I deployed a build which is working on another netlify deployment, to a custom domain (marketplug.app)
The build deployed successfully, but when I go to http://marketplug.app - I get the following error:
“This site can’t be reached
marketplug.app’s server IP address could not be found.”
As per your documents - I looked the site up on Google’s Dig tool. I got the following message:
id 3930
opcode QUERY
rcode SERVFAIL
flags QR RD RA
;QUESTION
marketplug.app. IN NS
;ANSWER
;AUTHORITY
;ADDITIONAL
Based on this code - is there a problem with the configuration? I did this the exact same way I did another custom domain which took a few minutes to build.
It’s been nearly 2 hours.
Should I wait and see, or is there something fundamentally wrong based on the DIG message above?
I’m using Google Domains. As I understand it, it’s simply a matter of pasting the Netlify nameservers i.e ‘dns1.p05.nsone.net’ into the UI on Google domains after going through the Netlify DNS setup process. This is what I did for a previous domain and it worked fine. Maybe I’m forgetting a step?
