Hey there, @stuntbox
It looks like stuntbox does not have a credit card on file. Please let us know once you add a credit card so that we can go ahead and complete this increase for you.
Thanks!
Thanks!
Thatās odd! Iām looking under billing/general for my org right now and I have a credit card entered and appearing in the āBilling Informationā section. Is there somewhere else that information should be?
hi there! got it - not sure what was happening before, but we do see a payment method and you are now bumped up to a 1 hour buiid time.
Thanks so much for the quick follow-up. Really appreciate it!
Iām looking at getting my build time increased to 60 mins for stupefied-shockley-17183b please. Would that be possible? Iāve updated the card on file in the billing section.
Thanks
Thanks so much! Much appreciated
Hello, I also need more minutes because my build wonāt pass otherwise.
My app: codeally.io
Hereās the link to the thread I made: More build time
hi there adam,
we can definitely bump up your build timeout if you would like us to, but what i am seeing in your build log seems unrelated to build times:
5:56:13 AM: Failing build: Failed to build site
5:56:13 AM: Finished processing build request in 13m0.180560435s
if the issue were related to build times, weād see that reflected in the total build time number there at the bottom. if you search for ā137ā you will see there are a number of topics on this issue, maybe there is something in there that is helpful for you to troubleshoot!
this is a nice general guide you might take a look at:
Can i have an update on that? I still have issues due to not enough build time.
hi there @Elatardev , we have bumped you up to 1 hr build time, can you try again and see if your builds go through now?
Hi, can someone please increase build time for site d738e1a2-4027-4fc4-a012-278353270aea to 1h minimum please.
we got you bumped - you are now at 30 mins, enjoy!
Thank you for the fast response! That was enough and the build went through.
@perry Iām a bit worried that Iām seeing this error although it says Published:
Error running command: Command did not finish within the time limit
Total time: Build time: 48m 33s. Total deploy time: 51m 5s
Can we increase the time limit a bit further please? Afraid we might encounter the error soon.
hi there, you are now at 1hr! if you need to go 1hr, we can potentially do that, but iād recommend chatting with our sales team first as there may be a custom build package that might work out cheaper for you than extending your build time continously
Thank you. Appreciate it!
