Best Gitignore Code For Hugo?
Dear All
I have this code for my root gitignore files ->
/public/
/resources/_gen/
hugo.exe
hugo.linux
hugo.darwin
But I still curious if it’s the best gitignore or not for Hugo building time process?
Regards
Hi @BayuAngora!
In regards of .gitignore files I usually just check out the actual project. Have a look at https://github.com/gohugoio/hugo/blob/master/.gitignore to get an overview of what they exclude from Git.
Another good resource is https://gitignore.io/. You can add all the tools you’re using and it will generate an appropriate .gitignore file.
Thanks. I will try it.
good suggestion, @flo! I use those too :slight_smile:
