- We need to know your netlify site name. Example:
gifted-antelope-58b104.netlify.app
- DNS issues? Tell us the custom domain, tell us the error message! We can’t help if we don’t know your domain.
- Build problems? Link or paste the FULL build log & build settings screenshot
- Did you try Ask Netlify, our generative AI chatbot, before posting? It pulls info from Support Guides and recent solved forums posts
hello good this morning buy domain in ionos and link it with netlify with the 4 dns all this to work with lovable the problem I have is that the changes I make are not reflected in the domain and sometimes it gives me privacy error,sometimes I try incognito and you see the changes and other times I have not verified that the dns were good and the dispersion is correct
