Hello, please increase timeout to max for: 420cce68-fe52-43be-9f03-c6150bca3a14
Thank you.
Thank you.
Hiya @jamesgenfitx thanks for reaching out! I have increased your function timeout to the max. Please re-deploy your site to see this take effect.
Hi there, please increase timeout to max for: 8dc54c18-e1c7-43b8-83c1-569331febf54, Thank you very much!!
Can the timeout please be extended to the maximum available for 4ae030aa-b3a2-4abf-881f-e64bd25a66a4
? Thank you
Hi @KhoaSD,
Thanks for reaching out! Iâve increased the function timeout to 26 seconds for the site. Youâll need to re-deploy for the change to take effect.
Hi @hutch78,
Thanks for reaching out! The function timeout on the site has been increased to 26 seconds (the maximum). Youâll need to redeploy the site for the change to take effect.
@Melvin TY for the quick response!
Does this apply to branch deploys such as that of my staging environment? I have a lambda that sends a request to a webbook endpopint in the site listed above, and processing of the webhook still seems to cut off after a second or two.
Hi @hutch78,
Thanks for following up. The function timeout was increased from 10 seconds to 26 seconds (the maximum) for the site, which would include the branches on the same site.
I double checked to ensure the increase did get set and do see that itâs set to 26 seconds for the site 4ae030aa-b3a2-4abf-881f-e64bd25a66a4
If youâre still having issues, could you create a new post describing exactly what happens, what error youâre seeing and how we can reproduce? Thatâll help the team do a better investigation.
Hello, Iâd like to extend the lambda timeout for 2 sites
d6c37a61-506e-4603-a28c-21d4f473b5e4
and
24d4d0ec-a194-4335-abae-3a607bc44381
Thanks in advance
Great, these two sites are all set @fvivaudo . Make sure to redeploy the sites to make the changes take effect!
Hello, please extend lambda limit for a6e77033-c164-402f-b089-fc7ef0678e4a
Thank you.
@charlottechhum @Melvin
Hi @anton.iakushyn,
Thanks for reaching out! Iâve increased the function time limit to 26 seconds for the site. Youâll need to re-deploy the site for the change to take effect.
Hello, We have a pro team plan for our company project. Can you please help us increase the function timeout limit to 26 seconds for those sites:
d3cbe7a0-5633-4581-a189-8b521cb3699e
8b208e5d-8a1a-4164-9a9b-63a8636a1518
0a69864c-eaad-4664-81c0-2e14b6ca228b
Hi there, can you please increase function timeout to the maximum 26s for the following site:
fd63601b-7ca6-4449-bd71-831971781083
Could you also let me know what the setting was set to previously?
Thank you
@tor, kindly do not duplicate yourself: Please help me increase my function timeout - #8 by tor
Is it possible for my app to increase the time limit. Iâm just using for nodemailer and sometime it takes more than 10 seconds
Please if anyone can help me, below is my site id
7113ef5a-5dd8-40c5-9c89-e6f45b10599a
Hi @Ridham2001,
We can definitely bump you up to 26 seconds, but youâll need to be on the Pro tier for us to make that change - thatâs a requirement that applies to everyone who wants a longer timeout. You can upgrade to Pro easily through the Netlify UI dashboard.
If you let us know when you have upgraded, we can change the settings for you!
Can i get the timeout limit increased for this please
8117da80-6c4a-48e4-933e-4f0372e38cbb
Hello, it looks like your account is already set at the max function timeout. Please re-deploy to see this take effect.
Hello @Melvin @hrishikesh ,
