Domain-level redirects do not work for aliases with https and wildcard
Hello! I’m seeing an issue where the following redirects do not work.
Site: https://rad-cm.netlify.app
Framework: Astro 2.2.0
https://rad-cm.netlify.app/*          https://rad.cm/:splat       301!
https://www.christianpetty.com/*      https://rad.cm/:splat       301!
https://christianpetty.com/*          https://rad.cm/:splat       301!
https://www.radianrad.com/*           https://rad.cm/:splat       301!
https://radianrad.com/*               https://rad.cm/:splat       301!
https://www.radianrd.com/*            https://rad.cm/:splat       301!
https://radianrd.com/*                https://rad.cm/:splat       301!
https://www.radian.ltd/*              https://rad.cm/:splat       301!
https://radian.ltd/*                  https://rad.cm/:splat       301!
https://www.radian.llc/*              https://rad.cm/:splat       301!
https://radian.llc/*                  https://rad.cm/:splat       301!
I’m wondering if this is an Astro issue since the following redirects do work:
https://wiki.radianrad.com/*        https://bb.rad.cm                                       301!
https://radian.wiki/*               https://bb.rad.cm                                       301!
https://wiki.rad.cm/*               https://bb.rad.cm                                       301!
hi there, before we dig in, did you see this brand new guide on debugging redirects?
I strongly suggest you give it a thorough read through and see if this fixes your problem:
if not, please post again, and we’ll try and troubleshoot.
None of these worked for me.
Hello! Yes I followed that. The rules are created without error, but it’s looking like none of the domain-level ones are working.
I moved one of the lines to a fresh new Netlify site along with that subdomain and it works, so maybe this setup specifically.
Here’s the full _redirects build output:
https://wiki.radianrad.com/Tools/Tolerance+stack+analysis       https://bb.rad.cm/t/tolerance-analysis/133         301!
https://onshape.rad.cm/*            https://bb.rad.cm/t/about-onshape-cad/182               301!
https://mathcad.rad.cm/*            https://bb.rad.cm/t/ptc-mathcad/77                      301!
https://qr.rad.cm       https://rad.cm/                           301!
https://fire.christianpetty.com       https://rad.cm/fire         301!
/qr								      https://qr.rad.cm				   		            301!
/portfolio                        /file/100010G%20RAD%20Portfolio.pdf             301!
/resume                           /file/christian_petty_resume.pdf                301!
/ty/*                               https://bb.rad.cm/:splat                      301!
/s/*                                https://bb.rad.cm/search?q=:splat             301!
/search/*                           https://bb.rad.cm/search?q=:splat             301!
/mathcad                            https://bb.rad.cm/t/ptc-mathcad/77                      301!
/met  								              https://bb.rad.cm/t/mathcad-excel-tool/61         	    301!
/hello          /.netlify/functions/hello                         200
/rand_color     /.netlify/functions/random_hex_color              200
/calc/thread-profile*    /threads:splat                           301!
/tools/thread-profile*   /threads:splat                           301!
/tools/log*              /log:splat                               301!
/             /.netlify/edge-functions/entry    200
/calc-test    /.netlify/edge-functions/entry    200
/contact      /.netlify/edge-functions/entry    200
/success      /success/index.html               200
/threads      /.netlify/edge-functions/entry    200
/coils        /.netlify/edge-functions/entry    200
/fire         /.netlify/edge-functions/entry    200
/math         /.netlify/edge-functions/entry    200
/404          /404.html                         200
/log          /.netlify/edge-functions/entry    200
/ip           /.netlify/edge-functions/entry    200
Ah, curiously https://radian.llc does not redirect. Nor does https://radian.llc/contact
But https://radian.llc/123456, or https://radian.llc/abcdef (indeed any random URL that isn’t an actual page) does.
My best guess is that Astro is causing the issue.
Thank you, I’ve got an issue with Astro open now.
