Home
Support Forums
Client Side Routing not working on Netlify
I tried deploying a React application on Netlify with client routing, but Netlify says the ‘404’ page was not found. This is not the first time stuff as this happens, I have deployed 2 client-side applications with proper routing that worked here but the latest deployment is not working. I really thought it was my application, so I checked all the files but no error, and I deployed to Vercel and it worked!. Please this should be resolved.
I will be glad if this is solved so I can move my applications here. Thank you. I await solutions.
hi there, do you have a redirects file? can you tell us a little more about how you are doing your routing? thanks.
