Extend 15min max build time to 30min
Hello everyone.
Am in the process of migrating from gatsby.
Could i request and increase to 45-60 minutes for site-id 674d1a21-ecda-4dae-aa6a-2a8a97b761b6 ?
My devleopers did tons of image processing it would appear :open_mouth: , i trust that once a full build has finished it’ll a ok :smile:
Thank very much.
Honorary tag @hrishikesh :innocent:
Hi @genisd,
Thanks for reaching out!
I’ve increased the build time limit to 60 minutes on the site. Please re-deploy to see this take effect.
Good day admin, I want to increase my build limit to 2hrs
site-id: 2e9914f2-f320-4fb7-a3ae-ced49acb9483
I wont mind to be paying for extra build if it can be extend beyond 2hrs
Thanks
Good Morning, could we increase the build time to 1 hour, please?
site-id: 852eb7f7-2731-4e8d-aeb1-ae7b617a9259
Thanks!
Hi @AidanFlaunt , I have bumped you up to 1 hour!
@SamO hi, could you extend the build time on f6d01cd2-3ef3-49fc-be61-31fa29c756c6 to an hour please?
thanks very much
john
Yep! Just bumped you up to a 1 hour build limit.
hiya @tillytillie1 !
I’m not clear that changing your timelimit would help. It looks to me like you are starting a server during our build process which is not how we intend our CI to be used. Can you explain more about the site you are trying to build so we can guide you in improving your use of our build system rather than just giving the current process longer to fail, which wouldn’t serve our purposes well?
Thanks
Hi again Tilly,
Please answer my above question before we adjust your build timeout at all. I need to know more about the website you are building first.
I just dive into web3 and am just testing my account to be listening to incoming transaction on block then notify me via console once any transaction is detected.
This is not how our system is intended to be used, Tilly. Our CI system is intended to build websites, not run servers. See this doc for more information: [Support Guide] Can I run a web server, HTTP listener, and/or database at Netlify?
I think you’ll want to find a different service that intends for you to run servers, such as heroku.
wonderful, thank you
Hi, could you bump the limit to 45 minutes for site id 3aaa0988-04d1-4468-986b-c649e584f9d9, please? Thank you!
@absolute-developers done!
Hi, could you extend the build time limit on my site(site id: ec433035-f6d4-44d7-909f-c01089c3fa46) to 2 hours?
Thanks
That’s a high build timeout can you explain what you intend to be doing with your site?
I am using the gatsby application and it requires a long build time if there is no cache because it retrieves a lot of image files from wordpress.
When I build with Gatsby Cloud it could take more than 1.5 hours. I would like to have the limit extended to 2 hours just to be safe.
@y.masuda, this is done.
I can confirm that the limit has been extended. Thank you.
