Custom domain stuck in provisioning state — blocks domain removal via dashboard and API
Project: nave-ferias-desportivas
Site ID: 899330ae-88f3-4a19-be8c-607422161f04
Domain in question: navepadel.com (currently set as primary custom domain)
similar issue reported here
Issue:
This project’s certificate is stuck in “provisioning” and has blocked all
domain changes for several weeks.
The SSL/TLS panel reports:
“DNS verification failed — navepadel.com doesn’t appear to be served by Netlify”
But every attempt to remove or change the domain — via the dashboard, and via
a direct API call (PATCH /api/v1/sites/{id} with custom_domain and
domain_aliases, using a personal access token with full write scope) —
returns the identical error:
“We’re provisioning a certificate for your site, you cannot change custom
domains until that process completes”
navepadel.com is intentionally hosted on Squarespace and was never meant to
point at Netlify — it was added to this project by mistake. Since the API
call fails identically to the dashboard, the lock appears to be enforced
server-side.
Could someone please manually remove the domain from this project so the
correct subdomain can be set as primary and receive its own certificate? The
subdomain itself works correctly over http — only https and the domain
cleanup are blocked.
