I got this error when I push & auto-deploy. (it worked fine 1 month before)
It seems I have some depreciated dependencies and missing files, but I could not find the reason.
※I tried to remove package.json and run npm install to recreate package.json on local ENV, but I still get the same error.
‘Build Settings’
Command : hugo --theme=hugo-tranquilpeak-theme --buildDrafts
Build Log
Failed during stage ‘building site’: Build script returned non-zero exit code: 1
ENOENT: no such file or directory, open ‘./package-lock.json’
hey there, we do need a package.json in with your github repo in most cases. We don’t explicitly require the package-lock file, but it is a good idea to commit it as it contains information about packages that are installed locally, it helps make sure we keep things in sync and in a working configuration.
It’s fine to delete it (the package.json file) from the repo and recreate locally, but you do want to add it back in and push it to wherever you are storing your repo so that we can parse it and download the correct dependencies for your project. Can you add it back in and see if the error goes away?
