:20 PM:         [
11:47:20 PM:             "https://l.wikijob.co.uk/3commas",
11:47:20 PM:             "\\b3commas\\b"
11:47:20 PM:         ],
11:47:20 PM:         [
11:47:20 PM:             "https://link.wikijob.co.uk/cryptohopper",
11:47:20 PM:             "\\bCryptohopper\\b"
11:47:20 PM:         ],
11:47:20 PM:         [
11:47:20 PM:             "https://link.wikijob.co.uk/shrimpy",
11:47:20 PM:             "\\bShrimpy\\b"
11:47:20 PM:         ],
11:47:20 PM:         [
11:47:20 PM:             "https://link.wikijob.co.uk/cryptotrader",
11:47:20 PM:             "\\bCryptotrader\\b"
11:47:20 PM:         ],
11:47:20 PM:         [
11:47:20 PM:             "https://l.wikijob.co.uk/zero-to-pro-signals",
11:47:20 PM:             "\\bZero to Pro forex signals\\b|\\bZero to Pro\\b"
11:47:20 PM:         ],
11:47:21 PM:         [
11:47:21 PM:             "https://l.wikijob.co.uk/wallStreet-forex-robot",
11:47:21 PM:             "\\bWallStreet Forex Robot\\b"
11:47:21 PM:         ],
11:47:21 PM:         [
11:47:21 PM:             "https://tests.wikijob.co.uk/p-g-assessment",
11:47:21 PM:             "\\bP&G online assessment\\b"
11:47:21 PM:         ],
11:47:21 PM:         [
11:47:21 PM:             "https://tests.wikijob.co.uk/target-test-prep",
11:47:21 PM:             "\\bTargetTestPrep\\b"
11:47:21 PM:         ],
11:47:21 PM:         [
11:47:21 PM:             "https://tests.wikijob.co.uk/psb-test",
11:47:21 PM:             "\\bPSB Aptitude Test\\b|\\bPSB test\\b"
11:47:21 PM:         ],
11:47:21 PM:         [
11:47:21 PM:             "https://l.wikijob.co.uk/my-tefl",
11:47:21 PM:             "\\btoefl\\b|\\bTEFL\\b"
11:47:21 PM:         ],
11:47:21 PM:         [
11:47:21 PM:             "https://tests.wikijob.co.uk/assessment-day-link",
11:47:21 PM:             "\\bAssessmentDay\\b"
11:47:21 PM:         ],
11:47:21 PM:         [
11:47:21 PM:             "https://l.wikijob.co.uk/amazon-echo",
11:47:22 PM:             "\\bAmazon Alexa\\b|\\bAmazon Echo\\b|\\bEcho Dot\\b"
11:47:22 PM:         ],
11:47:22 PM:         [
11:47:22 PM:             "https://l.wikijob.co.uk/amazon",
11:47:22 PM:             "\\bamazon\\b"
11:47:22 PM:         ],
11:47:22 PM:         [
11:47:22 PM:             "https://linkly.wikijob.co.uk/fxcm-fx-broker",
11:47:22 PM:             "\\bFXCM\\b"
11:47:22 PM:         ],
11:47:22 PM:         [
11:47:22 PM:             "https://tests.wikijob.co.uk/data-checking",
11:47:22 PM:             "\\bData Checking assessments\\b|\\bData Checking assessment\\b|\\bData Checking tests\\b|\\bData Checking test\\b|\\bError Checking\\b|\\bData Checking\\b"
11:47:22 PM:         ],
11:47:22 PM:         [
11:47:22 PM:             "https://tests.wikijob.co.uk/gmat-test",
11:47:22 PM:             "\\bpearson assessment\\b"
11:47:22 PM:         ],
11:47:22 PM:         [
11:47:22 PM:             "https://tests.wikijob.co.uk/magoosh-mcat",
11:47:22 PM:             "\\bMCAT\\b"
11:47:22 PM:         ],
11:47:22 PM:         [
11:47:23 PM:             "https://tests.wikijob.co.uk/cogat-screening",
11:47:23 PM:             "\\bCogAT Screening Form\\b"
11:47:23 PM:         ],
11:47:23 PM:         [
11:47:23 PM:             "https://tests.wikijob.co.uk/iowa-assessments",
11:47:23 PM:             "\\bIowa Assessments Exam\\b|\\bIowa Assessments\\b"
11:47:23 PM:         ],
11:47:23 PM:         [
11:47:23 PM:             "https://tests.wikijob.co.uk/accuplacer",
11:47:23 PM:             "\\bAccuplacer\\b"
11:47:23 PM:         ],
11:47:23 PM:         [
11:47:23 PM:             "https://tests.wikijob.co.uk/cuny-assessment",
11:47:23 PM:             "\\bCUNY Assessment\\b|\\bCUNY Placement\\b"
11:47:23 PM:         ],
11:47:23 PM:         [
11:47:23 PM:             "https://l.wikijob.co.uk/bots-signals",
11:47:23 PM:             "\\bBinary Options Trading Signals\\b|\\bBOTS trading signals\\b"
11:47:23 PM:         ],
11:47:23 PM:         [
11:47:23 PM:             "https://l.wikijob.co.uk/fx-agency-advisor",
11:47:23 PM:             "\\bFX Agency Advisor\\b|\\bFX-Agency Advisor\\b"
11:47:23 PM:         ],
11:47:23 PM:         [
11:47:23 PM:             "https://l.wikijob.co.uk/fx-childs-play-signals",
11:47:24 PM:             "\\bFX Childs Play Signals\\b"
11:47:24 PM:         ],
11:47:24 PM:         [
11:47:24 PM:             "https://l.wikijob.co.uk/zero-to-hero-fx-signals",
11:47:24 PM:             "\\bZero To Hero FX Signals\\b"
11:47:24 PM:         ],
11:47:24 PM:         [
11:47:24 PM:             "https://l.wikijob.co.uk/finviz-forex-signals",
11:47:24 PM:             "\\bfinviz\\b"
11:47:24 PM:         ],
11:47:24 PM:         [
11:47:24 PM:             "https://l.wikijob.co.uk/forex-market-sentiment",
11:47:24 PM:             "\\bForex Market Sentiment\\b"
11:47:24 PM:         ],
11:47:24 PM:         [
11:47:24 PM:             "https://l.wikijob.co.uk/fx-pattern-pro",
            "\\bFX Pattern Pro\\b"
11:47:24 PM:         ],
11:47:24 PM:         [
11:47:24 PM:             "https://l.wikijob.co.uk/fxtrendy",
11:47:24 PM:             "\\bForex Trendy\\b"
11:47:24 PM:         ],
11:47:24 PM:         [
11:47:24 PM:             "https://l.wikijob.co.uk/ea-builder",
11:47:24 PM:             "\\bExpert Advisor Builder\\b"
11:47:24 PM:         ],
11:47:25 PM:         [
11:47:25 PM:             "https://link.wikijob.co.uk/coinrule",
11:47:25 PM:             "\\bCoinrule\\b"
11:47:25 PM:         ],
11:47:25 PM:         [
11:47:25 PM:             "https://linkly.wikijob.co.uk/city-index-fx-broker",
11:47:25 PM:             "\\bCity Index\\b"
11:47:25 PM:         ],
11:47:25 PM:         [
11:47:25 PM:             "https://l.wikijob.co.uk/trading-212-general-link",
11:47:25 PM:             "\\btrading 212\\b|\\btrading212\\b"
11:47:25 PM:         ],
11:47:25 PM:         [
11:47:25 PM:             "https://tests.wikijob.co.uk/big-4-guides",
11:47:25 PM:             "\\bdeloitte\\b|\\bbig 4\\b|\\bKPMG\\b|\\bkpmg\\b|\\bPWC\\b|\\be&y\\b|\\bpwc\\b"
11:47:25 PM:         ],
11:47:25 PM:         [
11:47:25 PM:             "https://l.wikijob.co.uk/robinhood",
11:47:25 PM:             "\\brobinhood\\b"
11:47:25 PM:         ],
11:47:25 PM:         [
11:47:25 PM:             "https://l.wikijob.co.uk/capital-com",
11:47:25 PM:             "\\bcapital.com\\b"
11:47:25 PM:         ],
11:47:26 PM:         [
11:47:26 PM:             "https://tests.wikijob.co.uk/gump",
11:47:26 PM:             "\\bForex Gump\\b"
11:47:26 PM:         ],
11:47:26 PM:         [
11:47:26 PM:             "https://tests.wikijob.co.uk/hogan-checkout",
11:47:26 PM:             "\\bHogan\\b"
11:47:26 PM:         ],
11:47:26 PM:         [
11:47:26 PM:             "https://tests.wikijob.co.uk/atkins-assessment-center",
11:47:26 PM:             "\\bAtkins\\b"
11:47:26 PM:         ],
11:47:26 PM:         [
11:47:26 PM:             "https://tests.wikijob.co.uk/forex-mentor-pro",
11:47:26 PM:             "\\bforex mentor pro\\b"
11:47:26 PM:         ],
11:47:26 PM:         [
11:47:26 PM:             "https://tests.wikijob.co.uk/train-driver",
11:47:26 PM:             "\\btrain driver test\\b"
11:47:26 PM:         ],
11:47:26 PM:         [
11:47:26 PM:             "https://tests.wikijob.co.uk/critical-checkout",
11:47:26 PM:             "\\bcritical thinking tests\\b|\\bcritical thinking\\b"
11:47:26 PM:         ],
11:47:27 PM:         [
11:47:27 PM:             "https://linkly.wikijob.co.uk/plus500-fx-broker",
11:47:27 PM:             "\\bPlus500\\b"
11:47:27 PM:         ],
11:47:27 PM:         [
11:47:27 PM:             "https://link.wikijob.co.uk/economist-gre",
11:47:27 PM:             "\\bGRE\\b"
11:47:27 PM:         ],
11:47:27 PM:         [
11:47:27 PM:             "https://l.wikijob.co.uk/haas",
11:47:27 PM:             "\\bHaasbot\\b"
11:47:27 PM:         ],
11:47:27 PM:         [
11:47:27 PM:             "https://l.wikijob.co.uk/forex-diamond",
11:47:27 PM:             "\\bForex Diamond\\b"
11:47:27 PM:         ],
11:47:27 PM:         [
11:47:27 PM:             "https://tests.wikijob.co.uk/hello-bar",
11:47:27 PM:             "\\bassessment day\\b"
11:47:27 PM:         ],
11:47:27 PM:         [
11:47:27 PM:             "https://tests.wikijob.co.uk/eignungstest",
11:47:27 PM:             "\\bEignungstest\\b"
11:47:28 PM:         ],
11:47:28 PM:         [
11:47:28 PM:             "https://l.wikijob.co.uk/trademiner",
11:47:28 PM:             "\\bTradeMiner\\b"
11:47:28 PM:         ],
11:47:28 PM:         [
11:47:28 PM:             "https://l.wikijob.co.uk/vantagefx",
11:47:28 PM:             "\\bVantage FX\\b"
11:47:28 PM:         ],
11:47:28 PM:         [
11:47:28 PM:             "https://l.wikijob.co.uk/forexsignals",
11:47:28 PM:             "\\bforexsignals.com\\b"
11:47:28 PM:         ],
11:47:28 PM:         [
11:47:28 PM:             "https://tests.wikijob.co.uk/psb",
11:47:28 PM:             "\\bPSB\\b"
11:47:28 PM:         ],
11:47:28 PM:         [
11:47:28 PM:             "https://l.wikijob.co.uk/ddmarkets",
11:47:28 PM:             "\\bddmarkets\\b"
11:47:28 PM:         ],
11:47:28 PM:         [
11:47:28 PM:             "https://tests.wikijob.co.uk/parson-assessment",
11:47:28 PM:             "\\bparson assessment\\b"
11:47:28 PM:         ],
11:47:29 PM:         [
11:47:29 PM:             "https://l.wikijob.co.uk/markets",
11:47:29 PM:             "\\bMarkets.com\\b"
11:47:29 PM:         ],
11:47:29 PM:         [
11:47:29 PM:             "https://linkly.wikijob.co.uk/ig-fx-broker",
11:47:29 PM:             "\\bIG\\b"
11:47:29 PM:         ],
11:47:29 PM:         [
11:47:29 PM:             "https://l.wikijob.co.uk/oanda",
11:47:29 PM:             "\\bOANDA\\b"
11:47:29 PM:         ],
11:47:29 PM:         [
11:47:29 PM:             "https://l.wikijob.co.uk/bitmex",
11:47:29 PM:             "\\bBitMex\\b"
11:47:29 PM:         ],
11:47:29 PM:         [
11:47:29 PM:             "https://l.wikijob.co.uk/tradingview",
11:47:29 PM:             "\\bTradingView\\b"
11:47:29 PM:         ],
11:47:29 PM:         [
11:47:29 PM:             "https://l.wikijob.co.uk/olymptrade",
11:47:29 PM:             "\\bolymptrade\\b"
11:47:29 PM:         ],
11:47:29 PM:         [
11:47:29 PM:             "https://l.wikijob.co.uk/avatrade",
11:47:30 PM:             "\\bavatrade\\b"
11:47:30 PM:         ],
11:47:30 PM:         [
11:47:30 PM:             "https://link.wikijob.co.uk/economist-gmat-tutor-gmat-course",
11:47:30 PM:             "\\bGMAT\\b"
11:47:30 PM:         ],
11:47:30 PM:         [
11:47:30 PM:             "https://tests.wikijob.co.uk/shell-interview-practice",
11:47:30 PM:             "\\bShell\\b"
11:47:30 PM:         ],
11:47:30 PM:         [
11:47:30 PM:             "https://tests.wikijob.co.uk/british-council-interview",
11:47:30 PM:             "\\bBritish Council\\b"
11:47:30 PM:         ],
11:47:30 PM:         [
11:47:30 PM:             "https://tests.wikijob.co.uk/grant-thornton-interview",
11:47:30 PM:             "\\bGrant Thornton\\b"
11:47:30 PM:         ],
11:47:30 PM:         [
11:47:30 PM:             "https://tests.wikijob.co.uk/aldi-assessment-center",
11:47:30 PM:             "\\baldi\\b"
11:47:30 PM:         ],
11:47:30 PM:         [
11:47:31 PM:             "https://linkly.wikijob.co.uk/pepperstone-fx-broker",
11:47:31 PM:             "\\bcTrader platform\\b|\\bPepperstone\\b"
11:47:31 PM:         ],
11:47:31 PM:         [
11:47:31 PM:             "https://tests.wikijob.co.uk/case-study",
11:47:31 PM:             "\\bcase studies\\b|\\bcase study\\b"
11:47:31 PM:         ],
11:47:31 PM:         [
11:47:31 PM:             "https://tests.wikijob.co.uk/bloomberg-assessment",
11:47:31 PM:             "\\bBloomberg\\b"
11:47:31 PM:         ],
11:47:31 PM:         [
11:47:31 PM:             "https://tests.wikijob.co.uk/ramsay-checkout",
11:47:31 PM:             "\\bRamsay MAT-4\\b|\\bRamsay\\b"
11:47:31 PM:         ],
11:47:31 PM:         [
11:47:31 PM:             "https://tests.wikijob.co.uk/excel-checkout",
11:47:31 PM:             "\\bMicrosoft Excel tests\\b|\\bMicrosoft Excel test\\b|\\bMicrosoft excel\\b|\\bexcel tests\\b|\\bexcel test\\b"
11:47:31 PM:         ],
11:47:31 PM:         [
11:47:31 PM:             "https://l.wikijob.co.uk/magoosh-gmat",
11:47:31 PM:             "\\bMagoosh\\b"
11:47:31 PM:         ],
11:47:31 PM:         [
11:47:31 PM:             "https://l.wikijob.co.uk/kraken",
11:47:31 PM:             "\\bKraken\\b"
11:47:32 PM:         ],
11:47:32 PM:         [
11:47:32 PM:             "https://l.wikijob.co.uk/onetravel",
11:47:32 PM:             "\\bonetravel.com\\b"
11:47:32 PM:         ],
11:47:32 PM:         [
11:47:32 PM:             "https://l.wikijob.co.uk/bitpanda",
11:47:32 PM:             "\\bBitpanda\\b"
11:47:32 PM:         ],
11:47:32 PM:         [
11:47:32 PM:             "https://l.wikijob.co.uk/ironfx",
11:47:32 PM:             "\\bironfx.com\\b|\\bIronfx\\b"
11:47:32 PM:         ],
11:47:32 PM:         [
11:47:32 PM:             "https://l.wikijob.co.uk/southwest",
11:47:32 PM:             "\\bSouthwest.com\\b|\\bSouthwest\\b"
11:47:32 PM:         ],
11:47:32 PM:         [
11:47:32 PM:             "https://l.wikijob.co.uk/crypto",
11:47:32 PM:             "\\bcrypto.com\\b"
11:47:32 PM:         ],
11:47:32 PM:         [
11:47:32 PM:             "https://linkly.wikijob.co.uk/cmc-markets-fx-broker",
11:47:32 PM:             "\\bCMC Markets\\b"
11:47:32 PM:         ],
11:47:33 PM:         [
11:47:33 PM:             "https://l.wikijob.co.uk/hycm",
11:47:33 PM:             "\\bhycm.com\\b"
11:47:33 PM:         ],
11:47:33 PM:         [
11:47:33 PM:             "https://l.wikijob.co.uk/fxprofitsignals",
11:47:33 PM:             "\\bProfit Forex Signals\\b"
11:47:33 PM:         ],
11:47:33 PM:         [
11:47:33 PM:             "https://tests.wikijob.co.uk/mechanical-free-test",
11:47:33 PM:             "\\bFree Mechanical Tests\\b|\\bFree Mechanical Test\\b"
11:47:33 PM:         ],
11:47:33 PM:         [
11:47:33 PM:             "https://l.wikijob.co.uk/free-wonderlic-test",
11:47:33 PM:             "\\bFree Wonderlink Test\\b"
11:47:33 PM:         ],
11:47:33 PM:         [
11:47:33 PM:             "https://tests.wikijob.co.uk/free-criticall",
11:47:33 PM:             "\\bFree Criticall Tests\\b|\\bFree Criticall Test\\b"
11:47:33 PM:         ],
11:47:33 PM:         [
11:47:33 PM:             "https://tests.wikijob.co.uk/firefighter-free-test",
11:47:33 PM:             "\\bFree firefighter tests\\b|\\bFree firefighter test\\b"
11:47:33 PM:         ],
11:47:33 PM:         [
11:47:34 PM:             "https://l.wikijob.co.uk/pet-assure",
11:47:34 PM:             "\\bPet Assure\\b"
11:47:34 PM:         ],
11:47:34 PM:         [
11:47:34 PM:             "https://l.wikijob.co.uk/alaska-air",
11:47:34 PM:             "\\bAlaska Airlines\\b"
11:47:34 PM:         ],
11:47:34 PM:         [
11:47:34 PM:             "https://l.wikijob.co.uk/uphold",
11:47:34 PM:             "\\bUphold\\b"
11:47:34 PM:         ],
11:47:34 PM:         [
11:47:34 PM:             "https://l.linklyhq.com/l/e0hk",
11:47:34 PM:             "\\bExpedia\\b"
11:47:34 PM:         ],
11:47:34 PM:         [
11:47:34 PM:             "https://l.wikijob.co.uk/webull",
11:47:34 PM:             "\\bWebull\\b"
11:47:34 PM:         ],
11:47:34 PM:         [
11:47:34 PM:             "https://l.wikijob.co.uk/tickmill",
11:47:34 PM:             "\\bTickmill\\b"
11:47:34 PM:         ],
11:47:35 PM:         [
11:47:35 PM:             "https://l.wikijob.co.uk/bitflyer",
11:47:35 PM:             "\\bBitflyer\\b|\\bbitflyer\\b"
11:47:35 PM:         ],
11:47:35 PM:         [
11:47:35 PM:             "https://tests.wikijob.co.uk/video-interview",
11:47:35 PM:             "\\bvideo interview\\b"
11:47:35 PM:         ],
11:47:35 PM:         [
11:47:35 PM:             "https://tests.wikijob.co.uk/rcat",
11:47:35 PM:             "\\bRevelian Cognitive Ability Test\\b|\\bRCAT\\b"
11:47:35 PM:         ],
11:47:35 PM:         [
11:47:35 PM:             "https://tests.wikijob.co.uk/ford-assessment",
11:47:35 PM:             "\\bFord Assessments\\b|\\bFord Assessment\\b"
11:47:35 PM:         ],
11:47:35 PM:         [
11:47:35 PM:             "https://tests.wikijob.co.uk/supervisor-assessment",
11:47:35 PM:             "\\bSupervisor assessment\\b"
11:47:35 PM:         ],
11:47:35 PM:         [
11:47:35 PM:             "https://l.wikijob.co.uk/fiverr-freelance-sevices",
11:47:35 PM:             "\\bfiverr.com\\b|\\bfiverr\\b"
11:47:35 PM:         ],
11:47:35 PM:         [
11:47:36 PM:             "https://l.wikijob.co.uk/zero-to-hero",
11:47:36 PM:             "\\bZero to Hero\\b"
11:47:36 PM:         ],
11:47:36 PM:         [
11:47:36 PM:             "https://l.wikijob.co.uk/moneta-markets",
11:47:36 PM:             "\\bMoneta Markets\\b"
11:47:36 PM:         ],
11:47:36 PM:         [
11:47:36 PM:             "https://tests.wikijob.co.uk/gallup-strenghtsfinder",
11:47:36 PM:             "\\bGallup CliftonStrengths assessment \\b|\\bCliftonStrengths assessment\\b|\\bGallup CliftonStrengths \\b"
11:47:36 PM:         ],
11:47:36 PM:         [
11:47:36 PM:             "https://tests.wikijob.co.uk/geico-assessment-test",
11:47:36 PM:             "\\bGeico Assessment Test\\b"
11:47:36 PM:         ],
11:47:36 PM:         [
11:47:36 PM:             "https://l.wikijob.co.uk/universal-cpa-review",
11:47:36 PM:             "\\buniversal CPA review\\b"
11:47:36 PM:         ],
11:47:36 PM:         [
11:47:36 PM:             "https://l.wikijob.co.uk/upwork",
11:47:36 PM:             "\\bupwork\\b"
11:47:36 PM:         ],
11:47:36 PM:         [
11:47:36 PM:             "https://linkly.wikijob.co.uk/fxpro-fx-broker",
11:47:36 PM:             "\\bFxPro\\b"
11:47:37 PM:         ],
11:47:37 PM:         [
11:47:37 PM:             "https://tests.wikijob.co.uk/comprehension-test",
11:47:37 PM:             "\\bComprehension Test\\b"
11:47:37 PM:         ],
11:47:37 PM:         [
11:47:37 PM:             "https://tests.wikijob.co.uk/vodafone-graduate-prep",
11:47:37 PM:             "\\bVodafone Graduate Scheme\\b"
11:47:37 PM:         ],
11:47:37 PM:         [
11:47:37 PM:             "https://tests.wikijob.co.uk/data-entry",
11:47:37 PM:             "\\bdata entry test\\b|\\bData entry\\b"
11:47:37 PM:         ],
11:47:37 PM:         [
11:47:37 PM:             "https://tests.wikijob.co.uk/co-op-assessment",
11:47:37 PM:             "\\bCo-op Assessment Test\\b|\\bCo-op Assessment \\b|\\bCo-op Test\\b"
11:47:37 PM:         ],
11:47:37 PM:         [
11:47:37 PM:             "https://tests.wikijob.co.uk/spring-week",
11:47:37 PM:             "\\bSpring Week\\b"
11:47:37 PM:         ],
11:47:37 PM:         [
11:47:37 PM:             "https://link.wikijob.co.uk/zignaly",
11:47:37 PM:             "\\bZignaly\\b"
11:47:37 PM:         ],
11:47:38 PM:         [
11:47:38 PM:             "https://tests.wikijob.co.uk/bank-tellet",
11:47:38 PM:             "\\bbank teller test\\b|\\bbank teller \\b"
11:47:38 PM:         ],
11:47:38 PM:         [
11:47:38 PM:             "https://l.wikijob.co.uk/purplecv",
11:47:38 PM:             "\\bPurple CV\\b"
11:47:38 PM:         ],
11:47:38 PM:         [
11:47:38 PM:             "https://tests.wikijob.co.uk/california-corresctional-officer",
11:47:38 PM:             "\\bCalifornia correctional officer\\b"
11:47:38 PM:         ],
11:47:38 PM:         [
11:47:38 PM:             "https://tests.wikijob.co.uk/postal-exam-475",
11:47:38 PM:             "\\bUSPS postal exam 475\\b|\\bUSPS 475\\b"
11:47:38 PM:         ],
11:47:38 PM:         [
11:47:38 PM:             "https://l.wikijob.co.uk/centobot",
11:47:38 PM:             "\\bCentobot\\b"
11:47:38 PM:         ],
11:47:38 PM:         [
11:47:38 PM:             "https://l.wikijob.co.uk/uctrading",
11:47:38 PM:             "\\bUC Trading\\b"
11:47:39 PM:         ],
11:47:39 PM:         [
11:47:39 PM:             "https://tests.wikijob.co.uk/correctional-officer",
11:47:39 PM:             "\\bcorrectional officer\\b"
11:47:39 PM:         ],
11:47:39 PM:         [
11:47:39 PM:             "https://l.wikijob.co.uk/tradestation",
11:47:39 PM:             "\\btradestation\\b"
11:47:39 PM:         ],
11:47:39 PM:         [
11:47:39 PM:             "https://l.wikijob.co.uk/top-interview",
11:47:39 PM:             "\\bCompetency-based \\b|\\bcompetency based\\b"
11:47:39 PM:         ],
11:47:39 PM:         [
11:47:39 PM:             "https://tests.wikijob.co.uk/enneagram",
11:47:39 PM:             "\\bEnneagram Type 4\\b"
11:47:39 PM:         ],
11:47:39 PM:         [
11:47:39 PM:             "https://link.wikijob.co.uk/princeton-review-gmat-course",
11:47:39 PM:             "\\bThe Princeton Review\\b"
11:47:39 PM:         ],
11:47:39 PM:         [
11:47:39 PM:             "https://l.wikijob.co.uk/truity",
11:47:39 PM:             "\\bMyers-Briggs 16 personalities\\b|\\bMyers Briggs Type Inventory\\b|\\bMyers-Briggs\\b|\\bMyers Briggs\\b|\\bISFJ \\b|\\bENFP\\b|\\bMBTI\\b"
11:47:39 PM:         ],
11:47:40 PM:         [
11:47:40 PM:             "https://tests.wikijob.co.uk/postal-exam-476",
11:47:40 PM:             "\\b476 virtual entry assessment\\b|\\bUSPS 476 assessment\\b|\\bpostal exam 474\\b|\\bUSPS 476 Exam\\b|\\bUSPS 476 \\b"
11:47:40 PM:         ],
11:47:40 PM:         [
11:47:40 PM:             "https://l.wikijob.co.uk/flydubai",
11:47:40 PM:             "\\bFlydubai\\b"
11:47:40 PM:         ],
11:47:40 PM:         [
11:47:40 PM:             "https://tests.wikijob.co.uk/walmart-assessment",
11:47:40 PM:             "\\bWalmart Careers\\b|\\bWalmart\\b"
11:47:40 PM:         ],
11:47:40 PM:         [
11:47:40 PM:             "https://l.wikijob.co.uk/admiral-market",
11:47:40 PM:             "\\bAdmiral Markets\\b"
11:47:40 PM:         ],
11:47:40 PM:         [
11:47:40 PM:             "https://l.wikijob.co.uk/revolut",
11:47:40 PM:             "\\bRevolut\\b"
11:47:40 PM:         ],
11:47:40 PM:         [
11:47:40 PM:             "https://tests.wikijob.co.uk/swift-analysis",
11:47:40 PM:             "\\bSwift Skills Analysis Test\\b|\\bSwift Analysis Test\\b"
11:47:40 PM:         ],
11:47:40 PM:         [
11:47:41 PM:             "https://l.wikijob.co.uk/cheapair",
11:47:41 PM:             "\\bCheapair.com\\b"
11:47:41 PM:         ],
11:47:41 PM:         [
11:47:41 PM:             "https://l.wikijob.co.uk/flighthub",
11:47:41 PM:             "\\bFlighthub.com\\b"
11:47:41 PM:         ],
11:47:41 PM:         [
11:47:41 PM:             "https://tests.wikijob.co.uk/assessmentday-fujitsu",
11:47:41 PM:             "\\bFujitsu\\b"
11:47:41 PM:         ],
11:47:41 PM:         [
11:47:41 PM:             "https://l.wikijob.co.uk/degiro",
11:47:41 PM:             "\\bDEGIRO\\b"
11:47:41 PM:         ],
11:47:41 PM:         [
11:47:41 PM:             "https://tests.wikijob.co.uk/group-exercise",
11:47:41 PM:             "\\bgroup interview\\b|\\bgroup exercise\\b"
11:47:41 PM:         ],
11:47:41 PM:         [
11:47:41 PM:             "https://l.wikijob.co.uk/canva-main-page",
11:47:41 PM:             "\\bCanva\\b|\\bcanva\\b"
11:47:41 PM:         ],
11:47:41 PM:         [
11:47:41 PM:             "https://tests.wikijob.co.uk/case-studies-nav",
11:47:42 PM:             "\\bcase study interview\\b|\\bCase Interview\\b"
11:47:42 PM:         ],
11:47:42 PM:         [
11:47:42 PM:             "https://l.wikijob.co.uk/avianca",
11:47:42 PM:             "\\bAvianca\\b"
11:47:42 PM:         ],
11:47:42 PM:         [
11:47:42 PM:             "https://l.wikijob.co.uk/tradercobb",
11:47:42 PM:             "\\btradercobb.com\\b|\\btradercobb\\b"
11:47:42 PM:         ],
11:47:42 PM:         [
11:47:42 PM:             "https://tests.wikijob.co.uk/pilot-test",
11:47:42 PM:             "\\bPilot Aptitude Tests\\b|\\bPilot Aptitude Test\\b"
11:47:42 PM:         ],
11:47:42 PM:         [
11:47:42 PM:             "https://tests.wikijob.co.uk/bcat",
11:47:42 PM:             "\\bBCAT\\b"
11:47:42 PM:         ],
11:47:42 PM:         [
11:47:42 PM:             "https://tests.wikijob.co.uk/clerical-aptitude-tests",
11:47:42 PM:             "\\bclerical aptitude tests\\b|\\bclerical aptitude test\\b"
11:47:42 PM:         ],
11:47:42 PM:         [
11:47:42 PM:             "https://tests.wikijob.co.uk/pelletb-test",
11:47:43 PM:             "\\bPelletB\\b"
11:47:43 PM:         ],
11:47:43 PM:         [
11:47:43 PM:             "https://tests.wikijob.co.uk/royal-navy-test",
11:47:43 PM:             "\\bRoyal Navy Assessment\\b|\\bRoyal Navy Test\\b"
11:47:43 PM:         ],
11:46:46 PM:         [
11:46:46 PM:             "https://tests.wikijob.co.uk/clerical-aptitude-tests",
11:46:46 PM:             "\\bclerical aptitude tests\\b|\\bclerical aptitude test\\b"
11:46:46 PM:         ],
11:46:46 PM:         [
11:46:46 PM:             "https://tests.wikijob.co.uk/pelletb-test",
11:46:46 PM:             "\\bPelletB\\b"
11:46:46 PM:         ],
11:46:46 PM:         [
11:46:46 PM:             "https://tests.wikijob.co.uk/royal-navy-test",
11:46:47 PM:             "\\bRoyal Navy Assessment\\b|\\bRoyal Navy Test\\b"
11:46:47 PM:         ],
11:46:47 PM:         [
11:46:47 PM:             "https://tests.wikijob.co.uk/mmpi-link",
11:46:47 PM:             "\\bMMPI\\b"
11:46:47 PM:         ],
11:46:47 PM:         [
11:46:47 PM:             "https://tests.wikijob.co.uk/caliper-link",
11:46:47 PM:             "\\bCaliper\\b"
11:46:47 PM:         ],
11:46:47 PM:         [
11:46:47 PM:             "https://tests.wikijob.co.uk/barb-test",
11:46:47 PM:             "\\bBritish Army Cognitive Test\\b|\\bArmy Cognitive Test\\b|\\bBARB\\b"
11:46:47 PM:         ],
11:46:47 PM:         [
11:46:47 PM:             "https://tests.wikijob.co.uk/birkman",
11:46:47 PM:             "\\bBirkman tests\\b|\\bBirkman test\\b"
11:46:47 PM:         ],
11:46:48 PM:         [
11:46:48 PM:             "https://tests.wikijob.co.uk/cognitive-link",
11:46:48 PM:             "\\bcognitive ability\\b|\\bcognitive test\\b|\\bCAT\\b"
11:46:48 PM:         ],
11:46:48 PM:         [
11:46:48 PM:             "https://tests.wikijob.co.uk/bksb-test",
11:46:48 PM:             "\\bBKSB initial assessment\\b|\\bBKSB Test\\b|\\bBKSB\\b"
11:46:48 PM:         ],
11:46:48 PM:         [
11:46:48 PM:             "https://tests.wikijob.co.uk/in-tray-test",
11:46:48 PM:             "\\bin-tray\\b|\\bintray\\b"
11:46:48 PM:         ],
11:46:48 PM:         [
11:46:48 PM:             "https://tests.wikijob.co.uk/revelian-link",
11:46:48 PM:             "\\brevelian\\b|\\bRCAT\\b"
11:46:48 PM:         ],
11:46:49 PM:         [
11:46:49 PM:             "https://tests.wikijob.co.uk/criticall-link",
11:46:49 PM:             "\\bCriticall Tests\\b|\\bCriticall Test\\b"
11:46:49 PM:         ],
11:46:49 PM:         [
11:46:49 PM:             "https://tests.wikijob.co.uk/cast-test",
11:46:49 PM:             "\\bCAST\\b"
11:46:49 PM:         ],
11:46:49 PM:         [
11:46:49 PM:             "https://tests.wikijob.co.uk/workkeys",
11:46:49 PM:             "\\bWorkKeys\\b"
11:46:49 PM:         ],
11:46:49 PM:         [
11:46:49 PM:             "https://tests.wikijob.co.uk/eei-tests",
11:46:49 PM:             "\\bEEI\\b"
11:46:49 PM:         ],
11:46:49 PM:         [
11:46:49 PM:             "https://tests.wikijob.co.uk/capp-link",
11:46:49 PM:             "\\bCAPP tests\\b|\\bCAPP test\\b"
11:46:49 PM:         ],
11:46:49 PM:         [
11:46:49 PM:             "https://tests.wikijob.co.uk/qts-test",
11:46:49 PM:             "\\bQTS Numeracy\\b"
11:46:49 PM:         ],
11:46:50 PM:         [
11:46:50 PM:             "https://tests.wikijob.co.uk/disc",
11:46:50 PM:             "\\bDISC\\b"
11:46:50 PM:         ],
11:46:50 PM:         [
11:46:50 PM:             "https://tests.wikijob.co.uk/matrigma-prep",
11:46:50 PM:             "\\bMatrigma\\b"
11:46:50 PM:         ],
11:46:50 PM:         [
11:46:50 PM:             "https://tests.wikijob.co.uk/saville-assessment",
11:46:50 PM:             "\\bsaville assessment\\b"
11:46:50 PM:         ],
11:46:50 PM:         [
11:46:50 PM:             "https://tests.wikijob.co.uk/diagrammatic-practice-test",
11:46:50 PM:             "\\bFree Diagrammatic Practice Test\\b|\\bDiagrammatic Practice Test\\b"
11:46:50 PM:         ],
11:46:50 PM:         [
11:46:50 PM:             "https://tests.wikijob.co.uk/merrill-lynch-prep",
11:46:50 PM:             "\\bBank of America\\b|\\bMerrill Lynch\\b"
11:46:50 PM:         ],
11:46:50 PM:         [
11:46:50 PM:             "https://tests.wikijob.co.uk/act-asset-test",
11:46:50 PM:             "\\bACT ASSET test\\b|\\bACT ASSET Exam\\b|\\bASSET test\\b|\\bASSET Exam\\b|\\bACT exam\\b|\\bACT test\\b"
11:46:50 PM:         ],
11:46:50 PM:         [
11:46:51 PM:             "https://tests.wikijob.co.uk/asda-assessment",
11:46:51 PM:             "\\bASDA\\b"
11:46:51 PM:         ],
11:46:51 PM:         [
11:46:51 PM:             "https://tests.wikijob.co.uk/airbus-assessment-center",
11:46:51 PM:             "\\bAirbus\\b"
11:46:51 PM:         ],
11:46:51 PM:         [
11:46:51 PM:             "https://tests.wikijob.co.uk/factset-interviw",
11:46:51 PM:             "\\bFactset Interview\\b|\\bFactset\\b"
11:46:51 PM:         ],
11:46:51 PM:         [
11:46:51 PM:             "https://tests.wikijob.co.uk/asvab",
11:46:51 PM:             "\\bArmed Services Vocational Aptitude Battery\\b|\\bASVAB\\b"
11:46:51 PM:         ],
11:46:51 PM:         [
11:46:51 PM:             "https://tests.wikijob.co.uk/qts",
11:46:51 PM:             "\\bQualified Teacher Status\\b|\\bQTS Professional Skills\\b|\\bQTS Literacy\\b|\\bQTS Test\\b|\\bQTS\\b"
11:46:51 PM:         ],
11:46:51 PM:         [
11:46:51 PM:             "https://tests.wikijob.co.uk/amazon-assessment",
11:46:51 PM:             "\\bamazon assessment test\\b|\\bamazon assessment\\b"
11:46:52 PM:         ],
11:46:52 PM:         [
11:46:52 PM:             "https://tests.wikijob.co.uk/rolls-royce-assessment",
11:46:52 PM:             "\\bRolls-Royce\\b"
11:46:52 PM:         ],
11:46:52 PM:         [
11:46:52 PM:             "https://tests.wikijob.co.uk/usps-exams",
11:46:52 PM:             "\\bUSPS job\\b"
11:46:52 PM:         ],
11:46:52 PM:         [
11:46:52 PM:             "https://tests.wikijob.co.uk/blabkrock-assessment-center",
11:46:52 PM:             "\\bBlackRock\\b"
11:46:52 PM:         ],
11:46:52 PM:         [
11:46:52 PM:             "https://tests.wikijob.co.uk/raf-practice-link",
11:46:52 PM:             "\\bRAF Aptitude Test\\b|\\bRAF\\b"
11:46:52 PM:         ],
11:46:52 PM:         [
11:46:52 PM:             "https://tests.wikijob.co.uk/air-control",
11:46:52 PM:             "\\bNATS\\b|\\bATC\\b"
11:46:52 PM:         ],
11:46:52 PM:         [
11:46:52 PM:             "https://tests.wikijob.co.uk/standard-chartered-assessment",
11:46:53 PM:             "\\bStandard Chartered\\b"
11:46:53 PM:         ],
11:46:53 PM:         [
11:46:53 PM:             "https://tests.wikijob.co.uk/dhl",
11:46:53 PM:             "\\bDHL\\b"
11:46:53 PM:         ],
11:46:53 PM:         [
11:46:53 PM:             "https://tests.wikijob.co.uk/pg-link",
11:46:53 PM:             "\\bP&G online assessment\\b|\\bProcter & Gamble\\b"
11:46:53 PM:         ],
11:46:53 PM:         [
11:46:53 PM:             "https://tests.wikijob.co.uk/national-grid-assessment",
11:46:53 PM:             "\\bNational Grid\\b"
11:46:53 PM:         ],
11:46:53 PM:         [
11:46:53 PM:             "https://tests.wikijob.co.uk/free-watson-glaser",
11:46:53 PM:             "\\bfree watson glaser tests\\b|\\bfree watson glaser test\\b"
11:46:53 PM:         ],
11:46:53 PM:         [
11:46:53 PM:             "https://tests.wikijob.co.uk/written-exercises",
11:46:53 PM:             "\\bWritten exercises\\b"
11:46:53 PM:         ],
11:46:54 PM:         [
11:46:54 PM:             "https://tests.wikijob.co.uk/jtp-link",
11:46:54 PM:             "\\baptitude tests\\b|\\baptitude test\\b|\\bjob test prep\\b|\\bJobTestPrep\\b|\\bJobTestPrep\\b|\\bjobtestprep\\b|\\bjtp\\b"
11:46:54 PM:         ],
11:46:54 PM:         [
11:46:54 PM:             "https://tests.wikijob.co.uk/ey-interview",
11:46:54 PM:             "\\bEY interview\\b|\\bEY\\b"
11:46:54 PM:         ],
11:46:54 PM:         [
11:46:54 PM:             "https://tests.wikijob.co.uk/thames-water-assessment",
11:46:54 PM:             "\\bThames Water\\b"
11:46:54 PM:         ],
11:46:54 PM:         [
11:46:54 PM:             "https://tests.wikijob.co.uk/hmrc",
11:46:54 PM:             "\\bSantander\\b"
11:46:54 PM:         ],
11:46:54 PM:         [
11:46:54 PM:             "https://tests.wikijob.co.uk/santander-assessment",
11:46:54 PM:         ],
11:46:54 PM:         [
11:46:54 PM:             "https://tests.wikijob.co.uk/network-rail-assessment",
11:46:54 PM:             "\\bNetwork Rail\\b"
11:46:54 PM:         ],
11:46:54 PM:         [
11:46:55 PM:             "https://tests.wikijob.co.uk/accenture-application",
11:46:55 PM:             "\\bAccenture\\b"
11:46:55 PM:         ],
11:46:55 PM:         [
11:46:55 PM:             "https://tests.wikijob.co.uk/rsm",
11:46:55 PM:             "\\bRSM\\b"
11:46:55 PM:         ],
11:46:55 PM:         [
11:46:55 PM:             "https://tests.wikijob.co.uk/exxonmobil-assessment",
11:46:55 PM:             "\\bExxonMobil\\b"
11:46:55 PM:         ],
11:46:55 PM:         [
11:46:55 PM:             "https://l.wikijob.co.uk/maxcrowdfund",
11:46:55 PM:             "\\bmaxcrowdfund.com\\b"
11:46:55 PM:         ],
11:46:55 PM:         [
11:46:55 PM:             "https://tests.wikijob.co.uk/mckinsey-Test",
11:46:55 PM:             "\\bMcKinsey\\b"
11:46:55 PM:         ],
11:46:55 PM:         [
11:46:55 PM:             "https://tests.wikijob.co.uk/deutsche-bank-interview",
11:46:55 PM:             "\\bDeutsche Bank\\b"
11:46:55 PM:         ],
11:46:55 PM:         [
11:46:55 PM:             "https://tests.wikijob.co.uk/astra-zeneca-assessment",
11:46:55 PM:             "\\b Astra Zeneca application\\b|\\bastra zeneca\\b"
11:46:56 PM:         ],
11:46:56 PM:         [
11:46:56 PM:             "https://tests.wikijob.co.uk/hsbc-assessment-center",
11:46:56 PM:             "\\bHSBC\\b"
11:46:56 PM:         ],
11:46:56 PM:         [
11:46:56 PM:             "https://tests.wikijob.co.uk/clifford-chance",
11:46:56 PM:             "\\bClifford\\b"
11:46:56 PM:         ],
11:46:56 PM:         [
11:46:56 PM:             "https://tests.wikijob.co.uk/jtp-main-page",
11:46:56 PM:             "\\baptitude tests\\b|\\baptitude test\\b"
11:46:56 PM:         ],
11:46:56 PM:         [
11:46:56 PM:             "https://tests.wikijob.co.uk/predictive-index-tests",
11:46:56 PM:             "\\bPI Behavioral Assessment\\b|\\bPredictive Index\\b"
11:46:56 PM:         ],
11:46:56 PM:         [
11:46:56 PM:             "https://tests.wikijob.co.uk/pymetrics",
11:46:56 PM:             "\\bpymetrics test\\b|\\bPymetrics\\b"
11:46:56 PM:         ],
11:46:56 PM:         [
11:46:56 PM:             "https://tests.wikijob.co.uk/schroders-prep",
11:46:56 PM:             "\\bSchroders\\b"
11:46:57 PM:         ],
11:46:57 PM:         [
11:46:57 PM:             "https://tests.wikijob.co.uk/john-lewis-assessment",
11:46:57 PM:             "\\bJohn Lewis\\b"
11:46:57 PM:         ],
11:46:57 PM:         [
11:46:57 PM:             "https://tests.wikijob.co.uk/personality-link",
11:46:57 PM:             "\\bpersonality tests\\b|\\bpersonality test\\b"
11:46:57 PM:         ],
11:46:57 PM:         [
11:46:57 PM:             "https://tests.wikijob.co.uk/morgan-stanley-assessment-center",
11:46:57 PM:             "\\bMorgan Stanley\\b"
11:46:57 PM:         ],
11:46:57 PM:         [
11:46:57 PM:             "https://tests.wikijob.co.uk/herbert-assessment",
11:46:57 PM:             "\\bHerbert Smith Freehills \\b|\\bHSF\\b"
11:46:57 PM:         ],
11:46:57 PM:         [
11:46:57 PM:             "https://tests.wikijob.co.uk/uniliver-assessment",
11:46:57 PM:             "\\bUnilever\\b"
11:46:57 PM:         ],
11:46:57 PM:         [
11:46:57 PM:             "https://tests.wikijob.co.uk/ubs",
11:46:58 PM:             "\\bUBS\\b"
11:46:58 PM:         ],
11:46:58 PM:         [
11:46:58 PM:             "https://tests.wikijob.co.uk/aptitude-link",
11:46:58 PM:             "\\bpractice aptitude tests\\b|\\bpractice aptitude test\\b|\\baptitude tests\\b|\\baptitude test\\b"
11:46:58 PM:         ],
11:46:58 PM:         [
11:46:58 PM:             "https://tests.wikijob.co.uk/lloyds-assessment",
11:46:58 PM:             "\\bLloyds Bank\\b"
11:46:58 PM:         ],
11:46:58 PM:         [
11:46:58 PM:             "https://tests.wikijob.co.uk/sky-assessment",
11:46:58 PM:             "\\bSky\\b"
11:46:58 PM:         ],
11:46:58 PM:         [
11:46:58 PM:             "https://l.wikijob.co.uk/crowdwithus",
11:46:58 PM:             "\\bcrowdwithus.london\\b"
11:46:58 PM:         ],
11:46:58 PM:         [
11:46:58 PM:             "https://tests.wikijob.co.uk/kf-elements",
11:46:58 PM:             "\\bKF Elements Talent Q\\b|\\bKorn Ferry Elements\\b"
11:46:58 PM:         ],
11:46:58 PM:         [
11:46:59 PM:             "https://tests.wikijob.co.uk/civil-service",
11:46:59 PM:             "\\bcivil service\\b"
11:46:59 PM:         ],
11:46:59 PM:         [
11:46:59 PM:             "https://l.wikijob.co.uk/planethomeinvest",
11:46:59 PM:             "\\bhttps://planethome-invest.com/\\b"
11:46:59 PM:         ],
11:46:59 PM:         [
11:46:59 PM:             "https://tests.wikijob.co.uk/sova-assessment",
11:46:59 PM:             "\\bSova Assessment\\b|\\bSova\\b"
11:46:59 PM:         ],
11:46:59 PM:         [
11:46:59 PM:             "https://tests.wikijob.co.uk/lnat",
11:46:59 PM:             "\\bLNAT\\b"
11:46:59 PM:         ],
11:46:59 PM:         [
11:46:59 PM:             "https://tests.wikijob.co.uk/cut-e",
11:46:59 PM:             "\\bCut-e\\b"
11:46:59 PM:         ],
11:46:59 PM:         [
11:46:59 PM:             "https://tests.wikijob.co.uk/mcquaig-mental-agility",
11:46:59 PM:             "\\bMcQuaig Mental Agility\\b"
11:46:59 PM:         ],
11:46:59 PM:         [
11:46:59 PM:             "https://tests.wikijob.co.uk/iegat",
11:47:00 PM:             "\\bieGAT Test\\b|\\bieGAT\\b"
11:47:00 PM:         ],
11:47:00 PM:         [
11:47:00 PM:             "https://tests.wikijob.co.uk/pwc-interview",
11:47:00 PM:             "\\bPwC graduate application process\\b"
11:47:00 PM:         ],
11:47:00 PM:         [
11:47:00 PM:             "https://tests.wikijob.co.uk/mcquaig-word-survey",
11:47:00 PM:             "\\bMcQuaig Word Survey\\b"
11:47:00 PM:         ],
11:47:00 PM:         [
11:47:00 PM:             "https://tests.wikijob.co.uk/neo-personality",
11:47:00 PM:             "\\bNeo Personality Inventory Test\\b"
11:47:00 PM:         ],
11:47:00 PM:         [
11:47:00 PM:             "https://tests.wikijob.co.uk/deloitte-interview",
11:47:00 PM:             "\\bDeloitte Interview\\b"
11:47:00 PM:         ],
11:47:00 PM:         [
11:47:00 PM:             "https://tests.wikijob.co.uk/spatial-aptitude",
11:47:00 PM:             "\\bspatial aptitude\\b|\\bspatial\\b"
11:47:00 PM:         ],
11:47:00 PM:         [
11:47:00 PM:             "https://l.wikijob.co.uk/binance",
11:47:00 PM:             "\\bBinance\\b"
11:47:01 PM:         ],
11:47:01 PM:         [
11:47:01 PM:             "https://tests.wikijob.co.uk/online-tests",
11:47:01 PM:             "\\bOnline Tests\\b"
11:47:01 PM:         ],
11:47:01 PM:         [
11:47:01 PM:             "https://tests.wikijob.co.uk/bennett-test",
11:47:01 PM:             "\\bBennett Mechanical Comprehension Test\\b|\\bmechanical comprehension\\b|\\bBennett Test\\b|\\bBMCT Test\\b|\\bBennett\\b|\\bBMCT\\b"
11:47:01 PM:         ],
11:47:01 PM:         [
11:47:01 PM:             "https://tests.wikijob.co.uk/wonderlic-link",
11:47:01 PM:             "\\bWonderlic\\b"
11:47:01 PM:         ],
11:47:01 PM:         [
11:47:01 PM:             "https://tests.wikijob.co.uk/psychometric-tests",
11:47:01 PM:             "\\bpsychometric tests\\b|\\bpsychometric test\\b"
11:47:01 PM:         ],
11:47:01 PM:         [
11:47:01 PM:             "https://tests.wikijob.co.uk/online-tests-link",
11:47:01 PM:             "\\bonline tests\\b"
11:47:01 PM:         ],
11:47:01 PM:         [
11:47:02 PM:             "https://tests.wikijob.co.uk/capital-one-assessment",
11:47:02 PM:             "\\bCapital One Assessment Test\\b|\\bCapital One Assessment\\b|\\bCapital One\\b"
11:47:02 PM:         ],
11:47:02 PM:         [
11:47:02 PM:             "https://tests.wikijob.co.uk/assessment-centre",
11:47:02 PM:             "\\bassessment centres\\b|\\bassessment centre\\b"
11:47:02 PM:         ],
11:47:02 PM:         [
11:47:02 PM:             "https://tests.wikijob.co.uk/saville-wave-test",
11:47:02 PM:             "\\bSaville Wave Tests\\b|\\bSaville Wave Test\\b"
11:47:02 PM:         ],
11:47:02 PM:         [
11:47:02 PM:             "https://tests.wikijob.co.uk/cubiks",
11:47:02 PM:             "\\bCubiks tests\\b|\\bCubiks test\\b"
11:47:02 PM:         ],
11:47:02 PM:         [
11:47:02 PM:             "https://tests.wikijob.co.uk/mercer-assessment-centre",
11:47:02 PM:             "\\bMercer\\b"
11:47:02 PM:         ],
11:47:02 PM:         [
11:47:02 PM:             "https://tests.wikijob.co.uk/mechanical-nav",
11:47:02 PM:             "\\bmechanical reasoning test\\b|\\bmechanical reasoning\\b|\\bmechanical\\b"
11:47:02 PM:         ],
11:47:03 PM:         [
11:47:03 PM:             "https://tests.wikijob.co.uk/practice-tests",
11:47:03 PM:             "\\bpractice tests\\b|\\bpractice test\\b"
11:47:03 PM:         ],
11:47:03 PM:         [
11:47:03 PM:             "https://tests.wikijob.co.uk/kenexa-tests",
11:47:03 PM:             "\\bkenexa\\b"
11:47:03 PM:         ],
11:47:03 PM:         [
11:47:03 PM:             "https://tests.wikijob.co.uk/postal-exam-955",
11:47:03 PM:             "\\bPostal Exam 955\\b|\\bUSPS 955 exam\\b|\\bUSPS 955\\b|\\bExam 955\\b"
11:47:03 PM:         ],
11:47:03 PM:         [
11:47:03 PM:             "https://tests.wikijob.co.uk/lek-assessment",
11:47:03 PM:             "\\bLEK\\b"
11:47:03 PM:         ],
11:47:03 PM:         [
11:47:03 PM:             "https://tests.wikijob.co.uk/skype-interview-prep",
11:47:03 PM:             "\\bSkype\\b"
11:47:03 PM:         ],
11:47:03 PM:         [
11:47:03 PM:             "https://tests.wikijob.co.uk/analytical",
11:47:03 PM:             "\\bAnalytical Reasoning\\b"
11:47:04 PM:         ],
11:47:04 PM:         [
11:47:04 PM:             "https://tests.wikijob.co.uk/eiat",
11:47:04 PM:             "\\bThe Elevator Industry Aptitude Test (EIAT)\\b|\\bThe Elevator Industry Aptitude Test\\b|\\bEIAT\\b"
11:47:04 PM:         ],
11:47:04 PM:         [
11:47:04 PM:             "https://tests.wikijob.co.uk/rbc",
11:47:04 PM:             "\\bRBC\\b"
11:47:04 PM:         ],
11:47:04 PM:         [
11:47:04 PM:             "https://tests.wikijob.co.uk/postal-exam-474",
11:47:04 PM:             "\\bUSPS 474 assessment\\b|\\bpostal exam 474\\b|\\b Exam MC 474\\b|\\bUSPS 474\\b|\\bexam 474\\b|\\b MC 474\\b"
11:47:04 PM:         ],
11:47:04 PM:         [
11:47:04 PM:             "https://tests.wikijob.co.uk/fbi-link",
11:47:04 PM:             "\\bFBI Phase 1 Test\\b"
11:47:04 PM:         ],
11:47:04 PM:         [
11:47:04 PM:             "https://tests.wikijob.co.uk/microsoft-office",
11:47:04 PM:             "\\bMicrosoft Office Test\\b|\\bMicrosoft Office\\b|\\bMicrosoft Word\\b"
11:47:04 PM:         ],
11:47:04 PM:         [
11:47:04 PM:             "https://l.wikijob.co.uk/1password",
11:47:04 PM:             "\\b1Password\\b"
11:47:04 PM:         ],
11:47:05 PM:         [
11:47:05 PM:             "https://l.wikijob.co.uk/premier-tefl",
11:47:05 PM:             "\\bPremier TEFL\\b"
11:47:05 PM:         ],
11:47:05 PM:         [
11:47:05 PM:             "https://tests.wikijob.co.uk/bus-driver-assessment",
11:47:05 PM:             "\\bbus driver assessment\\b|\\bbus driver test\\b"
11:47:05 PM:         ],
11:47:05 PM:         [
11:47:05 PM:             "https://tests.wikijob.co.uk/berke-assessment",
11:47:05 PM:             "\\bBerke Assessment Test\\b|\\bBerke Assessment\\b"
11:47:05 PM:         ],
11:47:05 PM:         [
11:47:05 PM:             "https://tests.wikijob.co.uk/nyc-safety-agent",
11:47:05 PM:             "\\bNYC School Safety Agent Exam\\b|\\bNYC School Safety Agent\\b"
11:47:05 PM:         ],
11:47:05 PM:         [
11:47:05 PM:             "https://tests.wikijob.co.uk/utopia",
11:47:05 PM:             "\\butopia\\b"
11:47:05 PM:         ],
11:47:05 PM:         [
11:47:05 PM:             "https://tests.wikijob.co.uk/ibew-test",
11:47:05 PM:             "\\bIBEW Test\\b"
11:47:05 PM:         ],
11:47:06 PM:         [
11:47:06 PM:             "https://tests.wikijob.co.uk/cat-4",
11:47:06 PM:             "\\bCAT4\\b"
11:47:06 PM:         ],
11:47:06 PM:         [
11:47:06 PM:             "https://tests.wikijob.co.uk/pwc-test",
11:47:06 PM:             "\\bPrice waterhouse Coopers recruitment test\\b|\\bpwc recruitment test\\b|\\bpwc assessment test\\b|\\bpwc assessment\\b|\\bpwc test\\b"
11:47:06 PM:         ],
11:47:06 PM:         [
11:47:06 PM:             "https://tests.wikijob.co.uk/situational-check-out",
11:47:06 PM:             "\\bsituational judgement\\b|\\bSJT\\b"
11:47:06 PM:         ],
11:47:06 PM:         [
11:47:06 PM:             "https://tests.wikijob.co.uk/intray-link",
11:47:06 PM:             "\\bin tray\\b|\\bin-tray\\b|\\be-tray \\b|\\bintray\\b|\\be tray\\b|\\betray\\b"
11:47:06 PM:         ],
11:47:06 PM:         [
11:47:06 PM:             "https://tests.wikijob.co.uk/free-abstract-test",
11:47:06 PM:             "\\bfree abstract tests\\b|\\bfree abstract test\\b"
11:47:06 PM:         ],
11:47:06 PM:         [
11:47:06 PM:             "https://tests.wikijob.co.uk/abstract-check-out",
11:47:06 PM:             "\\babstract reasoning test\\b|\\babstract reasoning\\b|\\babstract\\b"
11:47:06 PM:         ],
11:47:06 PM:         [
11:47:07 PM:             "https://tests.wikijob.co.uk/bank-england-test",
11:47:07 PM:             "\\bbank of England test\\b"
11:47:07 PM:         ],
11:47:07 PM:         [
11:47:07 PM:             "https://tests.wikijob.co.uk/hudson-assessment",
11:47:07 PM:             "\\bHudson\\b"
11:47:07 PM:         ],
11:47:07 PM:         [
11:47:07 PM:             "https://tests.wikijob.co.uk/cabin-crew",
11:47:07 PM:             "\\bcabin crew test\\b"
11:47:07 PM:         ],
11:47:07 PM:         [
11:47:07 PM:             "https://l.wikijob.co.uk/blockchain",
11:47:07 PM:             "\\bBlockchain.com\\b"
11:47:07 PM:         ],
11:47:07 PM:         [
11:47:07 PM:             "https://l.wikijob.co.uk/tradex",
11:47:07 PM:             "\\bTradex\\b"
11:47:07 PM:         ],
11:47:07 PM:         [
11:47:07 PM:             "https://l.wikijob.co.uk/swyftfilings",
11:47:07 PM:             "\\bSwyft Filings\\b"
11:47:07 PM:         ],
11:47:07 PM:         [
11:47:07 PM:             "https://l.wikijob.co.uk/incfile",
11:47:08 PM:             "\\bIncfile\\b"
11:47:08 PM:         ],
11:47:08 PM:         [
11:47:08 PM:             "https://tests.wikijob.co.uk/edf",
11:47:08 PM:             "\\bEDF\\b"
11:47:08 PM:         ],
11:47:08 PM:         [
11:47:08 PM:             "https://tests.wikijob.co.uk/reckitt-benckiser",
11:47:08 PM:             "\\bReckitt Benckiser Assessment\\b|\\bReckitt Benckiser test\\b|\\bReckitt Benckiser\\b"
11:47:08 PM:         ],
11:47:08 PM:         [
11:47:08 PM:             "https://tests.wikijob.co.uk/amazon/warehouse-prep",
11:47:08 PM:             "\\bAmazon Warehouse and Fulfillment online assessment\\b|\\bAmazon Warehouse and Fulfillment assessment\\b"
11:47:08 PM:         ],
11:47:08 PM:         [
11:47:08 PM:             "https://l.wikijob.co.uk/lendsecured",
11:47:08 PM:             "\\bLendsecured.eu\\b"
11:47:08 PM:         ],
11:47:08 PM:         [
11:47:08 PM:             "https://tests.wikijob.co.uk/deductive-link",
11:47:08 PM:             "\\bdeductive reasoning\\b"
11:47:08 PM:         ],
11:47:08 PM:         [
11:47:08 PM:             "https://tests.wikijob.co.uk/verbal-reasoning-tests",
11:47:08 PM:             "\\bverbal reasoning tests\\b|\\bverbal reasoning test\\b|\\bverbal test\\b|\\bverbal\\b"
11:47:08 PM:         ],
11:47:09 PM:         [
11:47:09 PM:             "https://tests.wikijob.co.uk/opq32",
11:47:09 PM:             "\\boccupational personality questionnaire\\b|\\bSHL OPQ test\\b|\\bOPQ32 test\\b|\\bOPQ test\\b|\\bSHL OPQ\\b|\\bOPQ32\\b|\\bOPQ\\b"
11:47:09 PM:         ],
11:47:09 PM:         [
11:47:09 PM:             "https://tests.wikijob.co.uk/critical-reasoning-test",
11:47:09 PM:             "\\bCritical Reasoning\\b"
11:47:09 PM:         ],
11:47:09 PM:         [
11:47:09 PM:             "https://tests.wikijob.co.uk/non-verbal-reasoning",
11:47:09 PM:             "\\bnon-verbal reasoning\\b|\\bnon-verbal\\b|\\bnon verbal\\b"
11:47:09 PM:         ],
11:47:09 PM:         [
11:47:09 PM:             "https://tests.wikijob.co.uk/logical-link",
11:47:09 PM:             "\\blogical reasoning\\b"
11:47:09 PM:         ],
11:47:09 PM:         [
11:47:09 PM:             "https://tests.wikijob.co.uk/logical-test",
11:47:09 PM:         ],
11:47:09 PM:         [
11:47:09 PM:             "https://tests.wikijob.co.uk/spatial-reasoning",
11:47:09 PM:             "\\bspatial awareness\\b|\\bspatial reasoning\\b"
11:47:09 PM:         ],
11:47:10 PM:         [
11:47:10 PM:             "https://tests.wikijob.co.uk/critical-reasoning",
11:47:10 PM:             "\\bcritical reasoning\\b"
11:47:10 PM:         ],
11:47:10 PM:         [
11:47:10 PM:             "https://tests.wikijob.co.uk/diagrammatic-check-out",
11:47:10 PM:             "\\bdiagrammatic reasoning\\b|\\bdiagram tests\\b|\\bdiagrammatic\\b"
11:47:10 PM:         ],
11:47:10 PM:         [
11:47:10 PM:             "https://tests.wikijob.co.uk/isee-lower-level",
11:47:10 PM:             "\\blower level ISEE test\\b"
11:47:10 PM:         ],
11:47:10 PM:         [
11:47:10 PM:             "https://tests.wikijob.co.uk/nhs-aptitude-tests",
11:47:10 PM:             "\\bNHS\\b"
11:47:10 PM:         ],
11:47:10 PM:         [
11:47:10 PM:             "https://tests.wikijob.co.uk/free-verbal-test",
11:47:10 PM:             "\\bFree Verbal Reasoning Test\\b|\\bFree Verbal Tests\\b|\\bFree Verbal Test\\b"
11:47:10 PM:         ],
11:47:10 PM:         [
11:47:10 PM:             "https://tests.wikijob.co.uk/thinking-skills-assessment",
11:47:10 PM:             "\\bthinking skills assessment\\b"
11:47:10 PM:         ],
11:47:10 PM:         [
11:47:10 PM:             "https://tests.wikijob.co.uk/korn-ferry-talent-q",
11:47:11 PM:             "\\btalent q\\b"
11:47:11 PM:         ],
11:47:11 PM:         [
11:47:11 PM:             "https://l.wikijob.co.uk/flexjobs-interview",
11:47:11 PM:             "\\binterview\\b"
11:47:11 PM:         ],
11:47:11 PM:         [
11:47:11 PM:             "https://tests.wikijob.co.uk/isee-middle-level",
11:47:11 PM:             "\\bmiddle-level ISEE test\\b"
11:47:11 PM:         ],
11:47:11 PM:         [
11:47:11 PM:             "https://tests.wikijob.co.uk/hsbc-assessment",
11:47:11 PM:             "\\bHSBC\\b"
11:47:11 PM:         ],
11:47:11 PM:         [
11:47:11 PM:             "https://tests.wikijob.co.uk/kpmg",
11:47:11 PM:             "\\bKPMG\\b"
11:47:11 PM:         ],
11:47:11 PM:         [
11:47:11 PM:             "https://l.wikijob.co.uk/postal-exam-477",
11:47:11 PM:             "\\bUSPS 477 exam\\b|\\bUSPS 477 test\\b"
11:47:11 PM:         ],
11:47:11 PM:         [
11:47:11 PM:             "https://tests.wikijob.co.uk/ucat",
11:47:12 PM:             "\\bUniversity Clinical Aptitude Test\\b|\\bUCAT\\b"
11:47:12 PM:         ],
11:47:12 PM:         [
11:47:12 PM:             "https://tests.wikijob.co.uk/inductive-link",
11:47:12 PM:             "\\binductive reasoning\\b|\\binductive\\b"
11:47:12 PM:         ],
11:47:12 PM:         [
11:47:12 PM:             "https://tests.wikijob.co.uk/ccat-check-out",
11:47:12 PM:             "\\bCriteria Cognitive Aptitude Test\\b|\\bCCAT Test\\b|\\bCCAT\\b"
11:47:12 PM:         ],
11:47:12 PM:         [
11:47:12 PM:             "https://tests.wikijob.co.uk/korn-ferry-leadership-assessment",
11:47:12 PM:             "\\bKF Leadership assessment\\b|\\bKorn Ferry leadership\\b"
11:47:12 PM:         ],
11:47:12 PM:         [
11:47:12 PM:             "https://tests.wikijob.co.uk/korn-ferry",
11:47:12 PM:             "\\bKorn Ferry\\b"
11:47:12 PM:         ],
11:47:12 PM:         [
11:47:12 PM:             "https://tests.wikijob.co.uk/swift-executive",
11:47:12 PM:             "\\bSwift Executive Test\\b|\\bSwift Executive\\b"
11:47:12 PM:         ],
11:47:12 PM:         [
11:47:12 PM:             "https://tests.wikijob.co.uk/numerical-link",
11:47:12 PM:             "\\bnumerical reasoning\\b|\\bnumerical\\b"
11:47:13 PM:         ],
11:47:13 PM:         [
11:47:13 PM:             "https://tests.wikijob.co.uk/numerical-test",
11:47:13 PM:             "\\bNumerical\\b"
11:47:13 PM:         ],
11:47:13 PM:         [
11:47:13 PM:             "https://tests.wikijob.co.uk/shl-general-ability",
11:47:13 PM:             "\\bSHL General Ability Test\\b"
11:47:13 PM:         ],
11:47:13 PM:         [
11:47:13 PM:             "https://tests.wikijob.co.uk/map-test",
11:47:13 PM:             "\\bMeasures of Academic Progress Test\\b|\\bMAP test\\b|\\bMAP Test\\b"
11:47:13 PM:         ],
11:47:13 PM:         [
11:47:13 PM:             "https://l.wikijob.co.uk/ofx",
11:47:13 PM:             "\\bOFX\\b"
11:47:13 PM:         ],
11:47:13 PM:         [
11:47:13 PM:             "https://tests.wikijob.co.uk/error-checking-tests",
11:47:13 PM:             "\\berror checking tests\\b|\\berror checking test\\b"
11:47:13 PM:         ],
11:47:13 PM:         [
11:47:13 PM:             "https://tests.wikijob.co.uk/freshfield",
11:47:13 PM:             "\\bFreshfields\\b"
11:47:14 PM:         ],
11:47:14 PM:         [
11:47:14 PM:             "https://tests.wikijob.co.uk/hbri",
11:47:14 PM:             "\\bHBRI\\b"
11:47:14 PM:         ],
11:47:14 PM:         [
11:47:14 PM:             "https://tests.wikijob.co.uk/hbri-test",
11:47:14 PM:         ],
11:47:14 PM:         [
11:47:14 PM:             "https://tests.wikijob.co.uk/shl",
11:47:14 PM:             "\\bSHL test\\b|\\bSHL\\b"
11:47:14 PM:         ],
11:47:14 PM:         [
11:47:14 PM:             "https://tests.wikijob.co.uk/numerical-ability",
11:47:14 PM:             "\\bnumerical ability test\\b|\\bnumerical ability\\b"
11:47:14 PM:         ],
11:47:14 PM:         [
11:47:14 PM:             "https://tests.wikijob.co.uk/verbal-ability",
11:47:14 PM:             "\\bverbal ability tests\\b|\\bverbal ability test\\b|\\bVerbal Ability\\b"
11:47:14 PM:         ],
11:47:14 PM:         [
11:47:14 PM:             "https://tests.wikijob.co.uk/aon-test",
11:47:14 PM:             "\\bAon G.A.T.E Assessment Test\\b|\\bAon G.A.T.E\\b|\\bAonTest\\b"
11:47:14 PM:         ],
11:47:15 PM:         [
11:47:15 PM:             "https://linkly.wikijob.co.uk/xtb-fx-broker",
11:47:15 PM:             "\\bXTB\\b"
11:47:15 PM:         ],
11:47:15 PM:         [
11:47:15 PM:             "https://tests.wikijob.co.uk/thomas-ppa",
11:47:15 PM:             "\\bThomas PPA\\b|\\bPPA test\\b|\\bPPA\\b"
11:47:15 PM:         ],
11:47:15 PM:         [
11:47:15 PM:             "https://tests.wikijob.co.uk/gia-test",
11:47:15 PM:             "\\bThomas International\\b|\\bGIA\\b"
11:47:15 PM:         ],
11:47:15 PM:         [
11:47:15 PM:             "https://tests.wikijob.co.uk/staar",
11:47:15 PM:             "\\bState of Texas Assessments of Academic Readiness\\b|\\bSTAAR \\b"
11:47:15 PM:         ],
11:47:15 PM:         [
11:47:15 PM:             "https://tests.wikijob.co.uk/cogat",
11:47:15 PM:             "\\bCogAT\\b"
11:47:15 PM:         ],
11:47:15 PM:         [
11:47:15 PM:             "https://tests.wikijob.co.uk/olsat",
11:47:15 PM:             "\\bOtis-Lennon School Ability Test\\b|\\bOLSAT\\b"
11:47:15 PM:         ],
11:47:16 PM:         [
11:46:23 PM:             "\\bData Checking assessments\\b|\\bData Checking assessment\\b|\\bData Checking tests\\b|\\bData Checking test\\b|\\bError Checking\\b|\\bData Checking\\b"
11:46:23 PM:         ],
11:46:23 PM:         [
11:46:23 PM:             "https://tests.wikijob.co.uk/gmat-test",
11:46:23 PM:             "\\bpearson assessment\\b"
11:46:23 PM:         ],
11:46:23 PM:         [
11:46:23 PM:             "https://tests.wikijob.co.uk/magoosh-mcat",
11:46:23 PM:             "\\bMCAT\\b"
11:46:23 PM:         ],
11:46:23 PM:         [
11:46:23 PM:             "https://tests.wikijob.co.uk/cogat-screening",
11:46:23 PM:             "\\bCogAT Screening Form\\b"
11:46:23 PM:         ],
11:46:24 PM:         [
11:46:24 PM:             "https://tests.wikijob.co.uk/iowa-assessments",
11:46:24 PM:             "\\bIowa Assessments Exam\\b|\\bIowa Assessments\\b"
11:46:24 PM:         ],
11:46:24 PM:         [
11:46:24 PM:             "https://tests.wikijob.co.uk/accuplacer",
11:46:24 PM:             "\\bAccuplacer\\b"
11:46:24 PM:         ],
11:46:24 PM:         [
11:46:24 PM:             "https://tests.wikijob.co.uk/cuny-assessment",
11:46:24 PM:             "\\bCUNY Assessment\\b|\\bCUNY Placement\\b"
11:46:24 PM:         ],
11:46:24 PM:         [
11:46:24 PM:             "https://l.wikijob.co.uk/bots-signals",
11:46:24 PM:             "\\bBinary Options Trading Signals\\b|\\bBOTS trading signals\\b"
11:46:24 PM:         ],
11:46:24 PM:         [
11:46:24 PM:             "https://l.wikijob.co.uk/fx-agency-advisor",
11:46:24 PM:             "\\bFX Agency Advisor\\b|\\bFX-Agency Advisor\\b"
11:46:24 PM:         ],
11:46:24 PM:         [
11:46:24 PM:             "https://l.wikijob.co.uk/fx-childs-play-signals",
11:46:25 PM:             "\\bFX Childs Play Signals\\b"
11:46:25 PM:         ],
11:46:25 PM:         [
11:46:25 PM:             "https://l.wikijob.co.uk/zero-to-hero-fx-signals",
11:46:25 PM:             "\\bZero To Hero FX Signals\\b"
11:46:25 PM:         ],
11:46:25 PM:         [
11:46:25 PM:             "https://l.wikijob.co.uk/finviz-forex-signals",
11:46:25 PM:             "\\bfinviz\\b"
11:46:25 PM:         ],
11:46:25 PM:         [
11:46:25 PM:             "https://l.wikijob.co.uk/forex-market-sentiment",
11:46:25 PM:             "\\bForex Market Sentiment\\b"
11:46:25 PM:         ],
11:46:25 PM:         [
11:46:25 PM:             "https://l.wikijob.co.uk/fx-pattern-pro",
11:46:25 PM:             "\\bFX Pattern Pro\\b"
11:46:25 PM:         ],
11:46:25 PM:         [
11:46:25 PM:             "https://l.wikijob.co.uk/fxtrendy",
11:46:25 PM:             "\\bForex Trendy\\b"
11:46:25 PM:         ],
11:46:25 PM:         [
11:46:25 PM:             "https://l.wikijob.co.uk/ea-builder",
11:46:26 PM:             "\\bExpert Advisor Builder\\b"
11:46:26 PM:         ],
11:46:26 PM:         [
11:46:26 PM:             "https://link.wikijob.co.uk/coinrule",
11:46:26 PM:             "\\bCoinrule\\b"
11:46:26 PM:         ],
11:46:26 PM:         [
11:46:26 PM:             "https://linkly.wikijob.co.uk/city-index-fx-broker",
11:46:26 PM:             "\\bCity Index\\b"
11:46:26 PM:         ],
11:46:26 PM:         [
11:46:26 PM:             "https://l.wikijob.co.uk/trading-212-general-link",
11:46:26 PM:             "\\btrading 212\\b|\\btrading212\\b"
11:46:26 PM:         ],
11:46:26 PM:         [
11:46:26 PM:             "https://tests.wikijob.co.uk/big-4-guides",
11:46:27 PM:             "\\bdeloitte\\b|\\bbig 4\\b|\\bKPMG\\b|\\bkpmg\\b|\\bPWC\\b|\\be&y\\b|\\bpwc\\b"
11:46:27 PM:         ],
11:46:27 PM:         [
11:46:27 PM:             "https://l.wikijob.co.uk/robinhood",
11:46:27 PM:             "\\brobinhood\\b"
11:46:27 PM:         ],
11:46:27 PM:         [
11:46:27 PM:             "https://l.wikijob.co.uk/capital-com",
11:46:27 PM:             "\\bcapital.com\\b"
11:46:27 PM:         ],
11:46:27 PM:         [
11:46:27 PM:             "https://tests.wikijob.co.uk/gump",
11:46:27 PM:             "\\bForex Gump\\b"
11:46:27 PM:         ],
11:46:27 PM:         [
11:46:27 PM:             "https://tests.wikijob.co.uk/hogan-checkout",
11:46:27 PM:             "\\bHogan\\b"
11:46:27 PM:         ],
11:46:27 PM:         [
11:46:27 PM:             "https://tests.wikijob.co.uk/atkins-assessment-center",
11:46:27 PM:             "\\bAtkins\\b"
11:46:27 PM:         ],
11:46:28 PM:         [
11:46:28 PM:             "https://tests.wikijob.co.uk/forex-mentor-pro",
11:46:28 PM:             "\\bforex mentor pro\\b"
11:46:28 PM:         ],
11:46:28 PM:         [
11:46:28 PM:             "https://tests.wikijob.co.uk/train-driver",
11:46:28 PM:             "\\btrain driver test\\b"
11:46:28 PM:         ],
11:46:28 PM:         [
11:46:28 PM:             "https://tests.wikijob.co.uk/critical-checkout",
11:46:28 PM:             "\\bcritical thinking tests\\b|\\bcritical thinking\\b"
11:46:28 PM:         ],
11:46:28 PM:         [
11:46:28 PM:             "https://linkly.wikijob.co.uk/plus500-fx-broker",
11:46:28 PM:             "\\bPlus500\\b"
11:46:28 PM:         ],
11:46:28 PM:         [
11:46:28 PM:             "https://link.wikijob.co.uk/economist-gre",
11:46:28 PM:             "\\bGRE\\b"
11:46:28 PM:         ],
11:46:28 PM:         [
11:46:28 PM:             "https://l.wikijob.co.uk/haas",
11:46:28 PM:             "\\bHaasbot\\b"
11:46:29 PM:         ],
11:46:29 PM:         [
11:46:29 PM:             "https://l.wikijob.co.uk/forex-diamond",
11:46:29 PM:             "\\bForex Diamond\\b"
11:46:29 PM:         ],
11:46:29 PM:         [
11:46:29 PM:             "https://tests.wikijob.co.uk/hello-bar",
11:46:29 PM:             "\\bassessment day\\b"
11:46:29 PM:         ],
11:46:29 PM:         [
11:46:29 PM:             "https://tests.wikijob.co.uk/eignungstest",
11:46:29 PM:             "\\bEignungstest\\b"
11:46:29 PM:         ],
11:46:29 PM:         [
11:46:29 PM:             "https://l.wikijob.co.uk/trademiner",
11:46:29 PM:             "\\bTradeMiner\\b"
11:46:29 PM:         ],
11:46:29 PM:         [
11:46:29 PM:             "https://l.wikijob.co.uk/vantagefx",
11:46:29 PM:             "\\bVantage FX\\b"
11:46:30 PM:         ],
11:46:30 PM:         [
11:46:30 PM:             "https://l.wikijob.co.uk/forexsignals",
11:46:30 PM:             "\\bforexsignals.com\\b"
11:46:30 PM:         ],
11:46:30 PM:         [
11:46:30 PM:             "https://tests.wikijob.co.uk/psb",
11:46:30 PM:             "\\bPSB\\b"
11:46:30 PM:         ],
11:46:30 PM:         [
11:46:30 PM:             "https://l.wikijob.co.uk/ddmarkets",
11:46:30 PM:             "\\bddmarkets\\b"
11:46:30 PM:         ],
11:46:30 PM:         [
11:46:30 PM:             "https://tests.wikijob.co.uk/parson-assessment",
11:46:30 PM:             "\\bparson assessment\\b"
11:46:30 PM:         ],
11:46:30 PM:         [
11:46:31 PM:             "https://l.wikijob.co.uk/markets",
11:46:31 PM:             "\\bMarkets.com\\b"
11:46:31 PM:         ],
11:46:31 PM:         [
11:46:31 PM:             "https://linkly.wikijob.co.uk/ig-fx-broker",
11:46:31 PM:             "\\bIG\\b"
11:46:31 PM:         ],
11:46:31 PM:         [
11:46:31 PM:             "https://l.wikijob.co.uk/oanda",
11:46:31 PM:             "\\bOANDA\\b"
11:46:31 PM:         ],
11:46:31 PM:         [
11:46:31 PM:             "https://l.wikijob.co.uk/bitmex",
11:46:31 PM:             "\\bBitMex\\b"
11:46:31 PM:         ],
11:46:31 PM:         [
11:46:31 PM:             "https://l.wikijob.co.uk/tradingview",
11:46:31 PM:             "\\bTradingView\\b"
11:46:31 PM:         ],
11:46:31 PM:         [
11:46:31 PM:             "https://l.wikijob.co.uk/olymptrade",
11:46:31 PM:             "\\bolymptrade\\b"
11:46:31 PM:         ],
11:46:31 PM:         [
11:46:32 PM:             "https://l.wikijob.co.uk/avatrade",
11:46:32 PM:             "\\bavatrade\\b"
11:46:32 PM:         ],
11:46:32 PM:         [
11:46:32 PM:             "https://link.wikijob.co.uk/economist-gmat-tutor-gmat-course",
11:46:32 PM:             "\\bGMAT\\b"
11:46:32 PM:         ],
11:46:32 PM:         [
11:46:32 PM:             "https://tests.wikijob.co.uk/shell-interview-practice",
11:46:32 PM:             "\\bShell\\b"
11:46:32 PM:         ],
11:46:32 PM:         [
11:46:32 PM:             "https://tests.wikijob.co.uk/british-council-interview",
11:46:32 PM:             "\\bBritish Council\\b"
11:46:32 PM:         ],
11:46:32 PM:         [
11:46:32 PM:             "https://tests.wikijob.co.uk/grant-thornton-interview",
11:46:32 PM:             "\\bGrant Thornton\\b"
11:46:32 PM:         ],
11:46:32 PM:         [
11:46:32 PM:             "https://tests.wikijob.co.uk/aldi-assessment-center",
11:46:32 PM:             "\\baldi\\b"
11:46:32 PM:         ],
11:46:32 PM:         [
11:46:32 PM:             "https://linkly.wikijob.co.uk/pepperstone-fx-broker",
11:46:33 PM:             "\\bcTrader platform\\b|\\bPepperstone\\b"
11:46:33 PM:         ],
11:46:33 PM:         [
11:46:33 PM:             "https://tests.wikijob.co.uk/case-study",
11:46:33 PM:             "\\bcase studies\\b|\\bcase study\\b"
11:46:33 PM:         ],
11:46:33 PM:         [
11:46:33 PM:             "https://tests.wikijob.co.uk/bloomberg-assessment",
11:46:33 PM:             "\\bBloomberg\\b"
11:46:33 PM:         ],
11:46:33 PM:         [
11:46:33 PM:             "https://tests.wikijob.co.uk/ramsay-checkout",
11:46:33 PM:             "\\bRamsay MAT-4\\b|\\bRamsay\\b"
11:46:33 PM:         ],
11:46:33 PM:         [
11:46:33 PM:             "https://tests.wikijob.co.uk/excel-checkout",
11:46:33 PM:             "\\bMicrosoft Excel tests\\b|\\bMicrosoft Excel test\\b|\\bMicrosoft excel\\b|\\bexcel tests\\b|\\bexcel test\\b"
11:46:33 PM:         ],
11:46:33 PM:         [
11:46:33 PM:             "https://l.wikijob.co.uk/magoosh-gmat",
11:46:33 PM:             "\\bMagoosh\\b"
11:46:33 PM:         ],
11:46:33 PM:         [
11:46:33 PM:             "https://l.wikijob.co.uk/kraken",
11:46:33 PM:             "\\bKraken\\b"
11:46:34 PM:         ],
11:46:34 PM:         [
11:46:34 PM:             "https://l.wikijob.co.uk/onetravel",
11:46:34 PM:             "\\bonetravel.com\\b"
11:46:34 PM:         ],
11:46:34 PM:         [
11:46:34 PM:             "https://l.wikijob.co.uk/bitpanda",
11:46:34 PM:             "\\bBitpanda\\b"
11:46:34 PM:         ],
11:46:34 PM:         [
11:46:34 PM:             "https://l.wikijob.co.uk/ironfx",
11:46:34 PM:             "\\bironfx.com\\b|\\bIronfx\\b"
11:46:34 PM:         ],
11:46:34 PM:         [
11:46:34 PM:             "https://l.wikijob.co.uk/southwest",
11:46:34 PM:             "\\bSouthwest.com\\b|\\bSouthwest\\b"
11:46:34 PM:         ],
11:46:34 PM:         [
11:46:34 PM:             "https://l.wikijob.co.uk/crypto",
11:46:34 PM:             "\\bcrypto.com\\b"
11:46:34 PM:         ],
11:46:35 PM:         [
11:46:35 PM:             "https://linkly.wikijob.co.uk/cmc-markets-fx-broker",
11:46:35 PM:             "\\bCMC Markets\\b"
11:46:35 PM:         ],
11:46:35 PM:         [
11:46:35 PM:             "https://l.wikijob.co.uk/hycm",
11:46:35 PM:             "\\bhycm.com\\b"
11:46:35 PM:         ],
11:46:35 PM:         [
11:46:35 PM:             "https://l.wikijob.co.uk/fxprofitsignals",
11:46:35 PM:             "\\bProfit Forex Signals\\b"
11:46:35 PM:         ],
11:46:35 PM:         [
11:46:35 PM:             "https://tests.wikijob.co.uk/mechanical-free-test",
11:46:35 PM:             "\\bFree Mechanical Tests\\b|\\bFree Mechanical Test\\b"
11:46:35 PM:         ],
11:46:35 PM:         [
11:46:35 PM:             "https://l.wikijob.co.uk/free-wonderlic-test",
11:46:36 PM:             "\\bFree Wonderlink Test\\b"
11:46:36 PM:         ],
11:46:36 PM:         [
11:46:36 PM:             "https://tests.wikijob.co.uk/free-criticall",
11:46:36 PM:             "\\bFree Criticall Tests\\b|\\bFree Criticall Test\\b"
11:46:36 PM:         ],
11:46:36 PM:         [
11:46:36 PM:             "https://tests.wikijob.co.uk/firefighter-free-test",
11:46:36 PM:             "\\bFree firefighter tests\\b|\\bFree firefighter test\\b"
11:46:36 PM:         ],
11:46:36 PM:         [
11:46:36 PM:             "https://l.wikijob.co.uk/pet-assure",
11:46:36 PM:             "\\bPet Assure\\b"
11:46:36 PM:         ],
11:46:36 PM:         [
11:46:36 PM:             "https://l.wikijob.co.uk/alaska-air",
11:46:36 PM:             "\\bAlaska Airlines\\b"
11:46:36 PM:         ],
11:46:36 PM:         [
11:46:36 PM:             "https://l.wikijob.co.uk/uphold",
11:46:36 PM:             "\\bUphold\\b"
11:46:36 PM:         ],
11:46:36 PM:         [
11:46:37 PM:             "https://l.linklyhq.com/l/e0hk",
11:46:37 PM:             "\\bExpedia\\b"
11:46:37 PM:         ],
11:46:37 PM:         [
11:46:37 PM:             "https://l.wikijob.co.uk/webull",
11:46:37 PM:             "\\bWebull\\b"
11:46:37 PM:         ],
11:46:37 PM:         [
11:46:37 PM:             "https://l.wikijob.co.uk/tickmill",
11:46:37 PM:             "\\bTickmill\\b"
11:46:37 PM:         ],
11:46:37 PM:         [
11:46:37 PM:             "https://l.wikijob.co.uk/bitflyer",
11:46:37 PM:             "\\bBitflyer\\b|\\bbitflyer\\b"
11:46:37 PM:         ],
11:46:37 PM:         [
11:46:38 PM:             "https://tests.wikijob.co.uk/video-interview",
11:46:38 PM:             "\\bvideo interview\\b"
11:46:38 PM:         ],
11:46:38 PM:         [
11:46:38 PM:             "https://tests.wikijob.co.uk/rcat",
11:46:38 PM:             "\\bRevelian Cognitive Ability Test\\b|\\bRCAT\\b"
11:46:38 PM:         ],
11:46:38 PM:         [
11:46:38 PM:             "https://tests.wikijob.co.uk/ford-assessment",
11:46:38 PM:             "\\bFord Assessments\\b|\\bFord Assessment\\b"
11:46:38 PM:         ],
11:46:38 PM:         [
11:46:38 PM:             "https://tests.wikijob.co.uk/supervisor-assessment",
11:46:38 PM:             "\\bSupervisor assessment\\b"
11:46:38 PM:         ],
11:46:38 PM:         [
11:46:38 PM:             "https://l.wikijob.co.uk/fiverr-freelance-sevices",
11:46:38 PM:             "\\bfiverr.com\\b|\\bfiverr\\b"
11:46:38 PM:         ],
11:46:38 PM:         [
11:46:38 PM:             "https://l.wikijob.co.uk/zero-to-hero",
11:46:38 PM:             "\\bZero to Hero\\b"
11:46:38 PM:         ],
11:46:38 PM:         [
11:46:38 PM:             "https://l.wikijob.co.uk/moneta-markets",
11:46:39 PM:             "\\bMoneta Markets\\b"
11:46:39 PM:         ],
11:46:39 PM:         [
11:46:39 PM:             "https://tests.wikijob.co.uk/gallup-strenghtsfinder",
11:46:39 PM:             "\\bGallup CliftonStrengths assessment \\b|\\bCliftonStrengths assessment\\b|\\bGallup CliftonStrengths \\b"
11:46:39 PM:         ],
11:46:39 PM:         [
11:46:39 PM:             "https://tests.wikijob.co.uk/geico-assessment-test",
11:46:39 PM:             "\\bGeico Assessment Test\\b"
11:46:39 PM:         ],
11:46:39 PM:         [
11:46:39 PM:             "https://l.wikijob.co.uk/universal-cpa-review",
11:46:39 PM:             "\\buniversal CPA review\\b"
11:46:39 PM:         ],
11:46:39 PM:         [
11:46:39 PM:             "https://l.wikijob.co.uk/upwork",
11:46:39 PM:             "\\bupwork\\b"
11:46:39 PM:         ],
11:46:39 PM:         [
11:46:39 PM:             "https://linkly.wikijob.co.uk/fxpro-fx-broker",
11:46:39 PM:             "\\bFxPro\\b"
11:46:39 PM:         ],
11:46:39 PM:         [
11:46:40 PM:             "https://tests.wikijob.co.uk/comprehension-test",
11:46:40 PM:             "\\bComprehension Test\\b"
11:46:40 PM:         ],
11:46:40 PM:         [
11:46:40 PM:             "https://tests.wikijob.co.uk/vodafone-graduate-prep",
11:46:40 PM:             "\\bVodafone Graduate Scheme\\b"
11:46:40 PM:         ],
11:46:40 PM:         [
11:46:40 PM:             "https://tests.wikijob.co.uk/data-entry",
11:46:40 PM:             "\\bdata entry test\\b|\\bData entry\\b"
11:46:40 PM:         ],
11:46:40 PM:         [
11:46:40 PM:             "https://tests.wikijob.co.uk/co-op-assessment",
11:46:40 PM:             "\\bCo-op Assessment Test\\b|\\bCo-op Assessment \\b|\\bCo-op Test\\b"
11:46:40 PM:         ],
11:46:40 PM:         [
11:46:40 PM:             "https://tests.wikijob.co.uk/spring-week",
11:46:40 PM:             "\\bSpring Week\\b"
11:46:40 PM:         ],
11:46:40 PM:         [
11:46:40 PM:             "https://link.wikijob.co.uk/zignaly",
11:46:40 PM:             "\\bZignaly\\b"
11:46:40 PM:         ],
11:46:40 PM:         [
11:46:41 PM:             "https://tests.wikijob.co.uk/bank-tellet",
11:46:41 PM:             "\\bbank teller test\\b|\\bbank teller \\b"
11:46:41 PM:         ],
11:46:41 PM:         [
11:46:41 PM:             "https://l.wikijob.co.uk/purplecv",
            "\\bPurple CV\\b"
11:46:41 PM:         ],
11:46:41 PM:         [
11:46:41 PM:             "https://tests.wikijob.co.uk/california-corresctional-officer",
11:46:41 PM:             "\\bCalifornia correctional officer\\b"
11:46:41 PM:         ],
11:46:41 PM:         [
11:46:41 PM:             "https://tests.wikijob.co.uk/postal-exam-475",
11:46:41 PM:             "\\bUSPS postal exam 475\\b|\\bUSPS 475\\b"
11:46:41 PM:         ],
11:46:41 PM:         [
11:46:41 PM:             "https://l.wikijob.co.uk/centobot",
11:46:41 PM:             "\\bCentobot\\b"
11:46:41 PM:         ],
11:46:41 PM:         [
11:46:41 PM:             "https://l.wikijob.co.uk/uctrading",
11:46:42 PM:             "\\bUC Trading\\b"
11:46:42 PM:         ],
11:46:42 PM:         [
11:46:42 PM:             "https://tests.wikijob.co.uk/correctional-officer",
11:46:42 PM:             "\\bcorrectional officer\\b"
11:46:42 PM:         ],
11:46:42 PM:         [
11:46:42 PM:             "https://l.wikijob.co.uk/tradestation",
11:46:42 PM:             "\\btradestation\\b"
11:46:42 PM:         ],
11:46:42 PM:         [
11:46:42 PM:             "https://l.wikijob.co.uk/top-interview",
11:46:42 PM:             "\\bCompetency-based \\b|\\bcompetency based\\b"
11:46:42 PM:         ],
11:46:42 PM:         [
11:46:42 PM:             "https://tests.wikijob.co.uk/enneagram",
11:46:42 PM:             "\\bEnneagram Type 4\\b"
11:46:42 PM:         ],
11:46:42 PM:         [
11:46:42 PM:             "https://link.wikijob.co.uk/princeton-review-gmat-course",
11:46:42 PM:             "\\bThe Princeton Review\\b"
11:46:42 PM:         ],
11:46:42 PM:         [
11:46:42 PM:             "https://l.wikijob.co.uk/truity",
11:46:42 PM:             "\\bMyers-Briggs 16 personalities\\b|\\bMyers Briggs Type Inventory\\b|\\bMyers-Briggs\\b|\\bMyers Briggs\\b|\\bISFJ \\b|\\bENFP\\b|\\bMBTI\\b"
11:46:43 PM:         ],
11:46:43 PM:         [
11:46:43 PM:             "https://tests.wikijob.co.uk/postal-exam-476",
11:46:43 PM:             "\\b476 virtual entry assessment\\b|\\bUSPS 476 assessment\\b|\\bpostal exam 474\\b|\\bUSPS 476 Exam\\b|\\bUSPS 476 \\b"
11:46:43 PM:         ],
11:46:43 PM:         [
11:46:43 PM:             "https://l.wikijob.co.uk/flydubai",
11:46:43 PM:             "\\bFlydubai\\b"
11:46:43 PM:         ],
11:46:43 PM:         [
11:46:43 PM:             "https://tests.wikijob.co.uk/walmart-assessment",
11:46:43 PM:             "\\bWalmart Careers\\b|\\bWalmart\\b"
11:46:43 PM:         ],
11:46:43 PM:         [
11:46:43 PM:             "https://l.wikijob.co.uk/admiral-market",
11:46:43 PM:             "\\bAdmiral Markets\\b"
11:46:43 PM:         ],
11:46:43 PM:         [
11:46:43 PM:             "https://l.wikijob.co.uk/revolut",
11:46:44 PM:             "\\bRevolut\\b"
11:46:44 PM:         ],
11:46:44 PM:         [
11:46:44 PM:             "https://tests.wikijob.co.uk/swift-analysis",
11:46:44 PM:             "\\bSwift Skills Analysis Test\\b|\\bSwift Analysis Test\\b"
11:46:44 PM:         ],
11:46:44 PM:         [
11:46:44 PM:             "https://l.wikijob.co.uk/cheapair",
11:46:44 PM:             "\\bCheapair.com\\b"
11:46:44 PM:         ],
11:46:44 PM:         [
11:46:44 PM:             "https://l.wikijob.co.uk/flighthub",
11:46:44 PM:             "\\bFlighthub.com\\b"
11:46:44 PM:         ],
11:46:44 PM:         [
11:46:44 PM:             "https://tests.wikijob.co.uk/assessmentday-fujitsu",
11:46:44 PM:             "\\bFujitsu\\b"
11:46:44 PM:         ],
11:46:44 PM:         [
11:46:44 PM:             "https://l.wikijob.co.uk/degiro",
11:46:44 PM:             "\\bDEGIRO\\b"
11:46:44 PM:         ],
11:46:44 PM:         [
11:46:45 PM:             "https://tests.wikijob.co.uk/group-exercise",
11:46:45 PM:             "\\bgroup interview\\b|\\bgroup exercise\\b"
11:46:45 PM:         ],
11:46:45 PM:         [
11:46:45 PM:             "https://l.wikijob.co.uk/canva-main-page",
11:46:45 PM:             "\\bCanva\\b|\\bcanva\\b"
11:46:45 PM:         ],
11:46:45 PM:         [
11:46:45 PM:             "https://tests.wikijob.co.uk/case-studies-nav",
11:46:45 PM:             "\\bcase study interview\\b|\\bCase Interview\\b"
11:46:45 PM:         ],
11:46:45 PM:         [
11:46:45 PM:             "https://l.wikijob.co.uk/avianca",
11:46:45 PM:             "\\bAvianca\\b"
11:46:45 PM:         ],
11:46:45 PM:         [
11:46:45 PM:             "https://l.wikijob.co.uk/tradercobb",
11:46:45 PM:             "\\btradercobb.com\\b|\\btradercobb\\b"
11:46:45 PM:         ],
11:46:45 PM:         [
11:46:46 PM:             "https://tests.wikijob.co.uk/pilot-test",
11:46:46 PM:             "\\bPilot Aptitude Tests\\b|\\bPilot Aptitude Test\\b"
11:46:46 PM:         ],
11:46:46 PM:         [
11:46:46 PM:             "https://tests.wikijob.co.uk/bcat",
11:46:46 PM:             "\\bBCAT\\b"
11:46:46 PM:         ],
11:44:34 PM: Webpack Bundle Analyzer is started at http://127.0.0.1:3001
11:44:34 PM: Use Ctrl+C to close it
11:44:34 PM: success Building production JavaScript and CSS bundles - 27.488s
11:44:34 PM:
11:44:34 PM: gatsby-plugin-purgecss:
11:44:34 PM:  Previous CSS Size: 260.84 KB
11:44:34 PM:  New CSS Size: 110.76 KB (-57.54%)
11:44:34 PM:  Removed ~150.08 KB of CSS
11:44:34 PM:
11:44:53 PM: <w> [webpack.cache.PackFileCacheStrategy] Skipped not serializable cache item 'mini-css-extract-plugin /opt/build/repo/node_modules/css-loader/dist/cjs.js??ruleSet[1].rules[12].oneOf[0].use[1]!/opt/build/repo/node_modules/gatsby-plugin-purgecss/loader.js??ruleSet[1].rules[12].oneOf[0].use[2]!/opt/build/repo/node_modules/postcss-loader/dist/cjs.js??ruleSet[1].rules[12].oneOf[0].use[3]!/opt/build/repo/node_modules/sass-loader/dist/cjs.js??ruleSet[1].rules[12].oneOf[0].use[4]!/opt/build/repo/packages/wikijob/src/components/JobTestPrepBox/JobTestPrepBox.module.scss|0|Compilation/modules|/opt/build/repo/node_modules/css-loader/dist/cjs.js??ruleSet[1].rules[12].oneOf[0].use[1]!/opt/build/repo/node_modules/gatsby-plugin-purgecss/loader.js??ruleSet[1].rules[12].oneOf[0].use[2]!/opt/build/repo/node_modules/postcss-loader/dist/cjs.js??ruleSet[1].rules[12].oneOf[0].use[3]!/opt/build/repo/node_modules/sass-loader/dist/cjs.js??ruleSet[1].rules[12].oneOf[0].use[4]!/opt/build/repo/packages/wikijob/src/components/JobTestPrepBox/JobTestPrepBox.module.scss': No serializer registered for Warning
11:44:53 PM: <w> while serializing webpack/lib/cache/PackFileCacheStrategy.PackContentItems -> webpack/lib/NormalModule -> Array { 1 items } -> webpack/lib/ModuleWarning -> Warning
11:44:55 PM: <w> [webpack.cache.PackFileCacheStrategy] Skipped not serializable cache item 'Compilation/modules|/opt/build/repo/node_modules/css-loader/dist/cjs.js??ruleSet[1].rules[11].oneOf[0].use[0]!/opt/build/repo/node_modules/postcss-loader/dist/cjs.js??ruleSet[1].rules[11].oneOf[0].use[1]!/opt/build/repo/node_modules/sass-loader/dist/cjs.js??ruleSet[1].rules[11].oneOf[0].use[2]!/opt/build/repo/packages/wikijob/src/components/JobTestPrepBox/JobTestPrepBox.module.scss': No serializer registered for Warning
11:44:55 PM: <w> while serializing webpack/lib/cache/PackFileCacheStrategy.PackContentItems -> webpack/lib/NormalModule -> Array { 1 items } -> webpack/lib/ModuleWarning -> Warning
11:44:55 PM: success Building HTML renderer - 20.891s
11:45:00 PM: error [BABEL] Note: The code generator has deoptimised the styling of /opt/build/repo/packages/wikijob/.cache/page-ssr/routes/render-page.js as it exceeds the max of 500KB.
11:45:00 PM: success Execute page configs - 5.372s
11:45:00 PM: success Caching Webpack compilations - 0.000s
11:45:15 PM: warning This query took more than 15s to run — which is unusually long and might indicate you're querying too much or have some unoptimized code:
File path: /opt/build/repo/packages/wikijob/src/templates/article.js
11:45:15 PM: URL path: /interview-advice/company-interview-questions/bank-of-america-merrill-lynch
11:45:15 PM: Context: {
11:45:15 PM:     "id": "DatoCmsArticle-27776-en",
11:45:15 PM:     "pathname": "/interview-advice/company-interview-questions/bank-of-america-merrill-lynch",
11:45:15 PM:     "layout": {
11:45:15 PM:         "scrollableLayout": true
11:45:15 PM:     }
11:45:15 PM: }
11:45:15 PM: URL path: /interview-advice/interview-questions/case-study
11:45:15 PM:     "id": "DatoCmsArticle-27889-en",
11:45:15 PM:     "pathname": "/interview-advice/interview-questions/case-study",
11:45:15 PM:     }
11:45:15 PM: }
11:45:16 PM: warning This query took more than 15s to run — which is unusually long and might indicate you're querying too much or have some unoptimized code:
11:45:16 PM: URL path: /trading/forex/forex-brokers-australia
11:45:16 PM: Context: {
11:45:16 PM:     "id": "DatoCmsArticle-26936-en",
11:45:16 PM:     "pathname": "/trading/forex/forex-brokers-australia",
11:45:16 PM:     "layout": {
11:45:16 PM:         "scrollableLayout": true
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /application-advice/assessment-centres/presentation
11:45:16 PM:     "id": "DatoCmsArticle-26938-en",
11:45:16 PM:     "pathname": "/application-advice/assessment-centres/presentation",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /application-advice/cvs/computer-skills-resume
11:45:16 PM:     "id": "DatoCmsArticle-26941-en",
11:45:16 PM:     "pathname": "/application-advice/cvs/computer-skills-resume",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /application-advice/cvs/how-write-cover-letter
11:45:16 PM:     "id": "DatoCmsArticle-26943-en",
11:45:16 PM:     "pathname": "/application-advice/cvs/how-write-cover-letter",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /features/useful-resources/20-best-work-from-home-jobs
11:45:16 PM:     "id": "DatoCmsArticle-26815-en",
11:45:16 PM:     "pathname": "/features/useful-resources/20-best-work-from-home-jobs",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /features/useful-resources/career-matches-entj-personalities
11:45:16 PM:     "id": "DatoCmsArticle-26820-en",
11:45:16 PM:     "pathname": "/features/useful-resources/career-matches-entj-personalities",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /features/useful-resources/career-matches-intj-personalities
11:45:16 PM:     "id": "DatoCmsArticle-26821-en",
11:45:16 PM:     "pathname": "/features/useful-resources/career-matches-intj-personalities",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /features/useful-resources/career-matches-intp-personalities
11:45:16 PM:     "id": "DatoCmsArticle-26822-en",
11:45:16 PM:     "pathname": "/features/useful-resources/career-matches-intp-personalities",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /aptitude-tests/test-types/situational-judgement-test
11:45:16 PM:     "id": "DatoCmsArticle-28025-en",
11:45:16 PM:     "pathname": "/aptitude-tests/test-types/situational-judgement-test",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /industry/accountancy-professional-services/pwc-working-culture
11:45:16 PM:     "id": "DatoCmsArticle-28032-en",
11:45:16 PM:     "pathname": "/industry/accountancy-professional-services/pwc-working-culture",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /interview-advice/company-interview-questions/deutsche-bank
11:45:16 PM:     "id": "DatoCmsArticle-28038-en",
11:45:16 PM:     "pathname": "/interview-advice/company-interview-questions/deutsche-bank",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /aptitude-tests/test-types/disc-assessment
11:45:16 PM:     "id": "DatoCmsArticle-28039-en",
11:45:16 PM:     "pathname": "/aptitude-tests/test-types/disc-assessment",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /application-advice/job-applications/how-to-end-an-email
11:45:16 PM:     "id": "DatoCmsArticle-27593-en",
11:45:16 PM:     "pathname": "/application-advice/job-applications/how-to-end-an-email",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /industry/investment-banking/barclays-graduate-schemes
11:45:16 PM:     "id": "DatoCmsArticle-27594-en",
11:45:16 PM:     "pathname": "/industry/investment-banking/barclays-graduate-schemes",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /aptitude-tests/test-types/bennett-mechanical-comprehension-tests
11:45:16 PM:     "id": "DatoCmsArticle-27595-en",
11:45:16 PM:     "pathname": "/aptitude-tests/test-types/bennett-mechanical-comprehension-tests",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /aptitude-tests/gifted-and-talented-tests/nyc-gifted-and-talented-test
11:45:16 PM:     "id": "DatoCmsArticle-27596-en",
11:45:16 PM:     "pathname": "/aptitude-tests/gifted-and-talented-tests/nyc-gifted-and-talented-test",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /trading/forex/stock-trading-courses
11:45:16 PM:     "id": "DatoCmsArticle-26700-en",
11:45:16 PM:     "pathname": "/trading/forex/stock-trading-courses",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /aptitude-tests/test-types/analytical-reasoning-tests
11:45:16 PM:     "id": "DatoCmsArticle-26705-en",
11:45:16 PM:     "pathname": "/aptitude-tests/test-types/analytical-reasoning-tests",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /aptitude-tests/test-types/numerical-reasoning-tests
11:45:16 PM:     "id": "DatoCmsArticle-26707-en",
11:45:16 PM:     "pathname": "/aptitude-tests/test-types/numerical-reasoning-tests",
11:45:16 PM:     }
11:45:16 PM: }
11:45:16 PM: URL path: /aptitude-tests/test-types/pilot-aptitude-tests
11:45:16 PM:     "id": "DatoCmsArticle-26708-en",
11:45:16 PM:     "pathname": "/aptitude-tests/test-types/pilot-aptitude-tests",
11:45:16 PM:     }
11:45:16 PM: }
11:45:17 PM: warning This query took more than 15s to run — which is unusually long and might indicate you're querying too much or have some unoptimized code:
11:45:17 PM: URL path: /jobs-and-careers/leadership/carrot-and-stick-motivation
11:45:17 PM: Context: {
11:45:17 PM:     "id": "DatoCmsArticle-27569-en",
11:45:17 PM:     "pathname": "/jobs-and-careers/leadership/carrot-and-stick-motivation",
11:45:17 PM:     "layout": {
11:45:17 PM:         "scrollableLayout": true
11:45:17 PM:     }
11:45:17 PM: }
11:45:17 PM: URL path: /finance/make-money-online/make-money-on-youtube
11:45:17 PM:     "id": "DatoCmsArticle-27728-en",
11:45:17 PM:     "pathname": "/finance/make-money-online/make-money-on-youtube",
11:45:17 PM:     }
11:45:17 PM: }
11:45:17 PM: URL path: /jobs-and-careers/employment/code-of-ethics
11:45:17 PM:     "id": "DatoCmsArticle-27752-en",
11:45:17 PM:     "pathname": "/jobs-and-careers/employment/code-of-ethics",
11:45:17 PM:     }
11:45:17 PM: }
11:45:17 PM: URL path: /software/business-software/help-desk-software
11:45:17 PM:     "id": "DatoCmsArticle-27945-en",
11:45:17 PM:     "pathname": "/software/business-software/help-desk-software",
11:45:17 PM:     }
11:45:17 PM: }
File path: /opt/build/repo/packages/wikijob/src/templates/aptitude-test.js
11:45:17 PM: URL path: /aptitude-tests/test-providers/practice-shl-tests/shl-deductive-practice
11:45:17 PM:     "id": "DatoCmsTest-30027-en",
11:45:17 PM:     "words": [
11:45:17 PM:         [
11:45:17 PM:             "https://tests.wikijob.co.uk/math-assessment-test",
11:45:17 PM:             "\\bMath Assessment Tests\\b"
11:45:17 PM:         ],
11:42:53 PM: ────────────────────────────────────────────────────────────────
11:42:53 PM:   Netlify Build
11:42:53 PM: ​
11:42:53 PM: ❯ Version
11:42:53 PM:   @netlify/build 27.20.1
11:42:53 PM: ​
11:42:53 PM: ❯ Flags
11:42:53 PM:   baseRelDir: false
11:42:53 PM:   buildId: 634467533bcb0f000924c4d9
11:42:53 PM:   deployId: 634467533bcb0f000924c4db
11:42:53 PM: ​
11:42:53 PM: ❯ Current directory
11:42:53 PM:   /opt/build/repo/packages/wikijob
11:42:53 PM: ​
11:42:53 PM: ❯ Config file
11:42:53 PM:   /opt/build/repo/packages/wikijob/netlify.toml
11:42:53 PM: ​
11:42:53 PM: ❯ Context
11:42:53 PM:   deploy-preview
11:42:53 PM: ​
11:42:53 PM: ❯ Loading plugins
11:42:53 PM:    - netlify-purge-cloudflare-on-deploy@1.2.0 from Netlify app
11:42:53 PM:    - @netlify/plugin-lighthouse@2.1.3 from Netlify app
11:42:53 PM: ​
11:42:53 PM: ❯ Outdated plugins
11:42:53 PM:    - @netlify/plugin-lighthouse@2.1.3: latest version is 4.0.1
11:42:53 PM:      To upgrade this plugin, please uninstall and re-install it from the Netlify plugins directory (https://app.netlify.com/plugins)
11:42:54 PM: ​
11:42:54 PM: ────────────────────────────────────────────────────────────────
11:42:54 PM:   1. Build command from Netlify app
11:42:54 PM: ​
11:42:54 PM: $ yarn build
11:42:54 PM: yarn run v1.22.4
11:42:54 PM: $ gatsby build
11:42:57 PM: success compile gatsby files - 0.797s
11:42:57 PM: success load gatsby config - 0.054s
11:42:57 PM: warning Plugin gatsby-plugin-remove-trailing-slashes is not compatible with your gatsby version 4.24.4 - It requires gatsby@^3.0.0-next.0
11:42:57 PM: test
11:42:57 PM: warning Plugin gatsby-plugin-netlify is not compatible with your gatsby version 4.24.4 - It requires gatsby@^3.0.0
11:42:57 PM: warning Plugin gatsby-transformer-remark is not compatible with your gatsby version 4.24.4 - It requires gatsby@^3.0.0-next.0
11:42:58 PM: warning Plugin gatsby-plugin-remove-trailing-slashes is not compatible with your gatsby version 4.24.4 - It requires gatsby@^3.0.0-next.0
11:42:58 PM: warning Plugin gatsby-plugin-netlify is not compatible with your gatsby version 4.24.4 - It requires gatsby@^3.0.0
11:42:58 PM: warning Plugin gatsby-transformer-remark is not compatible with your gatsby version 4.24.4 - It requires gatsby@^3.0.0-next.0
11:42:59 PM: success load plugins - 2.384s
11:43:00 PM: success onPreInit - 0.322s
11:43:00 PM: success initialize cache - 0.059s
11:43:00 PM: success copy gatsby files - 0.184s
11:43:00 PM: success Compiling Gatsby Functions - 0.220s
11:43:00 PM: success onPreBootstrap - 0.230s
11:43:07 PM: test
11:43:07 PM: test
11:43:07 PM: test
11:43:07 PM: test
11:43:07 PM: test
11:43:07 PM: test
11:43:07 PM: test
11:43:07 PM: test
11:43:07 PM: test
11:43:07 PM: test
11:43:08 PM: test
11:43:08 PM: test
11:43:08 PM: test
11:43:08 PM: test
11:43:08 PM: test
11:43:15 PM: success loading DatoCMS schema - 15.009s
11:43:16 PM: success createSchemaCustomization - 15.547s
11:43:44 PM: success Checking for changed pages - 0.000s
11:43:44 PM: success source and transform nodes - 28.492s
11:43:45 PM: info Writing GraphQL type definitions to /opt/build/repo/packages/wikijob/.cache/schema.gql
11:43:46 PM: success building schema - 2.000s
11:43:48 PM: success createPages - 1.984s
11:43:49 PM: success createPagesStatefully - 0.136s
11:43:49 PM: info Total nodes: 117033, SitePage nodes: 1698 (use --verbose for breakdown)
11:43:49 PM: success Checking for changed pages - 0.001s
11:43:49 PM: success onPreExtractQueries - 0.001s
11:44:06 PM: success extract queries from components - 17.825s
11:44:06 PM: success write out redirect data - 0.001s
11:44:06 PM: success Build manifest and related icons - 0.065s
11:44:06 PM: success onPostBootstrap - 0.066s
11:44:06 PM: info bootstrap finished - 72.230s
11:44:07 PM: success write out requires - 0.021s
11:44:07 PM: info [gatsby-plugin-perf-budgets] hooking into webpack
11:44:25 PM: gatsby-plugin-purgecss: Only processing /opt/build/repo/node_modules/bootstrap/dist/css/bootstrap.min.css
11:44:25 PM:
11:44:25 PM: From: /opt/build/repo/node_modules/bootstrap/dist/css/bootstrap.min.css
11:44:25 PM:  Removed Selectors: [
11:44:25 PM:   'abbr[title]',
11:44:25 PM:   'dl',
11:44:25 PM:   'dt',
11:44:25 PM:   'blockquote',
11:44:25 PM:   '.mark',
11:44:25 PM:   'mark',
11:44:25 PM:   'sup',
11:44:25 PM:   'kbd',
11:44:25 PM:   'pre',
11:44:25 PM:   'samp',
11:44:25 PM:   'pre code',
11:44:25 PM:   'kbd kbd',
11:44:25 PM:   'th',
11:44:25 PM:   'tbody',
11:44:25 PM:   'td',
11:44:25 PM:   'tfoot',
11:44:25 PM:   'thead',
11:44:25 PM:   'tr',
11:44:25 PM:   'optgroup',
11:44:25 PM:   'textarea',
11:44:25 PM:   '[type=reset]',
11:44:25 PM:   '[type=reset]:not(:disabled)',
11:44:25 PM:   'fieldset',
11:44:25 PM:   'legend',
11:44:25 PM:   'legend+*',
11:44:25 PM:   'summary',
11:44:25 PM:   'progress',
11:44:25 PM:   '.lead',
11:44:25 PM:   '.display-1',
11:44:25 PM:   '.display-2',
11:44:25 PM:   '.display-3',
11:44:25 PM:   '.display-4',
11:44:25 PM:   '.display-5',
11:44:25 PM:   '.display-6',
11:44:25 PM:   '.list-unstyled',
11:44:25 PM:   '.list-inline',
11:44:25 PM:   '.list-inline-item',
11:44:25 PM:   '.list-inline-item:not(:last-child)',
11:44:25 PM:   '.initialism',
11:44:25 PM:   '.blockquote',
11:44:25 PM:   '.blockquote>:last-child',
11:44:25 PM:   '.blockquote-footer',
11:44:25 PM:   '.blockquote-footer::before',
11:44:25 PM:   '.img-thumbnail',
11:44:25 PM:   '.figure-img',
11:44:25 PM:   '.figure-caption',
11:44:25 PM:   '.container-fluid',
11:44:25 PM:   '.container-lg',
11:44:25 PM:   '.container-sm',
11:44:25 PM:   '.container-xl',
11:44:25 PM:   '.row-cols-auto>*',
11:44:25 PM:   '.row-cols-1>*',
11:44:25 PM:   '.row-cols-2>*',
11:44:25 PM:   '.row-cols-3>*',
11:44:25 PM:   '.row-cols-4>*',
11:44:25 PM:   '.row-cols-5>*',
11:44:25 PM:   '.row-cols-6>*',
11:44:25 PM:   '.col-auto',
11:44:25 PM:   '.col-1',
11:44:25 PM:   '.col-2',
11:44:25 PM:   '.col-3',
11:44:25 PM:   '.col-5',
11:44:25 PM:   '.col-7',
11:44:25 PM:   '.col-8',
11:44:25 PM:   '.col-9',
11:44:25 PM:   '.col-10',
11:44:25 PM:   '.col-11',
11:44:25 PM:   '.offset-1',
11:44:25 PM:   '.offset-2',
11:44:25 PM:   '.offset-3',
11:44:25 PM:   '.offset-4',
11:44:25 PM:   '.offset-5',
11:44:25 PM:   '.offset-6',
11:44:25 PM:   '.offset-7',
11:44:25 PM:   '.offset-8',
11:44:25 PM:   '.offset-9',
11:44:25 PM:   '.offset-10',
11:44:25 PM:   '.offset-11',
11:44:25 PM:   '.g-0',
11:44:25 PM:   '.gx-0',
11:44:25 PM:   '.gy-0',
11:44:25 PM:   '.g-1',
11:44:25 PM:   '.gx-1',
11:44:25 PM:   '.gy-1',
11:44:25 PM:   '.g-2',
11:44:25 PM:   '.gx-2',
11:44:25 PM:   '.gy-2',
11:44:25 PM:   '.gx-3',
11:44:25 PM:   '.gy-3',
11:44:25 PM:   '.g-4',
11:44:25 PM:   '.gx-4',
11:44:25 PM:   '.gy-4',
11:44:25 PM:   '.g-5',
11:44:25 PM:   '.gx-5',
11:44:25 PM:   '.gy-5',
11:44:25 PM:   '.col-sm',
11:44:25 PM:   '.row-cols-sm-auto>*',
11:44:25 PM:   '.row-cols-sm-1>*',
11:44:25 PM:   '.row-cols-sm-2>*',
11:44:25 PM:   '.row-cols-sm-3>*',
11:44:25 PM:   ... 2049 more items
11:44:25 PM: ]
11:41:24 PM: Build ready to start
11:41:26 PM: build-image version: 9289b698a503f132b265bd089ab40ce1d6f9e65e (focal)
11:41:26 PM: build-image tag: v4.12.0
11:41:26 PM: buildbot version: c87074660cd9a4568c0ac759bc083987e94204b3
11:41:26 PM: Fetching cached dependencies
11:41:26 PM: Starting to download cache of 582.7MB
11:41:31 PM: Finished downloading cache in 5.338923653s
11:41:31 PM: Starting to extract cache
11:41:38 PM: Finished extracting cache in 6.742468831s
11:41:38 PM: Finished fetching cache in 12.166876809s
11:41:38 PM: Starting to prepare the repo for build
11:41:38 PM: Preparing Git Reference pull/1868/head
11:41:39 PM: Parsing package.json dependencies
11:41:40 PM: Starting build script
11:41:40 PM: Installing dependencies
11:41:40 PM: Python version set to 2.7
11:41:41 PM: Started restoring cached node version
11:41:42 PM: Finished restoring cached node version
11:41:43 PM: v16.5.0 is already installed.
11:41:43 PM: Now using node v16.5.0 (npm v7.19.1)
11:41:43 PM: Started restoring cached build plugins
11:41:43 PM: Finished restoring cached build plugins
11:41:43 PM: Attempting ruby version 2.6.2, read from environment
11:41:43 PM: Started restoring cached ruby version
11:41:43 PM: Finished restoring cached ruby version
11:41:44 PM: Using ruby version 2.6.2
11:41:44 PM: Using PHP version 8.0
11:41:44 PM: Started restoring cached yarn cache
11:41:49 PM: Finished restoring cached yarn cache
11:41:50 PM: Found yarn version (1.13.0) that doesn't match expected (1.22.4)
11:41:50 PM: up to date, audited 1 package in 211ms
11:41:50 PM: found 0 vulnerabilities
11:41:50 PM: Installing yarn at version 1.22.4
11:41:50 PM: Installing Yarn!
11:41:50 PM: > Downloading tarball...
11:41:50 PM: [1/2]: https://yarnpkg.com/downloads/1.22.4/yarn-v1.22.4.tar.gz --> /tmp/yarn.tar.gz.1bw8HK5kPM
11:41:50 PM:   % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
11:41:50 PM:                                  Dload  Upload   Total   Spent    Left  Speed
11:41:50 PM:   0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
11:41:50 PM: 100    79  100    79    0     0    612      0 --:--:-- --:--:-- --:--:--   607
11:41:50 PM: 100    93  100    93    0     0    384      0 --:--:-- --:--:-- --:--:--   384
11:41:50 PM: 100 1215k  100 1215k    0     0  2901k      0 --:--:-- --:--:-- --:--:-- 2901k
11:41:50 PM: [2/2]: https://yarnpkg.com/downloads/1.22.4/yarn-v1.22.4.tar.gz.asc --> /tmp/yarn.tar.gz.1bw8HK5kPM.asc
11:41:50 PM: 100    83  100    83    0     0   1169      0 --:--:-- --:--:-- --:--:--  1169
11:41:51 PM: 100    97  100    97    0     0    960      0 --:--:-- --:--:-- --:--:--   960
11:41:51 PM:   0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
11:41:51 PM: 100  1028  100  1028    0     0   7290      0 --:--:-- --:--:-- --:--:--  7290
11:41:51 PM: > Verifying integrity...
11:41:51 PM: gpg: Signature made Mon 09 Mar 2020 03:52:13 PM UTC
11:41:51 PM: gpg:                using RSA key 6D98490C6F1ACDDD448E45954F77679369475BAA
11:41:51 PM: gpg: Good signature from "Yarn Packaging <yarn@dan.cx>" [unknown]
11:41:51 PM: gpg: WARNING: This key is not certified with a trusted signature!
11:41:51 PM: gpg:          There is no indication that the signature belongs to the owner.
11:41:51 PM: Primary key fingerprint: 72EC F46A 56B4 AD39 C907  BBB7 1646 B01B 86E5 0310
11:41:51 PM:      Subkey fingerprint: 6D98 490C 6F1A CDDD 448E  4595 4F77 6793 6947 5BAA
11:41:51 PM: > GPG signature looks good
11:41:51 PM: > Extracting to ~/.yarn...
11:41:51 PM: > Adding to $PATH...
11:41:51 PM: > Successfully installed Yarn 1.22.4! Please open another terminal where the `yarn` command will now be available.
11:41:51 PM: yarn workspaces detected
11:41:51 PM: Started restoring workspace packages/common node modules
11:41:51 PM: Finished restoring workspace packages/common node modules
11:41:51 PM: Started restoring workspace packages/psychometric node modules
11:41:51 PM: Finished restoring workspace packages/psychometric node modules
11:41:51 PM: Started restoring workspace packages/wikijob node modules
11:41:51 PM: Finished restoring workspace packages/wikijob node modules
11:41:51 PM: Started restoring workspace packages/wjdotcom node modules
11:41:51 PM: Finished restoring workspace packages/wjdotcom node modules
11:41:51 PM: Started restoring workspace root node modules
11:41:51 PM: Finished restoring workspace root node modules
11:41:51 PM: Installing NPM modules using Yarn version 1.22.4
11:41:52 PM: yarn install v1.22.4
11:41:52 PM: [1/4] Resolving packages...
11:41:53 PM: [2/4] Fetching packages...
11:42:19 PM: info fsevents@2.3.2: The platform "linux" is incompatible with this module.
11:42:19 PM: info "fsevents@2.3.2" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: info @lmdb/lmdb-darwin-arm64@2.5.3: The platform "linux" is incompatible with this module.
11:42:19 PM: info "@lmdb/lmdb-darwin-arm64@2.5.3" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: info @lmdb/lmdb-darwin-arm64@2.5.3: The CPU architecture "x64" is incompatible with this module.
11:42:19 PM: info @lmdb/lmdb-darwin-x64@2.5.3: The platform "linux" is incompatible with this module.
11:42:19 PM: info "@lmdb/lmdb-darwin-x64@2.5.3" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: info @lmdb/lmdb-linux-arm@2.5.3: The CPU architecture "x64" is incompatible with this module.
11:42:19 PM: info "@lmdb/lmdb-linux-arm@2.5.3" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: info @lmdb/lmdb-linux-arm64@2.5.3: The CPU architecture "x64" is incompatible with this module.
11:42:19 PM: info "@lmdb/lmdb-linux-arm64@2.5.3" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: info @lmdb/lmdb-win32-x64@2.5.3: The platform "linux" is incompatible with this module.
11:42:19 PM: info "@lmdb/lmdb-win32-x64@2.5.3" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: info @lmdb/lmdb-darwin-arm64@2.5.2: The platform "linux" is incompatible with this module.
11:42:19 PM: info "@lmdb/lmdb-darwin-arm64@2.5.2" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: info @lmdb/lmdb-darwin-arm64@2.5.2: The CPU architecture "x64" is incompatible with this module.
11:42:19 PM: info @lmdb/lmdb-darwin-x64@2.5.2: The platform "linux" is incompatible with this module.
11:42:19 PM: info "@lmdb/lmdb-darwin-x64@2.5.2" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: info @lmdb/lmdb-linux-arm@2.5.2: The CPU architecture "x64" is incompatible with this module.
11:42:19 PM: info "@lmdb/lmdb-linux-arm@2.5.2" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: info @lmdb/lmdb-linux-arm64@2.5.2: The CPU architecture "x64" is incompatible with this module.
11:42:19 PM: info "@lmdb/lmdb-linux-arm64@2.5.2" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: info @lmdb/lmdb-win32-x64@2.5.2: The platform "linux" is incompatible with this module.
11:42:19 PM: info "@lmdb/lmdb-win32-x64@2.5.2" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: info @msgpackr-extract/msgpackr-extract-darwin-arm64@2.1.2: The platform "linux" is incompatible with this module.
11:42:19 PM: info "@msgpackr-extract/msgpackr-extract-darwin-arm64@2.1.2" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: info @msgpackr-extract/msgpackr-extract-darwin-arm64@2.1.2: The CPU architecture "x64" is incompatible with this module.
11:42:19 PM: info @msgpackr-extract/msgpackr-extract-darwin-x64@2.1.2: The platform "linux" is incompatible with this module.
11:42:19 PM: info "@msgpackr-extract/msgpackr-extract-darwin-x64@2.1.2" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: info @msgpackr-extract/msgpackr-extract-linux-arm@2.1.2: The CPU architecture "x64" is incompatible with this module.
11:42:19 PM: info "@msgpackr-extract/msgpackr-extract-linux-arm@2.1.2" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: info @msgpackr-extract/msgpackr-extract-linux-arm64@2.1.2: The CPU architecture "x64" is incompatible with this module.
11:42:19 PM: info "@msgpackr-extract/msgpackr-extract-linux-arm64@2.1.2" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: info @msgpackr-extract/msgpackr-extract-win32-x64@2.1.2: The platform "linux" is incompatible with this module.
11:42:19 PM: info "@msgpackr-extract/msgpackr-extract-win32-x64@2.1.2" is an optional dependency and failed compatibility check. Excluding it from installation.
11:42:19 PM: [3/4] Linking dependencies...
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > common > @reach/router@1.3.4" has incorrect peer dependency "react@15.x || 16.x || 16.4.0-alpha.0911da3".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > common > @reach/router@1.3.4" has incorrect peer dependency "react-dom@15.x || 16.x || 16.4.0-alpha.0911da3".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > common > bootstrap@5.2.2" has unmet peer dependency "@popperjs/core@^2.11.6".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > common > gatsby-plugin-image@2.24.0" has unmet peer dependency "gatsby-plugin-sharp@^4.0.0-next".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > common > gatsby-plugin-image@2.24.0" has unmet peer dependency "gatsby-source-filesystem@^4.0.0-next".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > psychometric-success > @n8tb1t/use-scroll-position@2.0.3" has unmet peer dependency "@types/react@*".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > psychometric-success > gatsby-plugin-create-client-paths@3.14.0" has incorrect peer dependency "gatsby@^3.0.0-next.0".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > psychometric-success > gatsby-plugin-preact@6.24.0" has unmet peer dependency "preact@^10.3.4".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > psychometric-success > gatsby-plugin-preact@6.24.0" has unmet peer dependency "preact-render-to-string@^5.1.8".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > psychometric-success > gatsby-plugin-sass@4.14.0" has incorrect peer dependency "gatsby@^3.0.0-next.0".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > psychometric-success > gatsby-remark-images-datocms@0.1.2" has incorrect peer dependency "gatsby-source-datocms@^2.5.7".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > psychometric-success > gatsby-source-filesystem@3.14.0" has incorrect peer dependency "gatsby@^3.0.0-next.0".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > psychometric-success > gatsby-transformer-remark@4.11.0" has incorrect peer dependency "gatsby@^3.0.0-next.0".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > psychometric-success > gatsby-plugin-remove-trailing-slashes@3.14.0" has incorrect peer dependency "gatsby@^3.0.0-next.0".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > psychometric-success > gatsby-plugin-sitemap@3.3.0" has incorrect peer dependency "gatsby@^3.0.0-next.0".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > wikijob > gatsby-plugin-netlify@3.14.0" has incorrect peer dependency "gatsby@^3.0.0".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > wjdotcom > gatsby-plugin-google-tagmanager@3.14.0" has incorrect peer dependency "gatsby@^3.0.0-next.0".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > wjdotcom > gatsby-plugin-manifest@3.14.0" has incorrect peer dependency "gatsby@^3.0.0-next.0".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > common > @reach/router > create-react-context@0.3.0" has incorrect peer dependency "react@^0.14.0 || ^15.0.0 || ^16.0.0".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > wikijob > babel-preset-gatsby@2.24.0" has unmet peer dependency "core-js@^3.0.0".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > common > gatsby > react-server-dom-webpack@0.0.0-experimental-c8b778b7f-20220825" has incorrect peer dependency "react@0.0.0-experimental-c8b778b7f-20220825".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > psychometric-success > gatsby-plugin-preact > @prefresh/webpack@3.3.4" has unmet peer dependency "preact@^10.4.0".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > wjdotcom > gatsby-plugin-manifest > gatsby-plugin-utils@1.14.0" has incorrect peer dependency "gatsby@^3.0.0-next.0".
11:42:19 PM: warning "workspace-aggregator-958e6388-731e-4718-a471-6e3df565d573 > psychometric-success > gatsby-plugin-preact > @prefresh/webpack > @prefresh/core@1.4.1" has unmet peer dependency "preact@^10.0.0".
11:42:36 PM: [4/4] Building fresh packages...
11:42:47 PM: success Saved lockfile.
11:42:47 PM: Done in 55.56s.
11:42:47 PM: NPM modules installed using Yarn
11:42:47 PM: Started restoring cached go cache
11:42:47 PM: Finished restoring cached go cache
11:42:47 PM: Installing Go version 1.12 (requested 1.12)
11:42:51 PM: unset GOOS;
11:42:51 PM: unset GOARCH;
11:42:51 PM: export GOROOT='/opt/buildhome/.gimme/versions/go1.12.linux.amd64';
11:42:51 PM: export PATH="/opt/buildhome/.gimme/versions/go1.12.linux.amd64/bin:${PATH}";
11:42:51 PM: go version >&2;
11:42:51 PM: export GIMME_ENV="/opt/buildhome/.gimme/env/go1.12.linux.amd64.env"
11:42:51 PM: go version go1.12 linux/amd64
11:42:51 PM: Installing missing commands
11:42:51 PM: Verify run directory
11:42:53 PM:
ATTACHED COMPLETE BUILD LOG
Hi @bangash11
I noticed that you were able to move forward on that same PR, having a different error now.
Am I safe to assume this issue is different now? Can you please update us on where you are at this stage?
Thanks!
Hi @gualter,
Thank you there was some issue with gatsby-images-remarks-datocms plugin I removed that one.
Thanks! :slightly_smiling_face:
