Any tips for Nuxt 3 SSR continuous build?
Is there any tips on how to have a continuous build of Nuxt 3 SSR mode?
I found that every time we deploy a new build, on first load of the page it always showing error but after a page refresh it backs to normal.
Hi :wave:t6: welcome to the forums! Thanks so much for reaching out.
Have you tried that changing the build command in the package.json file from nuxt generate to nuxt build this resolved a similar issue in the past.
If not can you please supply your site details?
I’m on Nuxt 3.
The build command is nuxi build
So, every time ther eis a new build, the page must be refreshed twice to get the latest build loaded.
The first refresh will throw an HTTP 500 which I believe because of cache, the previous build file already gone.
Then second refresh then will get the new file and page will be loaded correctly.
