Hello @thanh-themedguide ! I have updated the timeouts for those sites. Please redeploy each one for the changes to take effect. Thanks!
Thank you very much!
you’re very welcome!
Hello @Melvin @charlottechhum
We have a pro plan, can you increase the function timeout to max limit for the website :
63c3e255-73fa-4361-91f5-65c9d0960b83
Another question. We see we can move netlify function execution datacenter. Can you move it on Paris for the same site if it’s possible ?
Thank you for help !
Hi @LudovicBruvry,
Thanks for reaching out! I’ve changed the function region for that site to eu-west-3
(Paris). Also, I saw that the function time limit was already set to 26 seconds (the maximum).
If you’re seeing timeouts, I recommend going through this Support Guide to troubleshoot the issue:
Hi @Melvin and @charlottechhum,
It would be possible to upgrade the function time limit to 26 seconds for this site: 7be778f3-44e8-4c52-a1ea-ffdf88308a8e
? We have an enterprise plan.
Hello, please can I increase my site’s timeout limit to 26s?
My site ID is: aea47c76-48df-407f-a344-2e3bfacb5bac
Thanks,
Dan
Thank you for your help !
Hi @Girgetto,
Thank you for reaching out. I’ve increased the function time limit for the site you mentioned to 26 seconds. You’ll need to re-deploy for this change to take effect. Thanks!
Hi @danieloj,
Thanks for reaching out and welcome to Netlify’s Support Forums!
I’ve increased the function time limit for the site to 26 seconds. Please re-deploy the site for the change to take effect.
Hi there, can you increase my sites timeout limit to 26s (or more), thanks!
fa953a79-7f6a-402d-a1c6-e87d3547ceda
3ad65c1d-36ed-46e5-8180-563b6ade42d8
Hi @ncprojectbe,
Thanks for reaching out! I’ve increased the function timelimit for both sites to 26 seconds (the maximum). Please re-deploy both sites in order for the change to take effect.
thank you so much Melvin!
Hi @ncprojectbe, you’re welcome. I hope you have a great day!
Hello @Melvin,
can you please increase time out for our site: 293ffaa8-a241-4b3a-82bc-70413bfee963
Thanks
Hey there @cwolff
I’ve gone ahead and increased the function timeout. You should just have to redeploy for the changes to take effect.
Hello @Melvin
Could you please increase the time limit for this website as well?
15900911-17f0-4c5c-8149-f4860d7135f5
Is there a way for me to increase it myself? Would be great to have this setting in the UI
Hi @finally_awake,
I’ve increased the function time limit to 26 seconds (the maximum) for that site. Please re-deploy the site for the change to take effect. There’s no way to currently increase the time limit yourself, we hope to change that in the future, but I don’t have a timeframe for when it will be available.
Hello! @Melvin Pro member here, could you possibly increase the timeout to 26 seconds for this site. All the best and thank you in advance!!!
a69c90ba-67be-455e-8ae9-fbd3956e24ad
Done, please re-deploy.
