Domains go up and down without any control, SSL issues
Problem: All of my domains go up and down like crazy without any control. It literally can be, that one second the url is working and the next it’s not. I’m doing all tests with fresh incognito mode with multiple devices.
It might be that the primary domain works and alias does not. Or the other way around. It might be that with www the domain works and the root does not, or vice versa. And they all keep switching up and down.
The usual reason for site being down is “ERR_SSL_PROTOCOL_ERROR”
Let’s encrypt SSL/TLS certificate gives all green. I’ve tried renewing. While it renews itself just fine, the issue does not disappear at all.
I’ve tried all I have know-how for and I’m out of juice. Reaching out for help here, thank you.
Site: https://rootskehoterapia.netlify.app/
Custom domains: rootskehoterapia.fi (primary), rootskehoterapia.online (alias), www.rootskehoterapia.fi, www.rootskehoterapia.online
Domain service provider: Zoner
External DNS verifiers like DNSChecker or DNSSpy give all green.
A is set to 75.2.60.5, CNAME to rootskehoterapia.netlify.app. AAAA is also set to IP6. Zoner does not support Aliases, hence the IP for A / AAAA
I’ve routed this to our helpdesk, we’ll follow up via email.
