Function not able to start
Hi all,
Today I committed a change to our go lang backend repo ( the change was a simple text description change no other code was touched ) and the deploy did build correctly however 10 minutes after the deploy has finished the server seems to no longer be able to start we are just getting this error message now again and again. We do not use an env file and provide the env vars via the netlify menus.
Nov 26, 03:15:48 PM: 106cb93e Starting server from iPad
Nov 26, 03:15:48 PM: 106cb93e Starting lambda
Nov 26, 03:15:48 PM: 106cb93e 2023/11/26 15:15:49 Starting lambda
Nov 26, 03:15:48 PM: 106cb93e INIT_REPORT Init Duration: 10010.42 ms Phase: invoke Status: error Error Type: Runtime.Unknown
Nov 26, 03:15:48 PM: 106cb93e 2023-11-26T15:15:59.017Z 106cb93e-5949-429d-9926-a7465c671b24 Task timed out after 10.01 seconds
Nov 26, 03:15:58 PM: 29b238ed Duration: 10012.70 ms Memory Usage: 23 MB
Nov 26, 03:15:58 PM: 106cb93e Duration: 10012.04 ms Memory Usage: 24 MB
Nov 26, 04:01:45 PM: ab033aa6 2023/11/26 16:01:45 Error loading .env file
Nov 26, 04:01:45 PM: ab033aa6 2023/11/26 16:01:45 Error loading .env file open .env: no such file or directory
Nov 26, 04:01:45 PM: ab033aa6 Starting server from iPad
Nov 26, 04:01:45 PM: ab033aa6 Starting lambda
Nov 26, 04:01:45 PM: ab033aa6 2023/11/26 16:01:45 Starting lambda
Nov 26, 04:01:45 PM: ab033aa6 INIT_REPORT Init Duration: 10009.43 ms Phase: init Status: timeout
Hi,
I’ve asked the devs to check this.
Thank you, we have upgraded to Pro plan and opened a support ticket.
