Hi @Zerotask,
While this gets investigated, could you see if setting the config option helps:
Basically, you can do something like:
netlifyIdentity.init({
APIUrl: 'https://my-new-url.netlify.app/.netlify/identity'
Hi @Zerotask,
I also have the same issue. I cloned a Next.js + Netlify CMS template from this repo: GitHub - wutali/nextjs-netlify-blog-template: Next.js blogging template for Netlify Follwed the setup but it seems everything was setup already. However, I still got that “email not confirmed” issue.
Hi @trz,
You can turn on auto-confirm from Identity settings and confirm the email address of the required users as soon as they signup.
You saved my live. Thanks!
Thanks you Tom!
The mail template version is obviously the cleanest option. Unfortunately it’s not available in the Starter package. So instead of loading the widget for all users I came up with a simple redirect instead. Something like:
useEffect(() => {
if (window.location.hash.includes('_token=')) {
window.location.replace('/admin/' + window.location.hash)
works quite nicely
I just created a Nextjs App and the init()
is in my context
and the whole site is wrapped inside the context
so I believe that’s the root.
I’m having the email not confirmed
I have tried some of the twerks here and nothing is working.
i tried opening the token url in a private window https://gamfew.netlify.app/#confirmation_token=3gUzdj9a...
but still nothing
hi there, sorry it has been a little while. have you made any progress with this?
Thanks for this elbotho - this “behaviour” confused me for a long time.
I wonder if another quicker and cleaner work-around (before this issue is either fixed or referenced clearly in the docs) would be to allow a starter package to change the path to template…
Is this something a passing netlify support person could consider? [requesting hopefully!]
To clarify, email templates were available on the starter plan in the past, but were removed a few months ago due to abuse of such high magnitude that it affected a part of our service. So, looking at that, it’s unlikely that this will be reversed any time soon.
Thanks hrishikesh - I wasn’t aware of the context before your note
