Thanks for your patience! I don’t see a 404 when I load your site-- are you still encountering obstacles? If you are, can you please share the edge function you are using?
Hi @restieauxbro! @ewanvalentine and me looked into this, and it seems like the __default is not defined problem stems from a bundling error around some code that calls some Supabase endpoints. Could you share a small reproduction repository with us? That’d make it easier for us to get to the ground of it.
Looked into it some more, and it looks like the edge function causing the error is not the one you mentioned above, but one called programme-search. Could you check if that also works in local development?
