Home
Support Forums
Azure Front Door - With Netlify
I have multiple static web apps developed in Vue.js,
e.g. 3 web apps for 3 modules of a software solution, my end result is too present to the User as
https://some.com/module1
https://some.com/module2
https://some.com/module3
I have configured Azure front door to forward the /module1/* appropriately to netlify domain name.
However, I can see requests are forwarded, the site is not loaded correctly. references to all the css, js are not loaded at all.
Any suggestions ? are there any _redirects to configure ?
Thanks
Could you help us with actual domains instead of placeholder ones?
https://devsmartek.azurefd.net/admin/login
Points to
https://stagingapp.smartek.net.au/login
Browsing to https://devsmartek.azurefd.net/admin/login
Results in
`Not found - Request ID: 01FA51SGJTF5B04TAGCACA9VV9
Browsing to https://devsmartek.azurefd.net/ results in
You have reached the BGA core api.
