Home
Support Forums
Deploy Failed: "Failed during stage 'building site': Build script returned non-zero exit code: 1"
Hello, I am having an issue with deploying my site to netlify. I am using the sanity-gatsby blog starter. Been tweaking it locally, and everything was working fine. When I committed my changes to my repo, and deployed my site on netlify I got the following errors. I must have done something wrong…I am new to all of this and would greatly appreciate any help. Thank you!
1:27:00 PM: Build ready to start
1:27:02 PM: build-image version: 0582042f4fc261adc7bd8333f34884959c577302
1:27:02 PM: build-image tag: v3.7.6
1:27:02 PM: buildbot version: 25525176e9a3fd4732ec80c06d9af2d602b3de9c
1:27:02 PM: Building without cache
1:27:02 PM: Starting to prepare the repo for build
1:27:03 PM: No cached dependencies found. Cloning fresh repo
1:27:03 PM: git clone git@github.com:mxysaj/launchblog
1:27:06 PM: Preparing Git Reference refs/heads/main
1:27:06 PM: Parsing package.json dependencies
1:27:07 PM: Different build dir detected, going to use the one specified in the Netlify configuration file: '' versus '/' in the Netlify UI
1:27:07 PM: Starting build script
1:27:07 PM: Installing dependencies
1:27:07 PM: Python version set to 2.7
1:27:08 PM: v12.18.0 is already installed.
1:27:09 PM: Now using node v12.18.0 (npm v6.14.4)
1:27:09 PM: Started restoring cached build plugins
1:27:09 PM: Finished restoring cached build plugins
1:27:09 PM: Attempting ruby version 2.7.1, read from environment
1:27:11 PM: Using ruby version 2.7.1
1:27:11 PM: Using PHP version 5.6
1:27:11 PM: Started restoring cached node modules
1:27:11 PM: Finished restoring cached node modules
1:27:11 PM: Installing NPM modules using NPM version 6.14.4
1:27:31 PM: npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
1:27:31 PM: > sanity-gatsby-blog@1.0.17 postinstall /opt/build/repo
1:27:31 PM: > lerna bootstrap
1:27:31 PM: lerna notice cli v3.22.1
1:27:31 PM: lerna info ci enabled
1:27:31 PM: lerna info Bootstrapping 2 packages
1:27:31 PM: lerna info Installing external dependencies
1:27:32 PM: lerna ERR! npm ci exited 1 in 'blog-with-gatsby-studio'
1:27:32 PM: lerna ERR! npm ci stderr:
1:27:32 PM: npm ERR! cipm can only install packages when your package.json and package-lock.json or npm-shrinkwrap.json are in sync. Please update your lock file with `npm install` before continuing.
1:27:32 PM: npm ERR! Missing: @sanity/code-input@^2.9.0
1:27:32 PM: npm ERR! A complete log of this run can be found in:
1:27:32 PM: npm ERR!     /opt/buildhome/.npm/_logs/2021-06-15T09_27_32_785Z-debug.log
1:27:32 PM: lerna WARN complete Waiting for 1 child process to exit. CTRL-C to exit immediately.
1:27:32 PM: npm ERR! code ELIFECYCLE
1:27:32 PM: npm ERR! errno 1
1:27:32 PM: npm ERR! sanity-gatsby-blog@1.0.17 postinstall: `lerna bootstrap`
1:27:32 PM: npm ERR! Exit status 1
1:27:32 PM: npm ERR! Failed at the sanity-gatsby-blog@1.0.17 postinstall script.
1:27:32 PM: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
1:27:32 PM: npm ERR!     /opt/buildhome/.npm/_logs/2021-06-15T09_27_32_903Z-debug.log
1:27:32 PM: Error during NPM install
1:27:32 PM: Build was terminated: Build script returned non-zero exit code: 1
1:27:32 PM: Creating deploy upload records
1:27:33 PM: Failing build: Failed to build site
1:27:33 PM: Failed during stage 'building site': Build script returned non-zero exit code: 1
1:27:33 PM: Finished processing build request in 30.878369855s
Hi @m_90,
I’d advise to try removing package-lock.json from your repo and retrying to see if it makes a difference.
Hi @hrishikesh , thank you for your reply. If I understand you correctly, I should delete the package-lock.json from my repo, commit changes and then retry deploying?
According to the error, yes, it seems like package-lock.json is the offending file (unless you have the other one that the logs mention).
Thank you for your help. I tried removing the file, but no luck. Any idea why?
10:00:38 PM: Build ready to start
10:00:49 PM: build-image version: 0582042f4fc261adc7bd8333f34884959c577302
10:00:49 PM: build-image tag: v3.7.6
10:00:49 PM: buildbot version: 77f6cd099df893d1381a2962ebcc1926e092a904
10:00:49 PM: Fetching cached dependencies
10:00:49 PM: Starting to download cache of 94.3MB
10:00:50 PM: Finished downloading cache in 1.483693903s
10:00:50 PM: Starting to extract cache
10:00:54 PM: Finished extracting cache in 3.667191387s
10:00:54 PM: Finished fetching cache in 5.190936479s
10:00:54 PM: Starting to prepare the repo for build
10:00:55 PM: Preparing Git Reference refs/heads/main
10:00:56 PM: Parsing package.json dependencies
10:00:56 PM: Different build dir detected, going to use the one specified in the Netlify configuration file: '' versus '/' in the Netlify UI
10:00:57 PM: Starting build script
10:00:57 PM: Installing dependencies
10:00:57 PM: Python version set to 2.7
10:00:57 PM: Started restoring cached node version
10:01:00 PM: Finished restoring cached node version
10:01:01 PM: v12.18.0 is already installed.
10:01:01 PM: Now using node v12.18.0 (npm v6.14.4)
10:01:01 PM: Started restoring cached build plugins
10:01:01 PM: Finished restoring cached build plugins
10:01:02 PM: Attempting ruby version 2.7.1, read from environment
10:01:03 PM: Using ruby version 2.7.1
10:01:03 PM: Using PHP version 5.6
10:01:03 PM: Started restoring cached node modules
10:01:03 PM: Finished restoring cached node modules
10:01:04 PM: Started restoring cached go cache
10:01:04 PM: Finished restoring cached go cache
10:01:04 PM: go version go1.14.4 linux/amd64
10:01:04 PM: Installing missing commands
10:01:04 PM: Verify run directory
10:01:05 PM: ​
10:01:05 PM: ────────────────────────────────────────────────────────────────
10:01:05 PM:   Netlify Build
10:01:05 PM: ​
10:01:05 PM: ❯ Version
10:01:05 PM:   @netlify/build 12.2.0
10:01:05 PM: ​
10:01:05 PM: ❯ Flags
10:01:05 PM:   deployId: 60c8eaab8dd60f0007855b16
10:01:05 PM: ​
10:01:05 PM: ❯ Current directory
10:01:05 PM:   /opt/build/repo
10:01:05 PM: ​
10:01:05 PM: ❯ Config file
10:01:05 PM:   No config file was defined: using default values.
10:01:05 PM: ​
10:01:05 PM: ❯ Context
10:01:05 PM:   production
10:01:05 PM: ​
10:01:05 PM:   1. Build command from Netlify app
10:01:05 PM: ​
10:01:05 PM: $ npm run build
10:01:05 PM: > sanity-gatsby-blog@1.0.17 build /opt/build/repo
10:01:05 PM: > lerna run build --parallel
10:01:05 PM: lerna notice cli v3.22.1
10:01:05 PM: lerna info ci enabled
10:01:06 PM: lerna info Executing command in 2 packages: "npm run build"
10:01:06 PM: blog-with-gatsby-studio: > blog-with-gatsby-studio@1.0.15 build /opt/build/repo/studio
10:01:06 PM: blog-with-gatsby-studio: > sanity build
10:01:06 PM: blog-with-gatsby-web: > blog-with-gatsby-web@1.0.7 build /opt/build/repo/web
10:01:06 PM: blog-with-gatsby-web: > gatsby build
10:01:06 PM: blog-with-gatsby-web: sh: 1: gatsby: not found
10:01:06 PM: blog-with-gatsby-web: npm ERR! code ELIFECYCLE
10:01:06 PM: blog-with-gatsby-web: npm ERR! syscall spawn
10:01:06 PM: blog-with-gatsby-web: npm ERR! file sh
10:01:06 PM: blog-with-gatsby-web: npm ERR! errno ENOENT
10:01:06 PM: blog-with-gatsby-web: npm ERR! blog-with-gatsby-web@1.0.7 build: `gatsby build`
10:01:06 PM: blog-with-gatsby-web: npm ERR! spawn ENOENT
10:01:06 PM: blog-with-gatsby-web: npm ERR! Failed at the blog-with-gatsby-web@1.0.7 build script.
10:01:06 PM: blog-with-gatsby-web: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
10:01:06 PM: blog-with-gatsby-web: npm WARN Local package.json exists, but node_modules missing, did you mean to install?
10:01:06 PM: blog-with-gatsby-web: npm ERR! A complete log of this run can be found in:
10:01:06 PM: blog-with-gatsby-web: npm ERR!     /opt/buildhome/.npm/_logs/2021-06-15T18_01_06_442Z-debug.log
10:01:06 PM: lerna ERR! npm run build exited 1 in 'blog-with-gatsby-web'
10:01:06 PM: lerna ERR! npm run build stdout:
10:01:06 PM: > blog-with-gatsby-web@1.0.7 build /opt/build/repo/web
10:01:06 PM: > gatsby build
10:01:06 PM: lerna ERR! npm run build stderr:
10:01:06 PM: sh: 1: gatsby: not found
10:01:06 PM: npm ERR! code ELIFECYCLE
10:01:06 PM: npm ERR! syscall spawn
10:01:06 PM: npm ERR! file sh
10:01:06 PM: npm ERR! errno ENOENT
10:01:06 PM: npm ERR! blog-with-gatsby-web@1.0.7 build: `gatsby build`
10:01:06 PM: npm ERR! spawn ENOENT
10:01:06 PM: npm ERR! Failed at the blog-with-gatsby-web@1.0.7 build script.
10:01:06 PM: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
10:01:06 PM: npm WARN Local package.json exists, but node_modules missing, did you mean to install?
10:01:06 PM: npm ERR! A complete log of this run can be found in:
10:01:06 PM: npm ERR!     /opt/buildhome/.npm/_logs/2021-06-15T18_01_06_442Z-debug.log
10:01:06 PM: lerna WARN complete Waiting for 1 child process to exit. CTRL-C to exit immediately.
10:01:06 PM: npm ERR! errno 1
10:01:06 PM: npm ERR! sanity-gatsby-blog@1.0.17 build: `lerna run build --parallel`
10:01:06 PM: npm ERR! Exit status 1
10:01:06 PM: npm ERR! Failed at the sanity-gatsby-blog@1.0.17 build script.
10:01:06 PM: npm ERR!     /opt/buildhome/.npm/_logs/2021-06-15T18_01_06_506Z-debug.log
10:01:06 PM: ​
10:01:06 PM: ────────────────────────────────────────────────────────────────
10:01:06 PM:   "build.command" failed
10:01:06 PM: ​
10:01:06 PM:   Error message
10:01:06 PM:   Command failed with exit code 1: npm run build
10:01:06 PM: ​
10:01:06 PM:   Error location
10:01:06 PM:   In Build command from Netlify app:
10:01:06 PM:   npm run build
10:01:06 PM: ​
10:01:06 PM:   Resolved config
10:01:06 PM:   build:
10:01:06 PM:     base: /opt/build/repo
10:01:06 PM:     command: npm run build
10:01:06 PM:     commandOrigin: ui
10:01:06 PM:     environment:
10:01:06 PM:       - SANITY_DEPLOY_STUDIO_TOKEN
10:01:06 PM:     publish: /opt/build/repo/web/public
10:01:06 PM:   functions:
10:01:06 PM:     '*': {}
10:01:06 PM: Caching artifacts
10:01:06 PM: Started saving node modules
10:01:06 PM: Finished saving node modules
10:01:06 PM: Started saving build plugins
10:01:06 PM: Finished saving build plugins
10:01:06 PM: Started saving pip cache
10:01:07 PM: Finished saving pip cache
10:01:07 PM: Started saving emacs cask dependencies
10:01:07 PM: Finished saving emacs cask dependencies
10:01:07 PM: Started saving maven dependencies
10:01:07 PM: Finished saving maven dependencies
10:01:07 PM: Started saving boot dependencies
10:01:07 PM: Finished saving boot dependencies
10:01:07 PM: Started saving rust rustup cache
10:01:07 PM: Finished saving rust rustup cache
10:01:07 PM: Started saving go dependencies
10:01:07 PM: Finished saving go dependencies
10:01:07 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
10:01:07 PM: Creating deploy upload records
10:01:07 PM: Failing build: Failed to build site
10:01:07 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2
10:01:07 PM: Finished processing build request in 18.187527646s
Does your package.json list gatsby in dependencies?
yes.
"dependencies": {
    "@sanity/block-content-to-react": "^2.0.7",
    "@sanity/image-url": "^0.140.22",
    "date-fns": "^2.19.0",
    "gatsby": "^3.0.3",
    "gatsby-image": "^2.0.41",
    "gatsby-plugin-image": "^1.0.0",
    "gatsby-plugin-postcss": "^4.0.0",
    "gatsby-plugin-react-helmet": "^4.0.0",
    "gatsby-source-sanity": "^7.0.2",
    "react": "^17.0.2",
    "react-dom": "^17.0.2",
    "react-helmet": "^6.1.0",
    "react-syntax-highlighter": "^15.4.3"
Well that’s a bummer. Would it be possible for you to share your repo?
sure, https://github.com/mxysaj/launchblog.git
You need all the dependencies to exist in your top-level package.json which is not the case:
Netlify only installs the dependencies listed here and not in sub-folders.
Your’e right, because when I created a new repo and installed all the dependencies it worked!
Thanks a lot.
