Hi,
I’m trying a POC with Docusaurus and sending the build to Netlify. I have been able to build locally without any problem.
I set the parameters when creating my deployment like this:
Here is my deployment log:
Deploy log
2:53:26 PM: Build ready to start
2:53:27 PM: build-image version: 4c0c1cadee6a31c9bb8d824514030009c4c05c6a (focal)
2:53:27 PM: build-image tag: v4.15.0
2:53:27 PM: buildbot version: 44377b3b6a4027dd8a09c3df7d29646ce9192423
2:53:27 PM: Fetching cached dependencies
2:53:27 PM: Failed to fetch cache, continuing with build
2:53:27 PM: Starting to prepare the repo for build
2:53:27 PM: No cached dependencies found. Cloning fresh repo
2:53:27 PM: git clone git@bitbucket.org:russ1/master
2:53:28 PM: Preparing Git Reference refs/heads/OM_Netlify_POC
2:53:29 PM: Parsing package.json dependencies
2:53:29 PM: Different build dir detected, going to use the one specified in the Netlify configuration file: ‘’ versus ‘/’ in the Netlify UI
2:53:29 PM: Section completed: initializing
2:53:30 PM: Starting build script
2:53:30 PM: Installing dependencies
2:53:30 PM: Python version set to 2.7
2:53:30 PM: v16.18.1 is already installed.
2:53:30 PM: Now using node v16.18.1 (npm v8.19.2)
2:53:30 PM: Enabling node corepack
2:53:31 PM: Started restoring cached build plugins
2:53:31 PM: Finished restoring cached build plugins
2:53:31 PM: Attempting ruby version 2.7.2, read from environment
2:53:31 PM: Using ruby version 2.7.2
2:53:31 PM: Using PHP version 8.0
2:53:31 PM: Started restoring cached go cache
2:53:31 PM: Finished restoring cached go cache
2:53:32 PM: Installing Go version 1.19.3 (requested 1.19.x)
2:53:37 PM: unset GOOS;
2:53:37 PM: unset GOARCH;
2:53:37 PM: export GOROOT=‘/opt/buildhome/.gimme/versions/go1.19.3.linux.amd64’;
2:53:37 PM: export PATH=“/opt/buildhome/.gimme/versions/go1.19.3.linux.amd64/bin:${PATH}”;
2:53:37 PM: go version >&2;
2:53:37 PM: export GIMME_ENV=“/opt/buildhome/.gimme/env/go1.19.3.linux.amd64.env”
2:53:37 PM: go version go1.19.3 linux/amd64
2:53:37 PM: Detected 0 framework(s)
2:53:37 PM: Installing missing commands
2:53:37 PM: Verify run directory
2:53:39 PM:
2:53:39 PM: ────────────────────────────────────────────────────────────────
2:53:39 PM: Netlify Build
2:53:39 PM:
2:53:39 PM: ❯ Version
2:53:39 PM: @netlify/build 28.4.0
2:53:39 PM:
2:53:39 PM: ❯ Flags
2:53:39 PM: baseRelDir: true
2:53:39 PM: buildId: 637e8846acf33a4ec6a9c2f2
2:53:39 PM: deployId: 637e8846acf33a4ec6a9c2f4
2:53:39 PM:
2:53:39 PM: ❯ Current directory
2:53:39 PM: /opt/build/repo
2:53:39 PM:
2:53:39 PM: ❯ Config file
2:53:39 PM: No config file was defined: using default values.
2:53:39 PM:
2:53:39 PM: ❯ Context
2:53:39 PM: production
2:53:39 PM:
2:53:39 PM: 1. Build command from Netlify app
2:53:39 PM:
2:53:39 PM: $ npm run build
2:53:39 PM: npm ERR! code ENOENT
2:53:39 PM: npm ERR! syscall open
2:53:39 PM: npm ERR! path /opt/build/repo/package.json
2:53:39 PM: npm ERR! errno -2
2:53:39 PM: npm ERR! enoent ENOENT: no such file or directory, open ‘/opt/build/repo/package.json’
2:53:39 PM: npm ERR! enoent This is related to npm not being able to find a file.
2:53:39 PM: npm ERR! A complete log of this run can be found in:
2:53:39 PM: npm ERR! /opt/buildhome/.npm/_logs/2022-11-23T20_53_39_544Z-debug-0.log
2:53:39 PM:
2:53:40 PM: Creating deploy upload records
2:53:39 PM: “build.command” failed
2:53:39 PM:
2:53:39 PM: Error message
2:53:40 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
2:53:39 PM: Command failed with exit code 254: npm run build (Search results for '"non-zero exit code: 254"' - Netlify Support Forums)
2:53:39 PM:
2:53:39 PM: Error location
2:53:39 PM: In Build command from Netlify app:
2:53:39 PM: npm run build
2:53:39 PM:
2:53:39 PM: Resolved config
2:53:39 PM: build:
2:53:39 PM: base: /opt/build/repo
2:53:39 PM: command: npm run build
2:53:39 PM: commandOrigin: ui
2:53:39 PM: publish: /opt/build/repo/build
2:53:39 PM: publishOrigin: ui
2:53:40 PM: Caching artifacts
2:53:40 PM: Started saving build plugins
2:53:40 PM: Finished saving build plugins
2:53:40 PM: Started saving pip cache
2:53:40 PM: Finished saving pip cache
2:53:40 PM: Started saving emacs cask dependencies
2:53:40 PM: Finished saving emacs cask dependencies
2:53:40 PM: Started saving maven dependencies
2:53:40 PM: Finished saving maven dependencies
2:53:40 PM: Started saving boot dependencies
2:53:40 PM: Finished saving boot dependencies
2:53:40 PM: Started saving rust rustup cache
2:53:40 PM: Finished saving rust rustup cache
2:53:40 PM: Started saving go dependencies
2:53:40 PM: Finished saving go dependencies
2:53:40 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
2:53:40 PM: Failing build: Failed to build site
2:53:41 PM: Finished processing build request in 13.701072704s
any help is greatly appreciated! Thanks so much!
Russ
