Home
Support Forums
Does Netlify has number of sites limitation per pricing tier?
Hello Netlify experts.
I’m working on a NodeJS app (will be a backend API for our SaaS platform) that generates static websites and deploys results to Netlify via REST API.
I think we have a simple flow, generate a static website, deploy the result to CDN, and set a custom domain with SSL certificate (or get it from Let’s Encrypt) for it.
We are planning to host 100-1000 websites, maybe more :slight_smile:
Does this feasible with Netlify, if yes what pricing tier should I choose, and what limitations I should put into account?
Also, the critical point is Netlify Rest API allows to deploy generated website files without a git repository.
Thanks
Hi there, @ygrik :wave:
Thanks for reaching out, and welcome to the Netlify Forums :netliconfetti:
You can check out our extensive pricing page here that should answer these questions in better details. Please let me know if you have additional questions after reading this!
Hi Hillary,
Thank you for the quick reply.
As I understand from the pricing page there is no limit for websites number, we should just track bandwidth (100GB/month for Starter, 400GB/month for Pro, etc ).
Is it normal if one member has thousands of websites?
What SLA do you have for Pro tier?
Hi there, @ygrik
Thanks for reaching out! You will find SLA information on that pricing page as well in the bottom Support category :slight_smile:
Given the information you have shared, I have reached out to our team that specializes in answering questions about plans that can fit a variety of needs! They will also be able to further discuss bandwidth and site count with you. Stay tuned to your email :netliconfetti:
