Home
Support Forums
Deploy fail, please help
Hi @Aniekan_Udo
It appears you have specified npm run build as a build command however the build does not exist.
A build script would go in a package.json file, but only if you have something to build. You don’t need to build anything as your git repository has a single HTML file in it.
Also note, the single file is resume.html which when deployed will result in a page not found. You will need to rename resume.html to index.html. Note that if you are deploying a site that does not need building, you could use drag and drop.
