Deploy failed (could not read Username for 'https://github.com')
Hello :slight_smile: my build Failed and this is the log and the link
Any idea why is happening that? I didn’t change anything :confused:
12:53:30 PM: Build ready to start
12:53:32 PM: build-image version: 1ac2360cf8aee6cb2695dd2682b312fefc908a7f (xenial)
12:53:32 PM: build-image tag: v3.15.0
12:53:32 PM: buildbot version: 4cf36a87393f464ce4306dd5bb696c9270afa3ef
12:53:32 PM: Fetching cached dependencies
12:53:32 PM: Failed to fetch cache, continuing with build
12:53:32 PM: Starting to prepare the repo for build
12:53:32 PM: User git error while checking for ref refs/heads/master
12:53:33 PM: Creating deploy upload records
12:53:33 PM: Failing build: Failed to prepare repo
12:53:33 PM: Failed during stage 'preparing repo': error checking for ref: fatal: could not read Username for '[https://github.com](https://github.com/)': No such device or address
: exit status 128
12:53:33 PM: Finished processing build request in 803.560391ms
Hey there, @93lucasp :wave:
Thanks for reaching out. Can you try reconnecting the repo and seeing if that solves the issue?
In the app settings, go to Build & Deploy > Build Settings > Edit Settings > Link to a different repository and select the same repo.
Keep us posted!
