Command was killed with SIGKILL (Forced termination): gatsby build
The error doesn’t say too much, but here is the build log:
https://app.netlify.com/sites/cesar-aiid-staging/deploys/62fac6ff1686a80009eeb831
is there any way to debug this? or see a more detailed log? Looks like something is swallowing the error.
thanks
hi there,
did you search the forums for the term “sigkill”? that might give you some insight into potential scenarios that can cause this:
https://answers.netlify.com/search?q=SIGKILL
i suggest looking through those responses, and if there isn’t anything there that helps, please do post again.
