Hi
I’m trying to figure out why my build for [condescending-keller-2d7116] is suddenly failing.
It is an 11ty install which used to work. But (together with some of my other installs) it stopped working on june 8th this year.
The log for [condescending-keller-2d7116] is here:
1:20:03 PM: Build ready to start
1:20:05 PM: build-image version: 30f629161c0736b1a3ecd8b418e5eeffab5c0faf
1:20:05 PM: build-image tag: v3.3.14
1:20:05 PM: buildbot version: a383ed3390159974f55f285b04457b44cb49efb0
1:20:05 PM: Fetching cached dependencies
1:20:05 PM: Starting to download cache of 172.8MB
1:20:07 PM: Finished downloading cache in 2.353545652s
1:20:07 PM: Starting to extract cache
1:20:16 PM: Finished extracting cache in 8.784922617s
1:20:16 PM: Finished fetching cache in 11.21088725s
1:20:16 PM: Starting to prepare the repo for build
1:20:17 PM: Preparing Git Reference refs/heads/master
1:20:23 PM: Starting build script
1:20:23 PM: Installing dependencies
1:20:24 PM: Started restoring cached node version
1:20:28 PM: Finished restoring cached node version
1:20:29 PM: v10.21.0 is already installed.
1:20:30 PM: Now using node v10.21.0 (npm v6.14.4)
1:20:30 PM: Started restoring cached build plugins
1:20:30 PM: Finished restoring cached build plugins
1:20:30 PM: Attempting ruby version 2.6.2, read from environment
1:20:32 PM: Using ruby version 2.6.2
1:20:32 PM: Using PHP version 5.6
1:20:32 PM: 5.2 is already installed.
1:20:32 PM: Using Swift version 5.2
1:20:32 PM: Started restoring cached node modules
1:20:32 PM: Finished restoring cached node modules
1:20:33 PM: Installing NPM modules using NPM version 6.14.4
1:20:41 PM: npm WARN dashboard@1.0.0 No repository field.
1:20:41 PM: npm
1:20:41 PM: WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/chokidar/node_modules/fsevents):
1:20:41 PM: npm
1:20:41 PM: WARN notsup
1:20:41 PM: SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
1:20:41 PM: npm
1:20:41 PM: SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/rollup/node_modules/fsevents):
1:20:41 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
1:20:41 PM: npm
1:20:41 PM: WARN
1:20:41 PM: optional
1:20:41 PM: SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.12 (node_modules/fsevents):
1:20:41 PM: npm
1:20:41 PM: WARN
1:20:41 PM: notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
1:20:41 PM: audited 1113 packages in 7.879s
1:20:42 PM: 32 packages are looking for funding
1:20:42 PM: run `npm fund` for details
1:20:42 PM: found 13 vulnerabilities (4 low, 4 moderate, 5 high)
1:20:42 PM: run `npm audit fix` to fix them, or `npm audit` for details
1:20:42 PM: NPM modules installed
1:20:42 PM: Started restoring cached go cache
1:20:42 PM: Finished restoring cached go cache
1:20:43 PM: go version go1.12 linux/amd64
1:20:43 PM: Installing missing commands
1:20:43 PM: Verify run directory
1:20:44 PM:
1:20:44 PM: ┌─────────────────────────────┐
1:20:44 PM: │ Netlify Build │
1:20:44 PM: └─────────────────────────────┘
1:20:44 PM:
1:20:44 PM: ❯ Version
1:20:44 PM: @netlify/build 1.0.16
1:20:44 PM:
1:20:44 PM: ❯ Flags
1:20:44 PM: mode: buildbot
1:20:44 PM:
1:20:44 PM: ❯ Current directory
1:20:44 PM: /opt/build/repo
1:20:44 PM:
1:20:44 PM: ❯ Config file
1:20:44 PM: No config file was defined: using default values.
1:20:44 PM:
1:20:44 PM: ❯ Context
1:20:44 PM: production
1:20:45 PM:
1:20:45 PM: ┌────────────────────────────────┐
1:20:45 PM: │ 1. Build command from settings │
1:20:45 PM: └────────────────────────────────┘
1:20:45 PM:
1:20:45 PM: $ prod
1:20:45 PM: bash: prod: command not found
1:20:45 PM:
1:20:45 PM: ┌─────────────────────────────┐
1:20:45 PM: │ "build.command" failed │
1:20:45 PM: └─────────────────────────────┘
1:20:45 PM:
1:20:45 PM: Error message
1:20:45 PM: Command failed with exit code 127: prod
1:20:45 PM:
1:20:45 PM: Error location
1:20:45 PM: In Build command from settings:
1:20:45 PM: prod
1:20:45 PM:
1:20:45 PM: Resolved config
1:20:45 PM: build:
1:20:45 PM: command: prod
1:20:45 PM: publish: /opt/build/repo/dist
1:20:45 PM: Caching artifacts
1:20:45 PM: Started saving node modules
1:20:45 PM: Finished saving node modules
1:20:45 PM: Started saving build plugins
1:20:45 PM: Finished saving build plugins
1:20:45 PM: Started saving pip cache
1:20:46 PM: Finished saving pip cache
1:20:46 PM: Started saving emacs cask dependencies
1:20:46 PM: Finished saving emacs cask dependencies
1:20:46 PM: Started saving maven dependencies
1:20:46 PM: Finished saving maven dependencies
1:20:46 PM: Started saving boot dependencies
1:20:46 PM: Finished saving boot dependencies
1:20:46 PM: Started saving go dependencies
1:20:46 PM: Finished saving go dependencies
1:20:46 PM: Error running command: Build script returned non-zero exit code: 1
1:20:46 PM: Failing build: Failed to build site
1:20:46 PM: Failed during stage 'building site': Build script returned non-zero exit code: 1
1:20:46 PM: Finished processing build request in 41.343136068s
And here is my build settings from package.json
And this is my build settings from package.json
"name": "dashboard",
"version": "1.0.0",
"description": "A simple dashboard to show datafrom projects with all api rolled up when static sites are generated = pure static and fast for the end user",
"main": "index.js",
"scripts": {
"prod": "cross-env NODE_ENV=production npm-run-all clean -p prod:*",
"prod:11ty": "eleventy --quiet",
"prod:rollup": "rollup -c",
"clean": "rimraf dist",
"dev": "npm-run-all clean build:* -p dev:*",
"dev:11ty": "eleventy --serve --quiet",
"dev:rollup": "rollup -c -w"
"author": "Mark Buskbjerg",
"license": "ISC",
// I removed depencies since those with @ in the depencyname counted as mentions :)
I’ve tried reverting to earlier commits where builds were succesful. But this doesn’t help me.
Also tried renaming build script from build to prod (was mentioned in your docs I shouldn’t use build)
I’ve been through the other topics with this error. But I’m not getting a solution.
The weirdest part seems to me that it just stopped working withoug me introducing new stuff to the git repo of either of my sites.
