Here is my code:
That’s the current Dashboard I’m getting with code above:
What am I doing wrong here? I wanna be able to edit the title and text.
Thanks in advance!
Here is my code:
Thanks in advance!
Hi @Nevzat-dev,
collections:
- name: "home"
label: "Home"
folder: "../../src/Content"
folder
needs to be relative to root of repo not root of config file. Could you try changing that?
For editing non-repeatable data in a single json file, you probably want to use a file collection as well:
You have to let the CMS know you’re using json if you’re using a folder collection. Markdown is the default value.
Thanks. It works now.
I am glad everything is working now, @Nevzat-dev. @tomrutgers, thanks for the awesome insight heres. We are grateful for your expertise
