Home
Support Forums
Deployment stuck at "Starting Up"
I have my Netlify site connected to my GitHub and have enabled automatic deployments from master branch. However, the deployment is stuck on the “Starting Up” phase. Even with a manual deployment, I get nowhere. I’ve never had this problem before. What could be the issue?
Hi @DavetheDev
I have experienced this issue a few times. Not entirely sure what the cause is. The solution I use is to cancel the deploy then trigger a new deploy.
I also have the same issue, I’ve been deploying my github repo 3 hours earlier without a problem and my latest update somehow got stuck at “Build ready to start” even cancelling and redeploying doesn’t make any changes.
I believe this is related to an ongoing incident:
https://www.netlifystatus.com
Somehow it’s working now
Yes, according to the incident, the builds are pending in a backlog. They’ll soon be in sync.
Update: It should be resolved. Do let us know if you’re still seeing issues.
