My build keeps timing out. I was reading that you can somehow change the build timeout setting but not sure how to do that. Can someone assist? Also, as a follow up question, this is my first build. Will subsequent builds take less time because the node modules will already have been installed?
Duplicate: First build is timing out
And the answer to your question is typically yes, the build cache will be maintained for subsequent builds, which should help speed things up.
