Astro project no longer showing svg images
I have the same issue, 64d380c1-4a84-41c3-bd96-0386414893a3
Hi @hrishikesh, sorry, but this is not actually on my account - it’s on another work account - would it be possible for you to do it for the individual sites, please:
  • 254d2912-4e29-4337-921c-84235b5215e7
  • e0d29c66-5a53-433a-9a33-912741d71b31
  • bf268780-6aa2-4156-9f6e-9662245fc5e5
  • b8b95565-349a-46bc-96db-6079ab48099b
  • e0efd593-ff6c-42b1-a132-0ccc2099f7cb
  • 567e105e-8d9f-41d1-82a8-01b144ffcda8
Same issue here with site 27d8dec7-2665-42e8-85e8-29b09c539156 is this going to be fixed ?
Hi, we’re having the same issue as well.
a16a66df-cba4-4952-b257-e972cca3d45a
(www.slantedlight.com)
Thank you!
@hrishikesh @Melvin
It’s doing it again on the same sites that were fixed before. Can you fix them again?
Hi there - I’ve got the same problem:
Can you please also fix this for me?
The Site ID is:
e424da91-7514-43d0-aee0-16abe5bdfe5e
Hi,
I’m having an issue with displaying SVG images in my Astro project deployed on Netlify. Everything works fine locally, but after deployment on Netlify, the SVG files are not showing, while other images (e.g., JPG) display correctly. I’m using the @astrojs/netlify adapter, which gives a warning about experimental support for ā€œassets.ā€ I’ve tried various solutions, but the issue persists.
Website: pawlukstudio.pl
Site ID: 9a8f5dc5-b22b-42a7-8e9e-77805eacf853
Could you please help or suggest a solution?
Thank you!
@benyoungnz, I was able to see the issue on one of your old deploys (before you disabled the Image CDN) and have passed the bug report to the devs. Meanwhile, I have excluded you from the feature flag, so even if you switch back to the Image CDN, your website should continue working fine.
@Flamingo147, @nebrekab, @fab, @slantedlight, @s8webteam, @jochenschmich, @MatPawluk, while I have’t been able to find the exact broken image on your sites, I have excluded all of you from the feature flag as well.
@hrishikesh Would you be able to do my account/site too, please.
Site ID: 14993616-8f16-4b3b-bcf5-e7d7cd0207f5
Thank you very much
If you wouldn’t mind @hrishikesh could you also exclude this site. Sorry you have to do this.
siteID: f1b4ab17-9641-4466-b44b-1a865eadd93c
Thank you
Could you please exclude my client’s website from the feature flag.
Site ID: 1d4aaf1c-391e-46fd-954d-936dc62f39d8
My other site’s are working again, but the Site ID below still isn’t working. Can this please be fixed? This is a live site for my client.
Site ID: 0150b72f-3765-463b-bcbc-6df10013f08a
hi @hrishikesh , I am just checking you are getting these? There are a few of us that need the exclusion. Thanks. siteID: f1b4ab17-9641-4466-b44b-1a865eadd93c
@jjjhill, @lw1, @femincan, @s8webteam, added the accounts of the reported site IDs to the exclusion.
That’s great, thanks @hrishikesh
Is this still an issue? We have some Gatsby sites and while svg images show just fine on local builds, they’re broken on Netlify. Here are the site ids:
1c6437cf-2dbb-4b90-a41a-045f80255a9f
be297a74-e45a-4c2c-a548-275dd5114eee
0a28db4c-8f0e-4542-b8de-fea6871f5cac
767a7856-1804-440e-86ee-fa2b41795fb4
7730a803-8e1f-4fb6-9735-8a61420c208d
I’m not seeing image load issues on your website. Please share the URLs of the affected pages with the steps to reproduce.
Hi @hrishikesh,
Please could you add the following site IDs:
  • eb689c9c-5e58-464f-9f95-81642255936c
  • b6f459e9-21dc-4a14-b4b3-0b5d598c6cbd
  • d5523ad7-83a7-4e65-ad7a-58d39678b382
We setup some new versions of the same site for testing and have the old issue back.
Thanks in advance
This thread is no longer relevant, so not sure if it’s the same issue. All your sites seem to be password protected, so I cannot check.
Hi @hrishikesh - thanks for the speedy reply.
When you say the thread is no longer relevant, why is that? Should the issue where SVG images from the Netlify CDN were not showing in Astro projects now be fixed?
Yes, they are protected - I can share access details with you via a DM if that would help? Essentially the issue is the same as originally reported in that all images show except those that are SVGs when our Astro site builds. I’ve temporarily disabled the Netlify image CDN for now, but could re-enable if you want to see the issue?
Thank you
