First deployment help?
Hi everyone. I’m new to Netlify and trying to expand my knowledge using Git to deploy sites etc. I’ve heard nothing but good things.
My initial site I want to deploy is built on Statamic which is a Laravel CMS (headless) and I’ve set my public folder and index.php as the path. However I end up getting a 404.
I’m wondering if there is something I need to do on the server for Laravel deployment? Has anyone had experience with Statamic / laravel deployment that could help me?
@niteowlcreative Welcome to the Netlify community.
Netlify serves only JAMStack sites, so no server-centric pages such as PHP will be served. You will need to convert your PHP files into HTML somewhere in your build process to have your site load over Netlify.
I know clients that have Statamic sites deployed on Netlify… I am unsure how to make that work then.
Maybe something like this?
And then, there’s this:
Well yea, I think SSG is the reason for the error. I don’t think you could access your CP if it’s static sites only with Statamic.
I was hoping it would work on Netlify, but I suppose maybe not.
