Build fails from webhook (storyblok) but works if I clear cache and deploy manually
I have a SSG Nuxt 3 project that is connected to a CMS (Storyblok). Netlify App
Until recently all builds were fine, now all of a sudden build fails when triggered by Storyblok webhook.
From the errors it occurs during the prerendering phase.
However if I clear cache and retry the failed build, it works. (sometimes it takes 2 retries for it to work)
Could it be a timeout or caching issue?
Failed build: Netlify App
Successful build: Netlify App
Steps I have done:
  • deleted and reinstalled package-lock and node modules
  • re-linked the repo
  • added &clear_cache=true param to webhook
Any help would be greatly appreciated!
Problem solved - it was rate limit issue.
