Home
Support Forums
Certificate problems
The certificate provided is working on 1/2 of devices tested on. Can you please repair the certificate in acordance with the following:
It is possible that we will get a certificate for one name (for example, petsofnetlify.com ) and not for another (for example, www.petsofnetlify.com or some domain alias). In this case selecting Renew certificate should resolve the issue. If it doesn‘t, please post in the Netlify Support Forums so our support engineers can repair the certificate.
@hmmmm
The SSL certificate works on both your bare domain dynamicnetworktoken.com and the www subdomain.
If you are still having issues, I believe they are local issues only.
Reposting of Ssl_error_bad_cert_domain
Hi, @hmmmm. I also checked all the IP addresses we currently use and all of them returned the correct SSL certificate.
If you are getting a bad SSL certificate, please let us know what IP address is returning the wrong certificate and we then be able to research what the cause is.
Hi,
I think it’s my local network. Seems to be working when testing from other networks.
