Extend timeout for Netlify functions request
Hi @gokaka-stsys,
Thanks for reaching out! I’ve increased the function time out to 26 seconds (the maximum) for the site. You’ll need to re-deploy for this change to take effect.
Hi @Melvin, @hrishikesh I just joined the Pro Plan yet couldn’t manage to increase the timeout from 10 seconds to 26 seconds using the netlify.toml file and re-deploying the site.
Could you please help me to increase the timeout to 26 seconds for the my site?
Site ID: da153cd0-138e-46d1-88d8-0888a0de19ac
Thank you!
hi @Florian-Josselin-dev :wave:t6: thanks for reaching out and welcome to the Netlify community! :partying_face: We’re so glad you found us! I have increased your site’s function timeout to the max (26s). Please re-deploy your site to see this take effect.
Hi there, can you increase the timeout for the following site ID?
484cd68c-b25d-4ea7-abc9-83d7a8144f39
Thanks!
This is done, please re-deploy.
hello! Wanted to request a timeout increase for the following sites:
836d59a0-444f-49c2-b696-243f8c955556
4ed5b1f1-c662-4bbf-bd97-5075cbee52f2
Hi @Cybercyrus,
Thanks for reaching out! I’ve increased the function time out for both sites to 26 seconds (the maximum). You’ll need to re-deploy the two sites for the change to take effect.
325598ff-c8e0-46ce-88f1-77f43e3c9b5a
Thanks!
hey @Robin_Zimmer1 ,
This has been done. Please redeploy when you have a chance to allow the changes to take effect.
Hello dear teachers i have a problem with my own domain techinfo.uz problem>> Another site is already using this domain. verified-for-netlify TXT done! I don’t know what else to do
Hi @NurMuhammad1988,
Thanks for reaching out! We’ve responded to your thread here: Problem: another site is already using this domain - #8 by Melvin Please refer to that thread in regards to your request. Note that it’s not necessary to open or post on multiple threads for the same issue.
Hello Marcus,
Would you be kind enough to add my site ID map as well for the 26s upgrade? I just upgraded to the pro plan
55696782-6e17-49ec-8e99-08391d0249ad
Hi @anonymouspanda312,
Thanks for reaching out! I’ve increased the function time limit to 26 seconds for the site. You’ll need to re-deploy the site in order for this change to take effect.
Hello, please could you increase the timeout for the following site ID?
53d6ca1d-3d65-45b0-b3bf-589c2bf97581
Thanks!
This is a Pro and above feature.
Can you please increase functions timeout to 26s for site ID f4342e3e-4d5e-4b41-9760-5944b69a097b ?
Thank you.
hi :wave:t6: thanks for reaching out! I can see your site is already at the max function timeout (26s). Please re-deploy if you don’t see this in effect.
Ah ok, that’s what I thought, but when debugging using the local Netlify functions dev server our functions are still timing out after 10 secs locally. I read on this forum that the timeout should reflect the Netlify server config automatically if the site is linked, which it is. Any idea how I can work around this?
This is my site Name: skillaxadmin
This is mu site ID: b5b2d2a1-a339-44c2-8065-f645d2393f43
I want to increase function time out
hello, thanks for reaching out. I have increased your function timeout to 26s. You need to re-deploy your site to see this take effect.
