Hello, guys,
The builds work fine on my local machine. When deployed, I get posts without content.
We’re using Jigsaw site builder.
Site name: apis3-banqi-website.netlify.app
We need help, troubleshooting this.
Thanks in advance.
Deploy logs:
5:32:49 PM: Build ready to start
5:33:04 PM: build-image version: ca811f47d4c1cbd1812d1eb6ecb0c977e86d1a1d
5:33:04 PM: build-image tag: v3.3.20
5:33:04 PM: buildbot version: 0ee111aa6b75403f01f5d27b0a6736d30a2da28c
5:33:04 PM: Fetching cached dependencies
5:33:05 PM: Starting to download cache of 418.9MB
5:33:07 PM: Finished downloading cache in 2.214231857s
5:33:07 PM: Starting to extract cache
5:33:16 PM: Finished extracting cache in 9.391496684s
5:33:16 PM: Finished fetching cache in 11.775049284s
5:33:16 PM: Starting to prepare the repo for build
5:33:17 PM: Preparing Git Reference refs/heads/master
5:33:19 PM: Starting build script
5:33:19 PM: Installing dependencies
5:33:19 PM: Python version set to 2.7
5:33:20 PM: Started restoring cached node version
5:33:23 PM: Finished restoring cached node version
5:33:24 PM: v12.18.3 is already installed.
5:33:25 PM: Now using node v12.18.3 (npm v6.14.6)
5:33:25 PM: Started restoring cached build plugins
5:33:25 PM: Finished restoring cached build plugins
5:33:25 PM: Attempting ruby version 2.7.1, read from environment
5:33:27 PM: Using ruby version 2.7.1
5:33:27 PM: Using PHP version 7.4
5:33:27 PM: 5.2 is already installed.
5:33:27 PM: Using Swift version 5.2
5:33:27 PM: Started restoring cached node modules
5:33:27 PM: Finished restoring cached node modules
5:33:27 PM: Installing NPM modules using NPM version 6.14.6
5:33:37 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/browser-sync/node_modules/fsevents):
5:33:37 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
5:33:37 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.12 (node_modules/fsevents):
5:33:37 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
5:33:37 PM: audited 1328 packages in 8.794s
5:33:38 PM: 36 packages are looking for funding
5:33:38 PM: run npm fund
for details
5:33:38 PM: found 1 low severity vulnerability
5:33:38 PM: run npm audit fix
to fix them, or npm audit
for details
5:33:38 PM: NPM modules installed
5:33:38 PM: Started restoring cached composer dependencies
5:33:38 PM: Finished restoring cached composer dependencies
5:33:40 PM: Loading composer repositories with package information
5:33:40 PM: Installing dependencies (including require-dev) from lock file
5:33:41 PM: Package operations: 31 installs, 0 updates, 0 removals
5:33:41 PM: - Installing doctrine/inflector (1.3.1): Loading from cache
5:33:41 PM: - Installing erusev/parsedown (1.7.4): Loading from cache
5:33:41 PM: - Installing hamcrest/hamcrest-php (v2.0.0): Loading from cache
5:33:41 PM: - Installing voku/portable-ascii (1.4.10): Loading from cache
5:33:41 PM: - Installing symfony/translation-contracts (v2.0.1): Loading from cache
5:33:41 PM: - Installing symfony/polyfill-mbstring (v1.15.0): Loading from cache
5:33:41 PM: - Installing symfony/translation (v5.0.8): Loading from cache
5:33:41 PM: - Installing nesbot/carbon (2.33.0): Loading from cache
5:33:41 PM: - Installing psr/simple-cache (1.0.1): Loading from cache
5:33:41 PM: - Installing psr/container (1.0.0): Loading from cache
5:33:41 PM: - Installing illuminate/contracts (v7.9.2): Loading from cache
5:33:41 PM: - Installing illuminate/support (v7.9.2): Loading from cache
5:33:41 PM: - Installing illuminate/container (v7.9.2): Loading from cache
5:33:41 PM: - Installing illuminate/events (v7.9.2): Loading from cache
5:33:41 PM: - Installing symfony/finder (v5.0.8): Loading from cache
5:33:41 PM: - Installing illuminate/filesystem (v7.9.2): Loading from cache
5:33:41 PM: - Installing samdark/sitemap (2.2.1): Loading from cache
5:33:41 PM: - Installing symfony/polyfill-php73 (v1.15.0): Loading from cache
5:33:41 PM: - Installing symfony/service-contracts (v2.0.1): Loading from cache
5:33:41 PM: - Installing symfony/polyfill-ctype (v1.15.0): Loading from cache
5:33:41 PM: - Installing phpoption/phpoption (1.7.3): Loading from cache
5:33:41 PM: - Installing vlucas/phpdotenv (v4.1.4): Loading from cache
5:33:41 PM: - Installing symfony/yaml (v4.4.8): Loading from cache
5:33:41 PM: - Installing symfony/var-dumper (v5.0.8): Loading from cache
5:33:41 PM: - Installing symfony/process (v5.0.8): Loading from cache
5:33:41 PM: - Installing symfony/console (v5.0.8): Loading from cache
5:33:41 PM: - Installing mockery/mockery (1.3.1): Loading from cache
5:33:41 PM: - Installing mnapoli/front-yaml (1.6.0): Loading from cache
5:33:41 PM: - Installing michelf/php-markdown (1.9.0): Loading from cache
5:33:41 PM: - Installing illuminate/view (v7.9.2): Loading from cache
5:33:41 PM: - Installing tightenco/jigsaw (v1.3.26): Loading from cache
5:33:42 PM: symfony/translation suggests installing symfony/config
5:33:42 PM: illuminate/support suggests installing moontoast/math (Required to use ordered UUIDs (^1.1).)
5:33:42 PM: illuminate/support suggests installing ramsey/uuid (Required to use Str::uuid() (^3.7|^4.0).)
5:33:42 PM: illuminate/filesystem suggests installing illuminate/http (Required for handling uploaded files (^7.0))
5:33:42 PM: illuminate/filesystem suggests installing league/flysystem (Required to use the Flysystem local and FTP drivers (^1.0).)
5:33:42 PM: illuminate/filesystem suggests installing league/flysystem-aws-s3-v3 (Required to use the Flysystem S3 driver (^1.0).)
5:33:42 PM: illuminate/filesystem suggests installing league/flysystem-cached-adapter (Required to use the Flysystem cache (^1.0).)
5:33:42 PM: illuminate/filesystem suggests installing league/flysystem-sftp (Required to use the Flysystem SFTP driver (^1.0).)
5:33:42 PM: illuminate/filesystem suggests installing psr/http-message (Required to allow Storage::put to accept a StreamInterface (^1.0))
5:33:42 PM: symfony/service-contracts suggests installing symfony/service-implementation
5:33:42 PM: symfony/console suggests installing psr/log (For using the console logger)
5:33:42 PM: symfony/console suggests installing symfony/event-dispatcher
5:33:42 PM: symfony/console suggests installing symfony/lock
5:33:42 PM: Generating autoload files
5:33:42 PM: 12 packages you are using are looking for funding.
5:33:42 PM: Use the composer fund
command to find out more!
5:33:42 PM: Started restoring cached go cache
5:33:42 PM: Finished restoring cached go cache
5:33:42 PM: go version go1.14.4 linux/amd64
5:33:42 PM: Installing missing commands
5:33:42 PM: Verify run directory
5:33:43 PM:
5:33:43 PM: ┌─────────────────────────────┐
5:33:43 PM: │ Netlify Build │
5:33:43 PM: └─────────────────────────────┘
5:33:43 PM:
5:33:43 PM: ❯ Version
5:33:43 PM: @netlify/build 3.1.5
5:33:43 PM:
5:33:43 PM: ❯ Flags
5:33:43 PM: deployId: 5f2874712764440007394530
5:33:43 PM: mode: buildbot
5:33:43 PM: timersFile: /tmp/substage_times.txt
5:33:43 PM:
5:33:43 PM: ❯ Current directory
5:33:43 PM: /opt/build/repo
5:33:43 PM:
5:33:43 PM: ❯ Config file
5:33:43 PM: /opt/build/repo/netlify.toml
5:33:43 PM:
5:33:43 PM: ❯ Context
5:33:43 PM: production
5:33:43 PM:
5:33:43 PM: ┌────────────────────────────────────┐
5:33:43 PM: │ 1. build.command from netlify.toml │
5:33:43 PM: └────────────────────────────────────┘
5:33:43 PM:
5:33:43 PM: $ npm run production
5:33:44 PM: > @ production /opt/build/repo
5:33:44 PM: > cross-env NODE_ENV=production node_modules/webpack/bin/webpack.js --progress --hide-modules --env=production --config=node_modules/laravel-mix/setup/webpack.config.js
5:33:46 PM: [webpack.Progress] 0% compiling
5:33:46 PM: [webpack.Progress] 10% building 0/0 modules 0 active
5:33:46 PM: [webpack.Progress] 10% building 0/1 modules 1 active multi /opt/build/repo/node_modules/laravel-mix/src/builder/mock-entry.js
5:33:46 PM: [webpack.Progress] 10% building 1/1 modules 0 active
5:33:46 PM: [webpack.Progress] 10% building 1/2 modules 1 active /opt/build/repo/node_modules/laravel-mix/src/builder/mock-entry.js
5:33:46 PM: [webpack.Progress] 10% building 2/2 modules 0 active
5:33:46 PM: [webpack.Progress] 70% building 2/2 modules 0 active
5:33:46 PM: [webpack.Progress] 70% finish module graph
5:33:46 PM: [webpack.Progress] 70% finish module graph FlagDependencyExportsPlugin
5:33:46 PM: [webpack.Progress] 70% finish module graph WasmFinalizeExportsPlugin
5:33:46 PM: [webpack.Progress] 70% sealing
5:33:46 PM: [webpack.Progress] 70% sealing WarnCaseSensitiveModulesPlugin
5:33:46 PM: [webpack.Progress] 72% basic dependencies optimization
5:33:46 PM: [webpack.Progress] 72% dependencies optimization
5:33:46 PM: [webpack.Progress] 72% dependencies optimization SideEffectsFlagPlugin
5:33:46 PM: [webpack.Progress] 72% dependencies optimization FlagDependencyUsagePlugin
5:33:46 PM: [webpack.Progress] 73% advanced dependencies optimization
5:33:46 PM: [webpack.Progress] 73% after dependencies optimization
5:33:46 PM: [webpack.Progress] 71% chunk graph
5:33:46 PM: [webpack.Progress] 71% after chunk graph
5:33:46 PM: [webpack.Progress] 71% after chunk graph WebAssemblyModulesPlugin
5:33:46 PM: [webpack.Progress] 74% optimizing
5:33:46 PM: [webpack.Progress] 74% basic module optimization
5:33:46 PM: [webpack.Progress] 75% module optimization
5:33:46 PM: [webpack.Progress] 75% advanced module optimization
5:33:46 PM: [webpack.Progress] 76% after module optimization
5:33:46 PM: [webpack.Progress] 76% basic chunk optimization
5:33:46 PM: [webpack.Progress] 76% basic chunk optimization EnsureChunkConditionsPlugin
5:33:46 PM: [webpack.Progress] 76% basic chunk optimization RemoveParentModulesPlugin
5:33:46 PM: [webpack.Progress] 76% basic chunk optimization RemoveEmptyChunksPlugin
5:33:46 PM: [webpack.Progress] 76% basic chunk optimization MergeDuplicateChunksPlugin
5:33:46 PM: [webpack.Progress] 77% chunk optimization
5:33:46 PM: [webpack.Progress] 77% advanced chunk optimization
5:33:46 PM: [webpack.Progress] 77% advanced chunk optimization SplitChunksPlugin
5:33:46 PM: [webpack.Progress] 77% advanced chunk optimization RemoveEmptyChunksPlugin
5:33:46 PM: [webpack.Progress] 77% after chunk optimization
5:33:46 PM: [webpack.Progress] 78% module and chunk tree optimization
5:33:46 PM: [webpack.Progress] 78% after module and chunk tree optimization
5:33:46 PM: [webpack.Progress] 79% basic chunk modules optimization
5:33:46 PM: [webpack.Progress] 80% chunk modules optimization
5:33:46 PM: [webpack.Progress] 80% chunk modules optimization ModuleConcatenationPlugin
5:33:46 PM: [webpack.Progress] 80% advanced chunk modules optimization
5:33:46 PM: [webpack.Progress] 81% after chunk modules optimization
5:33:46 PM: [webpack.Progress] 81% module reviving
5:33:46 PM: [webpack.Progress] 81% module reviving RecordIdsPlugin
5:33:46 PM: [webpack.Progress] 82% module order optimization
5:33:46 PM: [webpack.Progress] 82% module order optimization OccurrenceOrderModuleIdsPlugin
5:33:46 PM: [webpack.Progress] 82% advanced module order optimization
5:33:46 PM: [webpack.Progress] 83% before module ids
5:33:46 PM: [webpack.Progress] 83% before module ids HashedModuleIdsPlugin
5:33:46 PM: [webpack.Progress] 83% module ids
5:33:46 PM: [webpack.Progress] 84% module id optimization
5:33:46 PM: [webpack.Progress] 85% chunk reviving
5:33:46 PM: [webpack.Progress] 85% chunk reviving RecordIdsPlugin
5:33:46 PM: [webpack.Progress] 85% chunk order optimization
5:33:46 PM: [webpack.Progress] 85% chunk order optimization OccurrenceOrderChunkIdsPlugin
5:33:46 PM: [webpack.Progress] 86% before chunk ids
5:33:46 PM: [webpack.Progress] 86% chunk id optimization
5:33:46 PM: [webpack.Progress] 86% chunk id optimization FlagIncludedChunksPlugin
5:33:46 PM: [webpack.Progress] 87% after chunk id optimization
5:33:46 PM: [webpack.Progress] 87% record modules
5:33:46 PM: [webpack.Progress] 87% record modules RecordIdsPlugin
5:33:46 PM: [webpack.Progress] 87% record chunks
5:33:46 PM: [webpack.Progress] 87% record chunks RecordIdsPlugin
5:33:46 PM: [webpack.Progress] 88% hashing
5:33:46 PM: [webpack.Progress] 88% after hashing
5:33:46 PM: [webpack.Progress] 89% record hash
5:33:46 PM: [webpack.Progress] 89% module assets processing
5:33:46 PM: [webpack.Progress] 90% chunk assets processing
5:33:46 PM: [webpack.Progress] 90% additional chunk assets processing
5:33:46 PM: [webpack.Progress] 91% recording
5:33:46 PM: [webpack.Progress] 92% additional asset processing
5:33:46 PM: [webpack.Progress] 92% chunk asset optimization
5:33:46 PM: [webpack.Progress] 92% chunk asset optimization TerserPlugin
5:33:46 PM: [webpack.Progress] 92% chunk asset optimization OptimizeCssAssetsWebpackPlugin
5:33:46 PM: [webpack.Progress] 93% after chunk asset optimization
5:33:46 PM: [webpack.Progress] 93% after chunk asset optimization SourceMapDevToolPlugin
5:33:46 PM: [webpack.Progress] 93% after chunk asset optimization SourceMapDevToolPlugin mix.js generate SourceMap
5:33:46 PM: [webpack.Progress] 93% after chunk asset optimization SourceMapDevToolPlugin resolve sources
5:33:46 PM: [webpack.Progress] 93% after chunk asset optimization SourceMapDevToolPlugin mix.js attach SourceMap
5:33:46 PM: [webpack.Progress] 93% asset optimization
5:33:46 PM: [webpack.Progress] 94% after asset optimization
5:33:46 PM: [webpack.Progress] 94% after seal
5:33:46 PM: [webpack.Progress] 95% emitting
5:33:46 PM: [webpack.Progress] 95% emitting unnamed compat plugin
5:33:46 PM: [webpack.Progress] 95% emitting OptimizeCssAssetsWebpackPlugin
5:33:46 PM: [webpack.Progress] 98% after emitting
5:33:46 PM: [webpack.Progress] 98% after emitting SizeLimitsPlugin
5:33:46 PM: DONE Compiled successfully in 511ms8:33:46 PM
5:33:46 PM: [webpack.Progress] 100%
5:33:46 PM: Asset Size Chunks Chunk Names
5:33:46 PM: mix.js.map 4.52 KiB 0 [emitted] [dev] mix
5:33:48 PM:
5:33:48 PM: (build.command completed in 4.9s)
5:33:48 PM:
5:33:48 PM: ┌─────────────────────────────┐
5:33:48 PM: │ Netlify Build Complete │
5:33:48 PM: └─────────────────────────────┘
5:33:48 PM:
5:33:48 PM: (Netlify Build completed in 4.9s)
5:33:48 PM: Caching artifacts
5:33:48 PM: Started saving node modules
5:33:48 PM: Finished saving node modules
5:33:48 PM: Started saving build plugins
5:33:48 PM: Finished saving build plugins
5:33:48 PM: Started saving pip cache
5:33:48 PM: Finished saving pip cache
5:33:48 PM: Started saving emacs cask dependencies
5:33:48 PM: Finished saving emacs cask dependencies
5:33:48 PM: Started saving maven dependencies
5:33:48 PM: Finished saving maven dependencies
5:33:48 PM: Started saving boot dependencies
5:33:48 PM: Finished saving boot dependencies
5:33:48 PM: Started saving composer dependencies
5:33:48 PM: Finished saving composer dependencies
5:33:48 PM: Started saving go dependencies
5:33:48 PM: Finished saving go dependencies
5:33:48 PM: Build script success
5:33:48 PM: Starting to deploy site from ‘build_production’
5:33:49 PM: Creating deploy tree asynchronously
5:33:49 PM: Creating deploy upload records
5:33:51 PM: 34 new files to upload
5:33:51 PM: 0 new functions to upload
5:33:52 PM: Starting post processing
5:33:52 PM: Post processing - HTML
5:33:58 PM: Post processing - redirect rules
5:33:58 PM: Post processing - header rules
5:33:58 PM: Post processing done
5:33:59 PM: Site is live
5:34:34 PM: Finished processing build request in 1m29.605358742s
