I need an extension to a 45min build for this site:
9418419e-4756-49a6-93a0-8ea0e2bd69e4
Thank you!
Thank you!
Hey @jhull,
We have increased the build time limit for the slash-data account to 45 minutes. Please let us know if this addresses your build issues! If it doesn’t, I recommend looking through these resources: [Support Guide] Compiled Build and Deploy Resources -- start here!
can you extend the build time limit to 1 hour for the site with the id 66f9b416-4897-4775-a1aa-652806512ed7
Thank you
Hi guys, can you increase the build time to 1 hour for the sites under the responsible-ai-collaborative
team?
Thanks!
This is done. Can you re-deploy to see this in effect?
It works, thank you very much!
Hello! Can you please increase the build time to 1 hour for the site: 1a3ec1b4-3ac3-4d78-9925-30c1ca3d3b7e
Thank you
Hi you need to be a pro tier or higher to get it bumped.
can please extend to 30m or 1hr for brilliant-dieffenbachia-13cb8d only recently started getting “command did not finish within the time limit” errors. Thanks,
Hi @SamO @hrishikesh I’m reaching my build time limits. Please can you increase it for both of my sites to 1 hour?
The site IDs are “eaebc32a-3f68-4cee-92f7-5c00ee917b1e” and “9adc3f3f-b252-438c-8bbd-9d26da73a468”.
Thanks in advance!
Hi, yes I have updated your build timeout. Please re-deploy to see this take effect.
@SamO Thanks so much! I can confirm everything is working as expected now. Looks like it’s been suggested before but it’d be great if we had the ability to update the build time limit ourselves via site settings
@SamO Hi could you extend the build time on 32b73c38-b969-42d4-a783-f5d032904182 to an hour please? thanks very much, John
Hi, thanks for reaching out! I have upgraded your build timeout limit. Please re-deploy to see this take effect?
wonderful, thank you
Hi, this may sound excessive but could we get our build timeout adjusted to 3hrs for SiteID: d62878ea-a2da-45d6-93b8-1abf5ef7e2b9. Just migrating a large Gatsby build and the initial build take ages.
Hi @gendall,
3 hours sounds a little close to platform limits. I have pushed it to 2.5 hours for you.
Thanks for that. Would there be any support (either Netlify or Gatsby) I could talk to about large initial builds and how to provision best to get them to run as quickly as possible? It’s not a problem once it’s built and we’re doing incremental builds.
