Deployed Slack Bolt Python backend but its return page not found? can we deploy python on Netlify and if can then how to deploy it?
  • https://ahaai.netlify.app
  • as I mentioned previously it’s a Python backend for Slack app built on Slack Bolt. Bolt is a Slack SDK.
  • I deploy it and visits the end points it gives me 404 page not found error
Hi there,
Did you see this guide yet? This is the best place to start for “Page Not Found” issues.
If you are still seeing issues after following the troubleshooting steps in there, please check out this Support Guide as well. It outlines all of our build and deploy resources and will get you on the right track :slight_smile:
If none of the above resources help, please write back with your site name and what steps you have tried and we can look into this further!
I have come across this guide before and found it to be very helpful. However, my main challenge was serving Python.
  • as I mentioned previously it’s a Python backend for Slack app built on Slack Bolt (python). Bolt is a Slack SDK.
Netlify doesn’t support Python backends.
