Hi Netlify Support,
I’m unable to provision a Let’s Encrypt certificate for my custom domain. “Verify DNS configuration” passes successfully, but clicking “Provision certificate” returns:
“certificate parameter is required when updating an existing certificate”
Project details
- Project name: maggiestax
- Netlify subdomain: maggiestax.netlify.app
- Site ID: ffa6049f-82e9-42a9-bc71-a10bdfd9e1ed
- Custom domain: maggiestax.com (primary)
- Domain alias: www.maggiestax.com
- DNS provider: External (Cloudflare, records set to DNS only / grey cloud)
DNS records
- A @ 75.2.60.5
- A @ 99.83.231.61
- CNAME www maggiestax.com
What I have already verified
- “Verify DNS configuration” returns successful in the UI
- No AAAA records on either hostname
- No CAA records on the domain or any parent
- http://maggiestax.com/.well-known/acme-challenge/ returns a 404 served by Netlify (confirmed via the “server: Netlify” response header and an x-nf-request-id). Same result for www. So the HTTP-01 challenge path reaches your edge over port 80 un-redirected.
- The domain currently serves the default *.netlify.app wildcard certificate, so visitors get a hostname mismatch and a browser security warning.
Background
This domain previously pointed to GoDaddy, then moved to Cloudflare DNS, and has now been repointed to Netlify. I believe the original provisioning attempt failed while DNS was still pointed elsewhere, leaving a stale certificate record attached to the project. I’ve seen a number of other forum threads reporting this same error with the same cause.
Request
Could a support engineer please clear/reset the TLS certificate state on this project so I can provision a fresh Let’s Encrypt certificate covering both maggiestax.com and www.maggiestax.com?
This is a live client site currently showing a security warning to visitors, so a quick turnaround would be much appreciated.
Thank you.
