Home
Support Forums
Any solution to get Deploy Previews when using Bitbucket?
I’ve used Netlify in the past with GitHub and it worked like a charm, we used it extensively for Deploy Previews. I now have a repo that’s on BitBucket, so signed up to get deploy previews, only to find out that Bitbucket is not supported?
Is there any workaround? Perhaps using webhooks?
Hi there, @rolando :wave:
Thanks for reaching out, and welcome to the Netlify Forums :netliconfetti: Unfortunately, deploy previews are not compatible with Bitbucket. You can read more in their open Jira ticket. I do not have a workaround at this time – sorry we don’t have better news for you!
