Certificate provisioning stuck >48h — khwahish.ai.in (site: tangerine-fox-16c694)
Subject: Certificate provisioning stuck >48h — khwahish.ai.in (site: tangerine-fox-16c694)
Hi,
My custom domain khwahish.ai.in has been unable to provision a Let’s Encrypt certificate for over 48 hours. DNS verification reports success, but no certificate is ever issued and the Force HTTPS option never becomes available.
Site: tangerine-fox-16c694
Primary domain: khwahish.ai.in
Alias: www.khwahish.ai.in
DNS: Netlify DNS (nameservers dns1-4.p01.nsone.net, delegated at registrar ConnectReseller)
What I have already verified:
  • Both khwahish.ai.in and www.khwahish.ai.in show green “Netlify DNS” status in Domain management, with no warnings.
  • DNSSEC is disabled at the registrar — the DS record table is empty.
  • I have removed both domains and re-added them; this did not resolve the issue.
  • ai.in is present in the ICANN section of the Public Suffix List, so this should not be a per-registered-domain rate limit.
Could you check the actual error returned by the ACME order for this domain? I suspect a CAA lookup failure somewhere in the khwahish.ai.in / ai.in / .in chain, since that would not be visible from the dashboard.
The domain was registered on 31 July 2026, so it is new — if there is a registry-side issue with the ai.in zone I would appreciate knowing, so I can decide whether to move the domain elsewhere.
Thanks,
Khwahish Sheikh
