The time for post processing is huge for me too. Could you guys disable it for api id 8c434f9b-d801-4e8f-a5b5-6f091576f748
please?
thanks!
please?
thanks!
Hi @fool and @perry, can you help me disable post processing for the following API IDs as well?
On a side note, should really have the form processing option on the dashboard for this so we don’t have to always trouble you guys. Thanks in advance!
All 3 have had form post-processing disabled, @SMUMods. The feature’s there and pending; we appreciate the feedback!
Hi @perry and @fool, can you be so kind to disable all post-processing on:
627867b0-4e51-4238-b478-13e996c658ec
I also have two “active” forms that is not being used (file-upload and contact), if you can remove those from the dashboard as well that would be great.Thank you!
we took care of that for you!
hey all,
a quick note that we have added the functionality to be able to disable forms post processing through the UI
More info:
As a result, I’m going to close this thread to avoid duplication. If you have comments, please pop them on that thread
