Build still fails after case fixed
My build failed because of a case naming error. But after fixing the case error I’m still receiving the same exact error. I was wondering if anyone knew what else could be causing the build to fail.
Thanks.
Hi @SJellen,
The error does seem to be the case-sensitivity one. However, since you say you’ve already fixed it, is there a chance the changes are not yet reflected in your repo? There are cases where you update the case locally, but the repo doesn’t reflect the change.
If it’s still not helping, maybe you’ve indeed added a wrong path or the file has not been added to Git?
All these are just guesses and it’s not possible to say what it is exactly without actually having a look at the repo. If the above steps don’t help, do let us know.
