Home
Support Forums
Build timeout at 15 minutes
I am running into an issue with a build timeout error after 15 minutes. Is it possible to increase the build time settings?
site: emprezzo
Yup! Tis done. (There is no way for you to self-serve on it, so we have to do it for you)
Hi, can you bump up the build limit to 30 mins for our site as well? The site is called delta-landing-page.
Hi @ashwin-delta,
It has been done!
Thanks @hrishikesh !
