Good Day.
I searched and didn’t come up with any relevant answers or clues.
AstroJS 5.0.4
I was trying to debug why a remote image wasn’t loading. I suddenly started receiving the This edge functon has crashed.
An unhandled error in the function code triggered the following message:
uncaught exception during edge function invocation
Connection details
Netlify internal ID: 01JF0B9PHAK8HFXGQ63FTP38BN
So I figured it was something I did. So I re-fetched the remote repo to get back to where everything was prior to my image debugging. I’m still getting the error.
The edge function log:
Dec 13, 10:47:37 AM: 01JF0B8E info [Astro Middleware] LocalsReassigned: `locals` can not be assigned directly.
at Object.set locals (file:///root/.netlify/v1/edge-functions/middleware/middleware.mjs:2937:13)
at entry_default (file:///root/.netlify/v1/edge-functions/middleware/middleware.mjs:2985:14)
at file:///root/src/bootstrap/function_chain.ts:426:15
at AsyncLocalStorage.run (node:async_hooks:69:14)
at FunctionChain.runFunction (file:///root/src/bootstrap/function_chain.ts:420:28)
at FunctionChain.run (file:///root/src/bootstrap/function_chain.ts:324:31)
at handleRequest (file:///root/src/bootstrap/handler.ts:148:34)
at file:///root/src/bootstrap/server.ts:39:7
at ext:deno_http/00_serve.ts:369:24
at ext:deno_http/00_serve.ts:569:29 {
loc: undefined,
title: "`locals` must not be reassigned.",
hint: "Set a `locals` property instead.",
frame: undefined,
type: "AstroError",
The same build works fine with netlify dev
and I build locally and netlify deploy
which crashes the edge function.
Here’s the relevant section of astro.config.mjs:
// i tried the /functions from another support thread. neither are solving the issue.
//import netlify from "@astrojs/netlify";
import netlify from "@astrojs/netlify/functions"
export default defineConfig({
adapter: netlify({
edgeMiddleware: true,
imageCDN: true,
and my netlify.toml:
[functions]
directory = "netlify/functions" # Points to your custom functions directory
[[redirects]]
from = "/posts/*"
to = "/.netlify/functions/builder"
status = 200
force = true
I do not have any files in /netlify/functions
Any ideas?
I tried deploying to a new site by drag and drop the /dist folder after building, but still getting the same edge function crashed error.
Thanks.
