Hi @bo-dun , I have increased your function timeout to the max 26s. Please re-deploy to have this take effect.
Hi @bo-dun thanks for reaching out! I have increased your function timeout to 26s. You will need to re-deploy your site to see this take effect. (:
Hi @SamO
I see you tagged another user and our functions are still timing out after 10 seconds.
Can you please confirm that this has been updated for this site:
da241538-6d98-4499-95a5-041fff522b99
Thanks!
Hi, I checked again, your function timeout is set to 26s. Have you redeployed the site?
Hello! Can the timeouts for these two sites be increased?
c55adf9b-6b49-486e-bc9a-ee7f9eaf6f53
47287377-db97-47f5-a845-88f59ab2ca6e
Thank you!
Hi @SamO, sorry my bad! I sent the wrong ID!
Can you please update the timeout for this site:
797208ba-e454-4504-8c3d-028c000c4941
@Benard_Kong , @johanAgri , this is done. Please re-deploy.
Hello,
Our NextJS/Sanity site has become unusable, can you please increase our timeout as well?
Site ID: b321f0b1-fc59-41d1-b133-7225a1b3ad8f
You’re all set, I’ve increased your timeout. Please redeploy the site for the changes to take effect.
As a side note, with your account level, you can write into us directly at support and receive much faster attention! Thanks!
Thank you! Could your please provide with the contact for enterprise support? I do have a high priority request that I need to some help on.
Cheers
Hi @devs1,
Hi, the best way to contact us as an Enterprise level customer is to email support@netlify.com
from the Netlify login email associated with the Enterprise account (visible at Netlify App).
Hi,
Could I please have the timeout for my site increased?
Site ID: a8caaf5d-d8e3-46e0-92f8-eed60d0207d2
Thank you,
Hi, can I have my timeouts increased?
Site ID: a7bf1a11-c1a9-458f-8443-757fd8922636
@IPv5 , @annastrian , this is done. Please re-deploy.
Please kindly increas timeout for this site also:
Site ID: c85ebd2e-6c95-4f55-b6ff-7546fbd53333
Thanks
Hi, I’m a Pro member @Melvin @hrishikesh
can I please get the 26s timeout for functions in this app:
Site ID: 88facb4d-9c96-4303-912d-fd2c618d602d
All set! Please redeploy the site for changes to take effect. Let me know if you have any other questions.
Hello, can the timeout for this site be increased : a123666d-fa36-478f-881a-4c403f121c48 ?
Thank you!
I’ve increased the function time limit to 26 seconds for the site. You’ll need to re-deploy the site for the change to take effect.
Hi, @Melvin, @hrishikesh my team have joined the Pro Plan.
Cloud you increase our site’s function timeout to 30s?
Site ID: 62218230-be23-4837-98a1-19f18013ce5b
Thank you!
