The build error is as follows:
6:05:07 PM: Build ready to start
6:05:11 PM: build-image version: b0258b965567defc4a2d7e2f2dec2e00c8f73ad6
6:05:11 PM: build-image tag: v3.4.1
6:05:11 PM: buildbot version: fcbc7a79f7372e5995cf02954ef19fc48d20c871
6:05:11 PM: Building without cache
6:05:11 PM: Starting to prepare the repo for build
6:05:12 PM: No cached dependencies found. Cloning fresh repo
6:05:12 PM: git clone https://github.com/quizinc-nitd/quizink1
6:05:13 PM: Preparing Git Reference refs/heads/master
6:05:14 PM: Starting build script
6:05:14 PM: Installing dependencies
6:05:14 PM: Python version set to 2.7
6:05:30 PM: Version '12.18.0' not found - try `nvm ls-remote` to browse available versions.
6:05:30 PM: Failed to install node version '12.18.0'
6:05:30 PM: Error running command: Build script returned non-zero exit code: 1
6:05:30 PM: Failing build: Failed to build site
6:05:30 PM: Failed during stage 'building site': Build script returned non-zero exit code: 1
6:05:30 PM: Finished processing build request in 18.590193961s
I have used hugo server
locally and the website builds without any issues. Same with hugo -D
. Any help will be appreciated.
My repo can be seen here.
Build settings can be seen here:
Thanks in advance!
PS: I see now that there is some third-party error on Netlify’s end regarding node installations.
PPS: Looks like it’s resolved now
