I’ve set up external domain (sozanski-design.pl) with Netlify DNS and it was working. Now it does not work, but Netlify domain (sozanski-design.netlify.app) still works.
@olafsozanski You need to check your DNS settings. I’m not seeing any DNS records for sozanski-design.pl.
Hi, @olafsozanski. This site has DNSSEC enabled but Netlify DNS does not support DNSSEC:
https://dnsviz.net/d/sozanski-design.pl/dnssec/
The solution for this will be to either:
a) disable DNSSEC for this domain
or
b) do not use Netlify DNS and use the external DNS instructions instead
