Function timeout increase
Thanks so much Melvin!
Good morning!
Would you please extend the function timeout for site ID: 911ab3d7-ca54-42b3-841b-7df9631b91c5
Thank you!
@ab-ibrahim The function timeout for that site is already set to 26 seconds
Hi. Could I etened the funtion timeout for site ID : c05d7037-7a87-4a20-98f5-e6699db7508c. Thank you!
Hi @itsMikeLowrey :wave:t6: thanks for reaching out! I increased your function timeout. Please re-deploy to see this take effect.
Can i get increased function timeout to 26 seconds for
site id: 98b8c78d-bbc6-47b0-bbe8-5c7e3005fc3b
@Radagastno1 done! You’ll need to redeploy to see the changes take effect
@support Can you please update the function timeout to something more than 30 secs?
Site: “netberry-next”,
We are already on the pro plan.
Thanks!
Hi, the maximum function timeout is 26s. I have made this change for you. Can you please re-deploy to see this take effect?
Thanks, it has been increased.
Is there are way to upgrade the function timeout without notifying you guys? I need my site upgraded as well.
The site-id is df63af26-1c30-4c23-be48-c475e8c6d3f9
I dont mean upgraded but the limit increased please.
This is done, please re-deploy.
Please increase function timeout to 26 seconds for this site 448a7a94-dbb1-4b04-b9fd-1cb2b053d1b7
Thanks for reaching out @NGMI,
I’ve increased the function time limit to 26 seconds for your site. You’ll need to re-deploy the site for the change to take effect.
