PLI deployed a page on github pages and it is working fine but deploying it on netlify fails I updated the build settings to CI= npm run build and added environment variables but still it shows a a blank page.
It depends on what you’re working with, but you should hunt for references to my-portfolio as once your site is deployed it isn’t being served from that directory.
@ayush91985 I cannot tell you what you should do step by step, nor can I advise what to change in your github repo (or Netlify settings) as I cannot see any of those things… you’ve not provided them.
If you want someone to be more specific, you need to provide more detail/access yourself.
As @hrishikesh highlighted your error, you are importing your pdf wrongly. To fix it, navigate to your file at /src/components/Resume/ResumeNew.js and then change your pdf import to the below
import pdf from "../../Assets/Soumyajit_Behera-BIT_MESRA.pdf";
