Blank page when deploying a react project
Blank page when deploying a react project.
repository git : https://github.com/Joash-star/mimi.git
My site url: https://quirky-wing-2513a1.netlify.com/
hi there,
when i pull up your site, I have JS errors showing in the developer console.
https://docs.netlify.com/configure-builds/file-based-configuration/#sample-file
Looks like you are having some CORS errors - you might finding setting a content policy header useful in this context.
getting same error
My site url: gracious-kirch-9536e4.netlify.app
Hiya, sorry you are having trouble with your build.
This Support Guide contains a ton of useful debugging tips that can likely help you solve your problem :slight_smile:
We also recommend trying to search the forums with the build error you encountered - it’s likely your question was already asked by someone else!
It seems likely that your site is not building or deploying correctly, but I also suggest you review your build settings to make sure you are pointing at the correct page.
